MonoKrom - QtPyVCP GUI for PlasmaC and Mill
- Thank you received: 7505
04 Aug 2025 18:40 #332858
Replied by tommylight on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Added 2 more.
@tomapc
@toma.cnc1
@toma.3d
@tomaberisha5688
Reminds me, i have to fix the name on the last one as it was the first one i registered.
@tomapc
@toma.cnc1
@toma.3d
@tomaberisha5688
- Sandro
- Thank you received: 38
19 Oct 2025 14:53 #336722
by Sandro
Replied by Sandro on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Hello everyone
After seeing your video (looks really great by the way), I wanted to check out MonoKrom as well. However, following the instructions on the QtPyVCP repo, I fail at the step of installing MonoKrom itself. The apt source seems not be available anymore.
www.qtpyvcp.com/install/apt_install.html
$ sudo apt install python3-monokrom
Greetings Sandro
Greetings Sandro
- Joco
- Thank you received: 327
22 Oct 2025 16:16 - 23 Oct 2025 00:11 #336895
by Joco
Replied by Joco on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
The standard instructions are for stable releases. Monokrom is still in development. To enable access to development you need to adjust the sources line in /etc/apt/sources.list.d/kcjengr.list to read:deb [arch=arm64] repository.qtpyvcp.com/apt develop main
NOTE: the arch= on your install migh be different. Do no change that part of the entry.
Cheers.
Cheers.
Last edit: 23 Oct 2025 00:11 by Joco.
- Sandro
03 Nov 2025 13:20 #337778
by Sandro
Thank you Joco!
This works and I'm able to control my plasmacutter. I really like the interface.
I'm now only facing an issue loading g-code. I'm using the plasmac post processor for Sheetcam which outputs .tap files. When I load a file, I get the message “unknown word where unary operation could be”. I just assume, it has something to do with the filte section in my INI-File.
Is it possible, that the preprocessor cannot interpret my .tap. file?
[FILTER]
PROGRAM_EXTENSION = .ngc,.nc,.tap GCode File (*.ngc, *.nc, *.tap)
ngc = plasma_gcode_preprocessor
nc = plasma_gcode_preprocessor
tap = plasma_gcode_preprocessorIs it possible, that the preprocessor cannot interpret my .tap. file?
- Thank you received: 4155
05 Nov 2025 02:02 #337871
Replied by rodw on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
There is a sheetcam setting to set the file extension. I always output .ngc files but you can set linuxcnc to open tap too
The following user(s) said Thank You: Sandro
- Hakan
- Thank you received: 497
05 Nov 2025 03:02 #337874
by Hakan
Replied by Hakan on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
I tried to install Monokrom and installed python3-monokrom.
Then it stopped.
monokrom_plasma --install didn't do anything useful as far as I can see.Couldn't find the way forward.
Can some outline the steps to install monokrom. I have a qtplasmac system I want to test this on.
Then it stopped.
- Sandro
05 Nov 2025 13:34 #337904
by Sandro
This is just from the top of my head. I do not know if all steps are necessary:
1) Prerequisites for python3:
2) Then I followed those instructions for a development install: www.qtpyvcp.com/install/dev_install.html
3) Adding:
to the sources list in:
Note that if you have an x86 64-bit CPU it should be something like
4) Finally:
As mentioned, this is just as I roughly remember it. I could be off here. I've tried a lot of things till I was successful.
sudo apt install python3-pyqt5 python3-dbus.mainloop.pyqt5 python3-pyqt5.qtopengl python3-pyqt5.qsci python3-pyqt5.qtmultimedia \
python3-pyqt5.qtquick qml-module-qtquick-controls gstreamer1.0-plugins-bad libqt5multimedia5-plugins pyqt5-dev-tools python3-dev \
python3-setuptools python3-wheel python3-pip python3-six python3-docopt python3-qtpy python3-pyudev python3-psutil python3-markupsafe \
python3-opengl python3-vtk9 python3-pyqtgraph python3-simpleeval python3-jinja2 python3-deepdiff python3-sqlalchemy git python3-distro \
python3-serial2) Then I followed those instructions for a development install: www.qtpyvcp.com/install/dev_install.html
3) Adding:
read:deb [arch=arm64] [url=https://repository.qtpyvcp.com/apt]repository.qtpyvcp.com/apt[/url]to the sources list in:
/etc/apt/sources.list.d/kcjengr.listNote that if you have an x86 64-bit CPU it should be something like
read:deb [arch=amd64] [url=https://repository.qtpyvcp.com/apt]repository.qtpyvcp.com/apt[/url]4) Finally:
$ sudo apt install python3-monokromAs mentioned, this is just as I roughly remember it. I could be off here. I've tried a lot of things till I was successful.
- Sandro
05 Nov 2025 13:37 #337905
by Sandro
And remove the [url= or [/url] from the sources. I don't know what is going on with this editor.
- Hakan
05 Nov 2025 14:40 #337910
by Hakan
I few of the dependencies were missing.
I hope the --install is the next step.
debian@plasma:~$ monokrom_plasma --install
File "/usr/bin/monokrom_plasma", line 8, in <module>
sys.exit(main())
File "/usr/lib/python3/dist-packages/monokrom/plasma/__init__.py", line 8, in main
monokrom.main('plasma', opts)
File "/usr/lib/python3/dist-packages/monokrom/__init__.py", line 104, in main
copy_tree(src, os.path.expanduser('~/linuxcnc'), update=1)
File "/usr/lib/python3/dist-packages/setuptools/_distutils/dir_util.py", line 127, in copy_tree
raise DistutilsFileError(f"cannot copy tree '{src}': not a directory")
distutils.errors.DistutilsFileError: cannot copy tree '/home/debian/.local/share/monokrom/linuxcnc': not a directoryI hope the --install is the next step.
- Hakan
05 Nov 2025 15:07 #337914
by Hakan
Okay, I just copied the linuxcnc config directory from monokrom-vcp to my config directory.
Go sim.monokrom/plasmaGives the following, missing module imp which is deprecated when searching for it.
debian$ linuxcnc xyz.iniTraceback (most recent call last):
sys.exit(main())
File "/usr/lib/python3/dist-packages/monokrom/__init__.py", line 111, in main
qtpyvcp.run_vcp(opts, config_file)
File "/usr/lib/python3/dist-packages/qtpyvcp/__init__.py", line 26, in run_vcp
run(*args, **kwargs)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/__init__.py", line 129, in run
launch_application(opts, config)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 70, in launch_application
app = _initialize_object_from_dict(config['application'])
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 205, in _initialize_object_from_dict
obj = _get_object_by_referance(provider)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 193, in _get_object_by_referance
return getattr(importlib.import_module(modname), attrname)
File "/usr/lib/python3.13/importlib/__init__.py", line 88, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1387, in _gcd_import
File "<frozen importlib._bootstrap>", line 1360, in _find_and_load
File "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 935, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 1026, in exec_module
File "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removed
File "/usr/lib/python3/dist-packages/qtpyvcp/app/application.py", line 7, in <module>
import imp
ModuleNotFoundError: No module named 'imp'
Moderators: KCJ, Lcvette
Time to create page: 0.211 seconds
