  • distro88
  • distro88
23 Oct 2025 20:34
Replied by distro88 on topic torch moving UP when it should be moving DOWN
Category: Plasmac
I tried that too. I even reinstalled LinuxCNC and changed all the pins — same problem
23 Oct 2025 19:57
Replied by tommylight on topic Mesa 7i95T not responding
I do not know, i only had 7i95 without the T.
  • Ringardy
  • Ringardy
23 Oct 2025 19:55 - 23 Oct 2025 19:57
Replied by Ringardy on topic Mesa 7i95T not responding
Thanks, it works but one more thing.
Even tho its a 7i95T is it normal that it only says 7i95
23 Oct 2025 19:52
Replied by tommylight on topic torch moving UP when it should be moving DOWN
Category: Plasmac
Moved to "PlasmaC" section.
I am sure this same thing was posted before here, so what happened?
Checked your files twice, seems OK, so check the wiring although from your description should be OK.
Since i can not find anything wrong and there is an issue, the quickest solution would be to make a new config.
23 Oct 2025 19:46
Yes.
In a terminal
ping 10.10.10.10
should return values with the time it takes to card and back in ns (nano seconds).
  • PCW
  • PCW's Avatar
23 Oct 2025 19:44
Replied by PCW on topic Mesa 7i95T not responding
Yes, that is the EEPROM setting.
(default EEPROM IP address is 10.10.10.10)
  • Murphy
  • Murphy
23 Oct 2025 19:14
You will have to confirm , ec300 may still hardware count by modding the same way the ec500 is done. It also has the rt1052 ic ??
  • Ringardy
  • Ringardy
23 Oct 2025 18:56
Like this ?
  • distro88
  • distro88
23 Oct 2025 18:32 - 23 Oct 2025 18:33
Category: Plasmac
Hello everyone,
I’m having a strange issue with QtPlasmaC (version 2.9.238 / LinuxCNC 2.9.2) and my PROMA THC 150 connected to a Mesa 7i92 card.
Everything on my machine moves correctly — all axes jog fine, torch on/off works, ARC OK is detected correctly, and the THC UP and DOWN inputs show properly in HAL meter.
However, during cutting:
When the THC UP signal is active, the torch moves up
When the THC DOWN signal is active, the torch moves up instead of down
Both UP and DOWN signals appear normally in HAL meter as true/false.
Here’s my setup:
Controller: Mesa 7i92 + db25 bib (raw pins)
Plasma: PROMA THC 150
QtPlasmaC version: 2.9.238 (LinuxCNC 2.9.2)
QtPlasmaC Mode: External THC (UP/DOWN/ARC OK)
THC wiring: optocoupled to Mesa inputs
Firmware: 7i92_7i76x1D.
I’ll attach my .hal and .ini files below.
.hal
# Generated by PNCconf at Wed Oct 22 23:20:44 2025
# Using LinuxCNC version:  Master (2.9)
# overwritten when you run PNCconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_spindles=[TRAJ]SPINDLES
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=1 num_pwmgens=0 num_stepgens=5 sserial_port_0=00xxxxxx"
setp    hm2_7i92.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.y2,pid.z,pid.s
loadrt plasmac
addf hm2_7i92.0.read          servo-thread
addf motion-command-handler   servo-thread
addf motion-controller        servo-thread
addf pid.x.do-pid-calcs       servo-thread
addf pid.y.do-pid-calcs       servo-thread
addf pid.y2.do-pid-calcs       servo-thread
