MonoKrom - QtPyVCP GUI for PlasmaC and Mill
- pinder
- Thank you received: 128
09 Nov 2021 03:51 #225765
by pinder
Replied by pinder on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
hello @Joco
I appriciate for efforts you are putting here.
I will try to catch up the project again.
Cheers
Pinder
Cheers
Pinder
- anfänger
- Thank you received: 260
10 Nov 2021 06:39 #225929
by anfänger
Replied by anfänger on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Hi, has anyone tried MonoKrom on a mill yet. I think it would be fun to keep the oldschool look of my current retrofit project. For my other machines I’ve used probe basic, but I am not sure if it fits the screen I’ve here.
Thanks Patrick
Thanks Patrick
- Joco
- Thank you received: 327
10 Nov 2021 17:25 #226015
by Joco
Replied by Joco on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Hazzy did the initial mill work. But don’t know if he has done anything more than sim tests with it. I’m solely focused on the plasma version slowly nibbling at the long road to catchup with qtplasmac.
The following user(s) said Thank You: anfänger
- anfänger
10 Nov 2021 18:48 #226020
by anfänger
Thanks, I will give it a look when I start with the GUI
- Joco
11 Nov 2021 10:12 #226087
by Joco
A short update. With reference to
forum.linuxcnc.org/media/kunena/attachments/22732/param-run.jpg
The save/update/reload/new have been implemented on the combination of process-filters to process-parameters.
I'm also working on a simple "behind the scenes" script to seed a filters/parameters cut database from sheetcam tool files or a standard tabular format. The pattern being to convert from a source (sheetcam being the most likely source, but other popular formats could be supported) to the common tabular text format (just tab separated csv) which will be loadable into the qtpyvcp plasma database via the frameworks plasma-processes plugin.
The next stage is to get the linkage to hole/slot cutting parameters for hole/slot auto detection. The intent being to support process adjustment on gcode load.
Cheers - James.
Cheers - James.
- Joco
12 Nov 2021 18:46 #226239
by Joco
A short video showing the new material/cut selection Model i was working on recently. Some “fat finger” tuning to be done but hopefully it gives the general idea.
The following user(s) said Thank You: tommylight, rodw, KCJ
- anfänger
15 Nov 2021 19:46 #226600
by anfänger
Just took a short look at the mill version. its really at an early state with a lot work to do. Is there a way to get the development version like with Probe Basic?
cheers Patrick
cheers Patrick
- Joco
15 Nov 2021 22:48 #226607
by Joco
The following user(s) said Thank You: BigJohnT
- anfänger
16 Nov 2021 06:26 - 16 Nov 2021 06:26 #226626
by anfänger
thanks I downloaded it. Strange on the weekend I thought it wanted a username and password to checkout.
Last edit: 16 Nov 2021 06:26 by anfänger.
- Joco
22 Nov 2021 21:08 #227325
by Joco
New screen video of the interaction between gcode file, the filter program, the cutchart DB and the UI. Audio might be a little loud so suggest you turn down to start with and increase to comfortable levels.
Cheers - J.
Cheers - J.
The following user(s) said Thank You: TurBoss, tommylight, rodw
Moderators: KCJ, Lcvette
Time to create page: 0.383 seconds
