MonoKrom - QtPyVCP GUI for PlasmaC and Mill
- pinder
- Thank you received: 128
11 Oct 2020 17:23 #185731
by pinder
Replied by pinder on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Do we need go to zero button?
- Thank you received: 7478
11 Oct 2020 18:20 #185738
Also i remove the ohmic probe from the PlasmaC and add it there.
Replied by tommylight on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Not really, MDI can do that.Do we need go to zero button?
The following user(s) said Thank You: KCJ, pinder
- pinder
20 Oct 2020 14:57 #186698
by pinder
any updates?
The following user(s) said Thank You: AgentWD40
- MARCOS ROGERIO
25 Nov 2020 23:19 #190301
by MARCOS ROGERIO
Replied by MARCOS ROGERIO on topic Gui for plasmac
ola ! pinder voce comercializa essas gui para plasmac ? gostaria que desenvolvesse uma para min !
13 Dec 2020 23:13 - 13 Dec 2020 23:17 #191923
Replied by tommylight on topic Gui for plasmac
Has anyone seen Pinder lately?
Last update on github 28 days ago, spindle stuff for the Mill version.
Last edit: 13 Dec 2020 23:17 by tommylight. Reason: more info
- pinder
14 Dec 2020 06:37 - 14 Dec 2020 06:44 #191941
by pinder
hello everyone.
I am really sorry for not being able to finish this project yet.
The thing is I am starting a workshop of my own. I am 29, some say it's too early, but still, I am doing it. Wish me luck.
Legal works, architects, and construction is keeping me from everything.
Hopefully, everything will settle down by February.
Monokrom is a need of my own, so it will be usable for plasma and mill asap. Kurt is also busy with his stuff. Moreover, he has done all the work.
Better late than never.
Last edit: 14 Dec 2020 06:44 by pinder.
The following user(s) said Thank You: TurBoss, tommylight, KCJ
14 Dec 2020 09:07 #191946
Good luck with everything.
Doing the same thing here, the shops keep getting smaller !
26 Dec 2020 14:59 #193236
Made this a sticky as i had to use google to search for it several times.
- Joco
- Thank you received: 327
05 Apr 2021 09:41 #204870
by Joco
Replied by Joco on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
Starting a plasma cnc build and looking at interface options. I can see QTPlasmac is available and uses this style. However that is linked to linuxcnc 2.9 and to be honest my tests with 2.9 have made me skitish about it. Having linuxcnc seg fault or generate fatal XWindow errors is not good on a machine pushing sun hot plasma about the place.
On 2.8 things are nice and solid. So keen to see if this has been pushed along or perhaps helping to push it along to operate under 2.8.
So ... where are things at?
Cheers - J.
Cheers - J.
- snowgoer540
- Thank you received: 906
05 Apr 2021 11:54 #204883
by snowgoer540
Replied by snowgoer540 on topic MonoKrom - QtPyVCP GUI for PlasmaC and Mill
I’m curious what your tests involved?
I will say I’ve been running QtPlasmaC (and LinuxCNC 2.9) since it’s inception around October 2020, and I have yet to encounter any LinuxCNC specific related issue. Period.
I also know of many users running the original PlasmaC on 2.9 without incident as well.
There were two eoffset “issues” we ran into and I say “issues” because they were more to do with PlasmaC using them in a way that was outside of their original design scope. But those “issues” were present in 2.8 as well.
Moderators: KCJ, Lcvette
Time to create page: 1.479 seconds