addf pid.z.do-pid-calcs       servo-thread
addf pid.s.do-pid-calcs       servo-thread
addf plasmac                  servo-thread
addf hm2_7i92.0.write         servo-thread
setp hm2_7i92.0.dpll.01.timer-us -50
setp hm2_7i92.0.stepgen.timer-number 1
# ---PLASMA INPUT DEBOUNCE---
#values for these are in custom.hal
loadrt dbounce names=db_breakaway,db_float,db_ohmic,db_arc-ok
addf db_float     servo-thread
addf db_ohmic     servo-thread
addf db_breakaway servo-thread
addf db_arc-ok    servo-thread
# ---JOINT ASSOCIATED WITH THE Z AXIS---
net plasmac:axis-position joint.3.pos-fb => plasmac.axis-z-position
# ---PLASMA INPUTS---
# ---all modes---
net plasmac:float-switch     => db_float.in
net plasmac:breakaway        => db_breakaway.in
net plasmac:ohmic-probe      => db_ohmic.in
net plasmac:ohmic-sense-in   => plasmac.ohmic-sense-in
# ---modes 0 & 1
net plasmac:arc-voltage-in   => plasmac.arc-voltage-in
# ---modes 1 & 2
net plasmac:arc-ok-in        => db_arc-ok.in
# ---mode 2
net plasmac:move-up          <= plasmac.move-up
net plasmac:move-down        <= plasmac.move-down
# ---PLASMA OUTPUTS---
# ---all modes---
net plasmac:ohmic-enable     <= plasmac.ohmic-enable
net plasmac:scribe-arm       <= plasmac.scribe-arm
net plasmac:scribe-on        <= plasmac.scribe-on
# external output signals
# --- PLASMAC:TORCH-ON ---
setp hm2_7i92.0.gpio.030.is_output true
net plasmac:torch-on  =>     hm2_7i92.0.gpio.030.out
setp hm2_7i92.0.gpio.030.invert_output true
# --- PLASMAC:LASER-ON ---
setp hm2_7i92.0.gpio.031.is_output true
net plasmac:laser-on  =>     hm2_7i92.0.gpio.031.out
# --- DOUT-00 ---
setp hm2_7i92.0.gpio.032.is_output true
net dout-00  =>     hm2_7i92.0.gpio.032.out
# --- DOUT-01 ---
setp hm2_7i92.0.gpio.033.is_output true
#qtplasmac uses digital output dout-01:
#net dout-01  =>     hm2_7i92.0.gpio.033.out
# external input signals
# --- MIN-HOME-X ---
net min-home-x     <=  hm2_7i92.0.gpio.018.in
# --- MIN-HOME-Y ---
net min-home-y     <=  hm2_7i92.0.gpio.019.in
# --- MIN-HOME-Y2 ---
net min-home-y2     <=  hm2_7i92.0.gpio.020.in
# --- MAX-HOME-Z ---
net max-home-z     <=  hm2_7i92.0.gpio.021.in
# --- PLASMAC:FLOAT-SWITCH ---
net plasmac:float-switch     <=  hm2_7i92.0.gpio.022.in
# --- PLASMAC:BREAKAWAY ---
net plasmac:breakaway     <=  hm2_7i92.0.gpio.023.in
# --- PLASMAC:ARC-OK-IN ---
net plasmac:arc-ok-in     <=  hm2_7i92.0.gpio.024.in
# --- PLASMAC:MOVE-UP ---
net plasmac:move-up     <=  hm2_7i92.0.gpio.025.in
# --- PLASMAC:MOVE-DOWN ---
net plasmac:move-down     <=  hm2_7i92.0.gpio.026.in
# --- ESTOP-EXT ---
net estop-ext     <=  hm2_7i92.0.gpio.027.in_not
#  AXIS X JOINT 0
setp   pid.x.Pgain     [JOINT_0]P
setp   pid.x.Igain     [JOINT_0]I
setp   pid.x.Dgain     [JOINT_0]D
setp   pid.x.bias      [JOINT_0]BIAS
setp   pid.x.FF0       [JOINT_0]FF0
setp   pid.x.FF1       [JOINT_0]FF1
setp   pid.x.FF2       [JOINT_0]FF2
setp   pid.x.deadband  [JOINT_0]DEADBAND
setp   pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp   pid.x.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp   pid.x.maxerror 0.012700
