  • FullMetalDad
  • FullMetalDad
04 Nov 2025 20:51
Replied by FullMetalDad on topic FreeCAD 1.0 Who's using it?
Category: CAD CAM
I've been using FreeCAD for the last year as I learn CAD and now CAM. Its been a pretty good experience for me, I dont understand all the hate from the larger internet. I just chock it up to not learning any other CAD package first (unless you count Kicad).
Its been pretty cool watching it move to V1 and now beyond. It looks like CAM gets some good updates in V1.1. I might need to try the dev version one of these days.
  • unknown
  • unknown
04 Nov 2025 20:07
Proposal RPi Linuxcnc Image Based on Raspi OS All welcome/encoraged to comment
Category: Installing LinuxCNC
Adding the repo was no issue, haven't actually tried the build process yet.
Tho what I have been working on is trimming the image down. So far the compressed download has gone from about 2.2ishGB to 1.7ish. No Wayland, quite a bit of stuff removed, such as thonny, python libs that were related to the RPi development package. Modemmanger was removed, vnc taken out as cups was a dependency, which also takes 2 unneeded services out of the equation. Basically as much as I could find that wasn't really required to run a CNC machine. The image does have 2 desktop environments XFCE which is the default and RPi LXDE , you can swap via logging out and selecting the session from the login screen.
One thing that is annoying is that Linuxcnc appears under 3 different menu headings, whilst it is annoying is doesn't affect operation, this can be fixed by editing the desktop files deep in the system, this could get overwritten via upgrades. I'm considering using a 'hook' that is run when Linuxcnc is upgraded that fixes these annoying menu entries. Another "side project" to jump into.
This feels more like a blog now where I record ideas and changes hahaha
  • Ul
  • Ul
04 Nov 2025 20:03
Replied by Ul on topic Alle Desktopsymbole verschwunden
Category: Deutsch
Es ist möglich, dass es einen Fehler beim Abspeichern einer früheren Sitzung gegeben hat:
1. Gib mal im Dateimanager in die Adressenleiste ein: ~/.cache/sessions
2. Verschiebe den gesamten Ordnerinhalt woanders hin
3. Gehe auf Log Out, nimm den Haken bei "Save session for future login"
weg und starte neu
Ohne Gewähr. Ich habe es gerade bei mir getestet, keine Probleme nach dem Neustart. Ansonsten müsste man zuvor verschobene Daten zurückverschieben können.
  • unknown
  • unknown
04 Nov 2025 19:50
I have built the hardware and I have some questions
Sorry I pressed submit to early, the discussion is here
forum.linuxcnc.org/9-installing-linuxcnc...encoraged-to-comment
And I'm quite desperate to have at least one person to test.
  • unknown
  • unknown
04 Nov 2025 19:48
Mesa is pretty much the standard, firmware sources are open source, as you have found. Pete is rather open with his hardware designs, there are 7i92 clones on Ali express.
If you really want to have a look at well evolved ecosystem I suggest you check out this topic
forum.linuxcnc.org/18-computer/49142-lin...d-on-fpga-ice40-ecp5
This has evolved into the riocore project.
It may be an idea to contact Ollie and discuss enclosures and such. Whilst he has designed some boards his energies are mainly taken up by the firmware and software side.
So rather than another project from scratch, I honestly think offering your hardware skills would be awesome to take that project to the next level.
I'd even like to offer my help, I've been working on a custom RPi5\4 image based on the RPi build system, rather than another build system, that is basically exactly the same to setup on Raspberry Pi as a standard image.
  • chrischan
  • chrischan
04 Nov 2025 19:44
Replied by chrischan on topic Alle Desktopsymbole verschwunden
Category: Deutsch
Ja im Home Ordner ist alles vorhanden. Es wird nur nix angezeigt. Und auch RMB macht nix
  • rodw
  • rodw's Avatar
04 Nov 2025 19:37
Help with Wireless Handwheel XHC-WHB04B-6 (wrong Product ID)
[b]From what I’ve read, the Product ID is defined in the driver source (like usb.h), and you’d need to rebuild it — which I can’t manage.[/b]
Anybody can build linuxcnc from source. I did a video guide. studio.youtube.com/video/Oe4Hfq3G2_A/edit
  • rodw
  • rodw's Avatar
04 Nov 2025 19:33
Replied by rodw on topic USB activity causes network error
Category: Plasmac
Once you have isolated cores, Real time applications (like Linuxcnc) will run on one of those cores. More particularly, the RT servo thread will run there. I think user space parts will run on non isolated cores where there is no need to be in time...
  • Ul
  • Ul
04 Nov 2025 19:33 - 04 Nov 2025 19:33
Category: Deutsch
Gut, dann hat es immerhin kein Upgrade gemacht. Ist der Desktopordner im /home Verzeichnis zu finden?
  • unknown
  • unknown
04 Nov 2025 19:30
It's the IDs that are the issue which are hard coded into the driver. 2.9.7 won't help.
  • unknown
  • unknown
04 Nov 2025 19:28
Replied by unknown on topic Suggest RTAI version for me
Try the wheezy ISO from the downloads page, tho it will limit the version of Linuxcnc you can use. That really isn't an issue as it will work fine. Actually there's a few members that run earlier versions.
  • rodw
  • rodw's Avatar
04 Nov 2025 19:28
Replied by rodw on topic Suggest RTAI version for me
I personally think that modern Operating systems need more than 2 cores to  run  Linuxcnc these days. Give RTAI for 2.94 a go and see how you go.
I have no experience.
  • SvenRSA
  • SvenRSA
04 Nov 2025 19:28
Replied by SvenRSA on topic Maho 700C A-axis (rotating table)
Thanks I’ll be sure to check this.
  • rodw
  • rodw's Avatar
04 Nov 2025 19:26
Linuxcnc 2.9.4 was released to fix some things with with XHC USB pendants. Perhaps an upgrade will fix things. Here is how to get it on Trixie
  • Hakan
  • Hakan
04 Nov 2025 19:21
There may be more than the usb product code that differ between them.
Here is where to change github.com/LinuxCNC/linuxcnc/blob/fb1480...-whb04b-6/usb.h#L311
Then build linuxcnc and run-in-place.
Displaying 7651 - 7665 out of 16729 results.
Time to create page: 0.262 seconds
