  • andypugh
  • andypugh's Avatar
24 Oct 2025 20:47
Replied by andypugh on topic XHC-WHB04B-4 error during compile
Are you compiling from source because 2.9.6 doesn't work properly with the XHCWHB component?
If so then see this thread:
forum.linuxcnc.org/21-axis/57364-axis-co...-9-6?start=10#336658
if not, then you can get a list of the missing build dependencies
cd linuxcnc-dev
./debian configure no-docs
dpkg-checkbuilddeps
  • andypugh
  • andypugh's Avatar
24 Oct 2025 20:31 - 24 Oct 2025 20:32
Replied by andypugh on topic Lathe project needs a turret
Category: Turning
The manual turret looks like a prime candidate for motorisation...
Or get an industrial robot arm to operate the manual tool changer for you. :-)
  • andypugh
  • andypugh's Avatar
24 Oct 2025 20:19
Replied by andypugh on topic Maho MH800e Retrofit Project
Category: Milling Machines
You might need to force home-sw-in high, so that it always thinks it's on the switch, and then it will set the index-enable.
ie, in the HAL file:
sets joint.0.home-sw-in 1
  • sconisbee
  • sconisbee
24 Oct 2025 20:00
Replied by sconisbee on topic Feed per rev G95 way too fast
Category: Basic Configuration
Hi Andy, I've been running a 25,000ns relatively successfully. Which is why I've been scratching my head so much. However, actually thinking out loud on here had me thinking it had to be electrical. So I dug out the oscilloscope and probed the signal. The cheap Chinese sensors had a 20k pull up resistor which was far too strong and was causing the pulse width to be way too long. So at 1900 the signal went from a pulse train to just "on".
I've swapped out the resistor and now getting good clean pulses read by the Pi with a stable speed reading up to 4000rpm.
Thank you for your suggestions as they have pointed me in the right direction. I'm in the process of modelling up a mount so i can mount two sensors to create a encoder that will do direction as you suggested.
  • bnet
  • bnet's Avatar
24 Oct 2025 19:48
Fanuc Serial Pulse Coders - Red cap servos, mesa 7i76e, how to?
Category: Driver Boards
I think you are suggesting that you could supply "fake" commutation signals from LinuxCNC to the drive, and that might be enough to persuade the drive to start working?
This is what I'm thinking. I will try it as soon as I have time and report back.
  • Unlogic
  • Unlogic
24 Oct 2025 18:54
Replied by Unlogic on topic Probe Basic backplot error when loading file
Category: QtPyVCP
For comparison here is how the plot looks without the patch applied.
  • CaliusOptimus
  • CaliusOptimus
24 Oct 2025 18:50
Lathe project needs a turret was created by CaliusOptimus
Category: Turning
Hi all, new user long time lurker. My first linuxcnc experience was a sherline and a parallel port some 10 years ago. That turned into a pair of tormachs, now a vf2ssyt, and more if I had the space. Anyway...I picked up this lathe some time ago. It was originally cnc and converted to linuxcnc by the previous owner. I got it in a sort of working state. Everything was hooked up and moving but needed some refinement. At some point the PC died of unknown causes so I decided to start from scratch with trixie, kde and 2.9.6. I've got the servo thread running solid at 0.5ms, the motors all tuned and running well, the spindle drive is now controlled through modbus rather than analog, and I've added a few handy things with pyvcp. It's running fast and holding size.Now it's ready for a turret, and I'm hoping to get a recommendation. I currently have a neat manual turret but... manual is no fun. I've browsed alibaba and seen some affordable options. Also checked ebay and the pickings were slim, ancient and beat to death. I considered a tormach turret since it works so well on my sl15 but it would be nice to beat the $5k price tag.Also searching for an automatic collet closer or some sort of automatic chuck. It would be amazing to have a 16c or a 3j automatic collet... sounds like a huge amount of work if I can't find something to retrofit. Any ideas?
  • Aciera
  • Aciera's Avatar
24 Oct 2025 18:38
Replied by Aciera on topic EtherCAT with OMRON R88D-1SN servo drive
Category: EtherCAT
Looks like a fair bit of work has already gone into this. Thanks for sharing.
  • sparviero
  • sparviero's Avatar
24 Oct 2025 18:00
EtherCAT with OMRON R88D-1SN servo drive was created by sparviero
Category: EtherCAT
Hello everyone,
I am a beginner of LinuxCNC but I have collected what i have learned using EtherCAT, BECKHOFF modules and a OMRON R88D-1SN drive. I think it may be useful for others approaching this world. The repository is still incomplete and lacks of many things. Hope in a feedback from everyone and from who is working with the same OMRON drive.
Here is the link to the github page:  linuxcnc-collection
  • Unlogic
  • Unlogic
24 Oct 2025 17:06
Category: QtPyVCP
Lcvette and the Probe Basic dev team quickly produced a patch for me to test.
They are clearly making progress on this issue because with the patch the crash is gone. However I noticed a slight side effect with the plot not drawing all the moves correctly.
Here are the steps I did to produce the following screenshots.
I started by setting all the G54, G55 and G56 offsets to all zeros:
G10 L2 P1 X0 Y0 Z0
G10 L2 P2 X0 Y0 Z0
G10 L2 P3 X0 Y0 Z0
I then loaded the file attached to my first post and probed all the three parts going from right to left (starting with G56, then G55 and finally G54). The probing worked and there was no crash but the plot show some strange moves.
Opening the same file again without doing anything else produced the following plot instead.
The plot above looks better but I think it's not fully correct as it should start with the left most part not center one.
Here are the offset values for G54, G55 and G56 used for the two plots above.
  • boksi
  • boksi
24 Oct 2025 17:00
Mesa smart serial or PktUART or serial over RS232 or udp for robot joints
Hello, I looked all options.
If I go with base interface I would have to do isolation on all 6 encoders that would be best option concenirg signal grounds and also I would have to make aditional 6 connectors to carry signals to mesa board. Also not sure if 6i25/7i92 has space for 6-7 step gens + 6 encoders(not regular ones but uart + incremental -> absolute so more logic needed). But if I do it this way I would get all 6 readings synchronized.
Probably I will choose to go with stm32 ethernet option or mesa smart serial(maybe both try). In this case I will not have synchonized reads of positions but mismatched max by 60uS.
When you talk about SSerialB are you refering to master or slave? Could official firmware for example for 6i25 or 7i92 currently accept 224bits via smart serial from slave? In my case slave will just send 24 bytes to mesa card.
Do you know for robot kinematics module how much I need to sample robot joints angles at “same” time?
I suppose mesa built encoders interface do this in hardware and just read all 6 regiters at same time, so no even small mismatch in time between samples?
  • Cooped-Up
  • Cooped-Up
24 Oct 2025 16:58
Replied by Cooped-Up on topic Maho MH800e Retrofit Project
So on the z axis I did manually set the z enable and jogged to where the index was and it did turn off. I then tried changing the final velocity to invert it from the starting velocity of homing to make it come back instead of continuing into the E stop limit and that did not change its behavior it still goes past and it's homing sequence to the E stop
  • Cooped-Up
  • Cooped-Up
24 Oct 2025 15:34
that seems like an easy enough check. Ill do that after I get home from work!
Displaying 8161 - 8175 out of 16959 results.
Time to create page: 0.521 seconds