net x-index-enable  =>  pid.x.index-enable
net x-enable        =>  pid.x.enable
net x-pos-cmd       =>  pid.x.command
net x-pos-fb        =>  pid.x.feedback
net x-output        <=  pid.x.output
# Step Gen signals/setup
setp   hm2_7i92.0.stepgen.00.dirsetup        [JOINT_0]DIRSETUP
setp   hm2_7i92.0.stepgen.00.dirhold         [JOINT_0]DIRHOLD
setp   hm2_7i92.0.stepgen.00.steplen         [JOINT_0]STEPLEN
setp   hm2_7i92.0.stepgen.00.stepspace       [JOINT_0]STEPSPACE
setp   hm2_7i92.0.stepgen.00.position-scale  [JOINT_0]STEP_SCALE
setp   hm2_7i92.0.stepgen.00.step_type        0
setp   hm2_7i92.0.stepgen.00.control-type     1
setp   hm2_7i92.0.stepgen.00.maxaccel         [JOINT_0]STEPGEN_MAXACCEL
setp   hm2_7i92.0.stepgen.00.maxvel           [JOINT_0]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net x-pos-cmd    <= joint.0.motor-pos-cmd
net x-vel-cmd    <= joint.0.vel-cmd
net x-output     => hm2_7i92.0.stepgen.00.velocity-cmd
net x-pos-fb     <= hm2_7i92.0.stepgen.00.position-fb
net x-pos-fb     => joint.0.motor-pos-fb
net x-enable     <= joint.0.amp-enable-out
net x-enable     => hm2_7i92.0.stepgen.00.enable
# ---setup home / limit switch signals---
net min-home-x     =>  joint.0.home-sw-in
net min-home-x     =>  joint.0.neg-lim-sw-in
net x-pos-limit     =>  joint.0.pos-lim-sw-in
#  AXIS Y JOINT 1
setp   pid.y.Pgain     [JOINT_1]P
setp   pid.y.Igain     [JOINT_1]I
setp   pid.y.Dgain     [JOINT_1]D
setp   pid.y.bias      [JOINT_1]BIAS
setp   pid.y.FF0       [JOINT_1]FF0
setp   pid.y.FF1       [JOINT_1]FF1
setp   pid.y.FF2       [JOINT_1]FF2
setp   pid.y.deadband  [JOINT_1]DEADBAND
setp   pid.y.maxoutput [JOINT_1]MAX_OUTPUT
setp   pid.y.error-previous-target true
setp   pid.y.maxerror 0.012700
net y-index-enable  =>  pid.y.index-enable
net y-enable        =>  pid.y.enable
net y-pos-cmd       =>  pid.y.command
net y-pos-fb        =>  pid.y.feedback
net y-output        <=  pid.y.output
setp   hm2_7i92.0.stepgen.01.dirsetup        [JOINT_1]DIRSETUP
setp   hm2_7i92.0.stepgen.01.dirhold         [JOINT_1]DIRHOLD
setp   hm2_7i92.0.stepgen.01.steplen         [JOINT_1]STEPLEN
setp   hm2_7i92.0.stepgen.01.stepspace       [JOINT_1]STEPSPACE
setp   hm2_7i92.0.stepgen.01.position-scale  [JOINT_1]STEP_SCALE
setp   hm2_7i92.0.stepgen.01.step_type        0
setp   hm2_7i92.0.stepgen.01.control-type     1
setp   hm2_7i92.0.stepgen.01.maxaccel         [JOINT_1]STEPGEN_MAXACCEL
setp   hm2_7i92.0.stepgen.01.maxvel           [JOINT_1]STEPGEN_MAXVEL
net y-pos-cmd    <= joint.1.motor-pos-cmd
net y-vel-cmd    <= joint.1.vel-cmd
net y-output     => hm2_7i92.0.stepgen.01.velocity-cmd
net y-pos-fb     <= hm2_7i92.0.stepgen.01.position-fb
net y-pos-fb     => joint.1.motor-pos-fb
net y-enable     <= joint.1.amp-enable-out
net y-enable     => hm2_7i92.0.stepgen.01.enable
net min-home-y     =>  joint.1.home-sw-in
net min-home-y     =>  joint.1.neg-lim-sw-in
net y-pos-limit     =>  joint.1.pos-lim-sw-in
#  Tandem AXIS Y2 JOINT 2
setp   pid.y2.Pgain     [JOINT_2]P
setp   pid.y2.Igain     [JOINT_2]I
setp   pid.y2.Dgain     [JOINT_2]D
setp   pid.y2.bias      [JOINT_2]BIAS
setp   pid.y2.FF0       [JOINT_2]FF0
setp   pid.y2.FF1       [JOINT_2]FF1
setp   pid.y2.FF2       [JOINT_2]FF2
setp   pid.y2.deadband  [JOINT_2]DEADBAND
setp   pid.y2.maxoutput [JOINT_2]MAX_OUTPUT
setp   pid.y2.error-previous-target true
setp   pid.y2.maxerror 0.012700
net y2-index-enable  =>  pid.y2.index-enable
net y2-enable        =>  pid.y2.enable
net y2-pos-cmd       =>  pid.y2.command
net y2-pos-fb        =>  pid.y2.feedback
net y2-output        <=  pid.y2.output
# Step Gen signals/setup for tandem axis
setp   hm2_7i92.0.stepgen.04.dirsetup        [JOINT_2]DIRSETUP
setp   hm2_7i92.0.stepgen.04.dirhold         [JOINT_2]DIRHOLD
setp   hm2_7i92.0.stepgen.04.steplen         [JOINT_2]STEPLEN
setp   hm2_7i92.0.stepgen.04.stepspace       [JOINT_2]STEPSPACE
setp   hm2_7i92.0.stepgen.04.position-scale  [JOINT_2]STEP_SCALE
setp   hm2_7i92.0.stepgen.04.step_type        0
setp   hm2_7i92.0.stepgen.04.control-type     1
setp   hm2_7i92.0.stepgen.04.maxaccel         [JOINT_2]STEPGEN_MAXACCEL
setp   hm2_7i92.0.stepgen.04.maxvel           [JOINT_2]STEPGEN_MAXVEL
net y2-pos-cmd    <= joint.2.motor-pos-cmd
net y2-vel-cmd    <= joint.2.vel-cmd
net y2-output     => hm2_7i92.0.stepgen.04.velocity-cmd
net y2-pos-fb     <= hm2_7i92.0.stepgen.04.position-fb
net y2-pos-fb     => joint.2.motor-pos-fb
net y2-enable     <= joint.2.amp-enable-out
net y2-enable     => hm2_7i92.0.stepgen.04.enable
net min-home-y2     =>  joint.2.home-sw-in
net min-home-y2     =>  joint.2.neg-lim-sw-in
net y2-pos-limit     =>  joint.2.pos-lim-sw-in
#  AXIS Z JOINT 3
setp   pid.z.Pgain     [JOINT_3]P
setp   pid.z.Igain     [JOINT_3]I
setp   pid.z.Dgain     [JOINT_3]D
setp   pid.z.bias      [JOINT_3]BIAS
setp   pid.z.FF0       [JOINT_3]FF0
setp   pid.z.FF1       [JOINT_3]FF1
setp   pid.z.FF2       [JOINT_3]FF2
setp   pid.z.deadband  [JOINT_3]DEADBAND
setp   pid.z.maxoutput [JOINT_3]MAX_OUTPUT
setp   pid.z.error-previous-target true
setp   pid.z.maxerror 0.012700
net z-index-enable  =>  pid.z.index-enable
net z-enable        =>  pid.z.enable
net z-pos-cmd       =>  pid.z.command
net z-pos-fb        =>  pid.z.feedback
net z-output        <=  pid.z.output
setp   hm2_7i92.0.stepgen.03.dirsetup        [JOINT_3]DIRSETUP
setp   hm2_7i92.0.stepgen.03.dirhold         [JOINT_3]DIRHOLD
setp   hm2_7i92.0.stepgen.03.steplen         [JOINT_3]STEPLEN
setp   hm2_7i92.0.stepgen.03.stepspace       [JOINT_3]STEPSPACE
setp   hm2_7i92.0.stepgen.03.position-scale  [JOINT_3]STEP_SCALE
setp   hm2_7i92.0.stepgen.03.step_type        0
setp   hm2_7i92.0.stepgen.03.control-type     1
setp   hm2_7i92.0.stepgen.03.maxaccel         [JOINT_3]STEPGEN_MAXACCEL
setp   hm2_7i92.0.stepgen.03.maxvel           [JOINT_3]STEPGEN_MAXVEL
net z-pos-cmd    <= joint.3.motor-pos-cmd
net z-vel-cmd    <= joint.3.vel-cmd
net z-output     => hm2_7i92.0.stepgen.03.velocity-cmd
net z-pos-fb     <= hm2_7i92.0.stepgen.03.position-fb
net z-pos-fb     => joint.3.motor-pos-fb
net z-enable     <= joint.3.amp-enable-out
net z-enable     => hm2_7i92.0.stepgen.03.enable
net max-home-z     =>  joint.3.home-sw-in
net z-neg-limit     =>  joint.3.neg-lim-sw-in
net max-home-z     =>  joint.3.pos-lim-sw-in
#  ---motion control signals---
net in-position               <=  motion.in-position
net machine-is-enabled        <=  motion.motion-enabled
#  ---digital in / out signals---
net dout-00     <=  motion.digital-out-00
#net dout-01     <=  motion.digital-out-01
#  ---estop signals---
net estop-out     <=  iocontrol.0.user-enable-out
net estop-ext     =>  iocontrol.0.emc-enable-in
# ---QTPLASMAC TOOLCHANGE PASSTHROUGH---
net tool:change iocontrol.0.tool-change  => iocontrol.0.tool-changed
net tool:prep   iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
.ini
[code]# Generated by PNCconf at Wed Oct 22 23:20:44 2025
[EMC]
MACHINE = test-2
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = qtvcp qtplasmac
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/x/linuxcnc/nc_files
INCREMENTS = 10mm 1mm .1mm .01mm .001mm
DEFAULT_LINEAR_VELOCITY = 6.000000
MAX_LINEAR_VELOCITY = 25.000000
MIN_LINEAR_VELOCITY = 0.500000
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
GEOMETRY = xyz
CYCLE_TIME = 100
[FILTER]
PROGRAM_EXTENSION = .ngc,.nc,.tap GCode File (*.ngc, *.nc, *.tap)
ngc = qtplasmac_gcode
nc  = qtplasmac_gcode
tap = qtplasmac_gcode
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
RS274NGC_STARTUP_CODE = G21 G40 G49 G80 G90 G92.1 G94 G97 M52P1
SUBROUTINE_PATH = ./:../../nc_files
USER_M_PATH = ./:../../nc_files
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
[HMOT]
# **** This is for info only ****
CARD0=hm2_7i92.0
[HAL]
HALUI = halui
HALFILE = test-2.hal
HALFILE = qtplasmac_comp.hal
HALFILE = custom.hal
POSTGUI_HALFILE = custom_postgui.hal
SHUTDOWN = shutdown.hal
[HALUI]
[KINS]
JOINTS = 4
KINEMATICS = trivkins coordinates=XYYZ
[TRAJ]
SPINDLES = 3
COORDINATES =  XYYZ
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 2.50
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
# MAX_VEL & MAX_ACC need to be twice the corresponding joint value
MAX_VELOCITY = 50.0
MAX_ACCELERATION = 1500.0
OFFSET_AV_RATIO = 0.5
MIN_LIMIT = -0.01
MAX_LIMIT = 2000.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
MAX_ACCELERATION = 750.0
STEPGEN_MAXVEL = 31.25
STEPGEN_MAXACCEL = 937.50
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP   = 10000
DIRHOLD    = 10000
STEPLEN    = 5000
STEPSPACE  = 5000
STEP_SCALE = 100.0
MIN_LIMIT = -0.01
MAX_LIMIT = 2000.0
HOME_OFFSET = 0.000000
HOME_SEARCH_VEL = -1.000000
HOME_LATCH_VEL = 0.500000
HOME_FINAL_VEL = 0.000000
HOME_USE_INDEX = NO
HOME_IGNORE_LIMITS = YES
HOME_SEQUENCE = 2
[AXIS_Y]
MAX_VELOCITY = 50.0
MIN_LIMIT = -0.01
MAX_LIMIT = 3000.0
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 10000
DIRHOLD    = 10000
STEPLEN    = 5000
STEPSPACE  = 5000
STEP_SCALE = 100.0
MIN_LIMIT = -0.01
MAX_LIMIT = 3000.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = -3
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 10000
DIRHOLD    = 10000
STEPLEN    = 5000
STEPSPACE  = 5000
STEP_SCALE = 100.0
MIN_LIMIT = -0.01
MAX_LIMIT = 3000.0
HOME_USE_INDEX = NO
HOME_SEQUENCE = -3
[AXIS_Z]
MAX_VELOCITY = 50.0
MIN_LIMIT = -200.0
MAX_LIMIT = 0.01
[JOINT_3]
TYPE = LINEAR
HOME = 0.0
FERROR = 10.0
MIN_FERROR = 1.0
MAX_VELOCITY = 25.0
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 10000
DIRHOLD    = 10000
STEPLEN    = 5000
STEPSPACE  = 5000
STEP_SCALE = 100.0
MIN_LIMIT = -200.0
MAX_LIMIT = 0.01
HOME_USE_INDEX = NO
HOME_SEQUENCE = 1
Any help or working HAL example with PROMA 150 + Mesa hardware would be greatly appreciated!
Thank you in advance
[/code]
  • Ringardy
  • Ringardy
23 Oct 2025 18:20
So how would i have to set the jumper to be correct.
Havent yet figured out how there ment to be set
  • PCW
  • PCW's Avatar
23 Oct 2025 18:17
You have the IP address jumpers set to 192.168.1.121 mode (down/down)
rather than EEPROM mode (down,up)
  • Ringardy
  • Ringardy
23 Oct 2025 18:13
Mesa 7i95T not responding was created by Ringardy
Fist up im brand new to this topic with linuxcnc.So i have bought a 7i95T FPGA Card and now i have the problem that i cant ping it or even read the config.The networkmanager says its connected to a ethernet Network, it recognices when its being disconected and connected.Ethernet Port on the card does blink from time to time (the way it does when sending and reciveing signals).When the card is being powerd on the DONE and INIT lights light up shortly once and the USER LEDS cycle as well.PWR is light up orange.No jumpers have been moved and it only has been connected to that ones pc´s ethernet port.
Searched everywhere to find an answer but no luck.
  • PCW
  • PCW's Avatar
23 Oct 2025 18:12
RS-422 Linear Magnetic Encoder shows ERROR LED after power-on (Mesa 7i76 + 7i85)
Category: Driver Boards
Maybe the scales cannot drive the RS-422 termination on the 7I76/7I85
or perhaps the 5V is marginal (check at encoder end of cable)
  • unknown
  • unknown
23 Oct 2025 18:07
Proposal RPi Linuxcnc Image Based on Raspi OS All welcome/encoraged to comment
Category: Installing LinuxCNC
Image version Twenty Three gazillion.
Standard raspios desktops included plus XFCE, changed lightdm chooser to the gtk-greeter, auto login is enabled, easiest way to change desktop environment is to logout and select the desktop prior to logging in. Still working with Bookworm ATM. Needs a little polishing, need to add the environment variable for realtime, will include a config for XFCE terminal that had a few options setup. And yes I will keep Midnight commander in there, great clone of the old Norton commander dos file manager, the included editor is pretty good as well.
  • unknown
  • unknown
23 Oct 2025 17:56
Replied by unknown on topic 7i92H
7i92H
Mesa have a product called spinx or similar, converts digital pwm to isolated analogue out.
The new image I'm working is created using the same utility that Raspberry Pi company uses to create their own images, so basically raspios with a real time kernel and Linuxcnc pre installed. Far more raspios than the previous.
Displaying 8251 - 8265 out of 16960 results.
Time to create page: 0.679 seconds
