  • JT
  • JT's Avatar
15 Oct 2025 11:47
Glade Hal Meter Spindle Speed -> postgui
Category: GladeVCP
In your hal file you have
net spindle-vel-cmd-rpm        <=  spindle.0.speed-out
So the signal spindle-vel-cmd-rpm can be connected to your rpm meter or you can comment out the line that pncconf made.
JT
  • jmp97
  • jmp97
15 Oct 2025 11:37
Replied by jmp97 on topic LinuxCNC installation + 7I96S
Category: Installing LinuxCNC
--- 192.168.1.121 ping stadistics ---
60000 packets transmitted, 60000 received, 0% packet loss, time 59998ms
rtt min/avg/max/mdev = 0.046/0.057/0.157/0.000 ms
I don't think it's a connection or latency problem.
  • cmorley
  • cmorley
15 Oct 2025 11:26
Replied by cmorley on topic Glade Hal Meter Spindle Speed -> postgui
Category: GladeVCP
An output pin can only be connected to one signal, but a signal can be connected to many input pins.
You didn;t post your postgui file so can't see the actual problem to comment more.
  • cmorley
  • cmorley
15 Oct 2025 11:19
Replied by cmorley on topic Zero the DRO
Zero the DRO
Category: GladeVCP
Have you set this in the TRAJ section of the INI?
NO_FORCE_HOMING = 1
linuxcnc.org/docs/devel/html/config/ini-...tml#sub:ini:sec:traj
Then you should be able to use the normal way to zero the axis.
But you lose the safety pf soft limits with no fixed homing spot.
  • cmorley
  • cmorley
15 Oct 2025 11:12
Replied by cmorley on topic WCS Problem with Linuxcnc/qtdragon
Does t3 have x or y offsets in the tool page?
  • Bram kersten
  • Bram kersten
15 Oct 2025 11:02
Replied by Bram kersten on topic WCS Problem with Linuxcnc/qtdragon
Because we had problems with mach4 and our hardware wasn't compatible with linuxcnc.
and oops i see i frogot to f11 in my picture but there isn't that much more info only the status bar. but maybe you can see someting extra, im very new to linuxcnc/qtdragon so to me everything looks normal.
i added a picture with the fullcreen gui
  • ffffrf
  • ffffrf
15 Oct 2025 10:26
what is the absolute easiest way to hook up pendant to 7i96s cnc setup?
Category: CNC Machines
Hey everyone - I have a modified taig that i am running with linuxcnc using a mesa 7i96s and a dell optiplex 7010 (i think). I am wondering what you all think is the easiest way to hook up a pendant? The only thing I care about is being able to jog the axis. I have been looking online and there seems to be so many ways to do it like daighter cards, different ifirmware, parallel ports in pci slot, but do any of you have experience on whats the most simple setup with purchasing a common pendant online?
  • Todd Zuercher
  • Todd Zuercher's Avatar
15 Oct 2025 09:55
Replied by Todd Zuercher on topic Zero the DRO
Zero the DRO
Category: GladeVCP
Use an mdi command to issue the appropriate G10 command.
  • Hakan
  • Hakan
15 Oct 2025 09:47
Replied by Hakan on topic Ohmic sensing with IPTM-60
Category: Show Your Stuff
And here are voltages on a wet table.
Ok, little bit more intriguing than I first thought.
Not much of a dip there.
How to detect that? There are ways of course.
  • RecividstOfndr
  • RecividstOfndr's Avatar
15 Oct 2025 08:47
Favourites page was created by RecividstOfndr
Favourites page
Category: Forum Questions
Hi all, I marked a forum topic so as to be able to come back and read further and the pop up said it was 'saved to my favourites' . Alas I can find no such page anywhere. I would have thought it would be somewhere in my profile page?
  • sin-do-re
  • sin-do-re
15 Oct 2025 08:28
THC qtplasmac 2.9 is moving UP when it should be moving DOWN
Hello
I'm having a weird Qtplasmac 2.9.238.315 bug where my torch goes down when it should be going up - but only during THC corrections.
Normal Z axis movement is OK as it should, with homing, probing, etc.
THC is being used from voltage (THCAD-2) and arc OK signal is present.
I tried reversing the Voltage Scale (from 0.009 to -0.009) and no changes. - it still is correcting in the reverse way. how weird is it!
Where could i start?
Thanks everyone
  • DerKlotz
  • DerKlotz
15 Oct 2025 08:13
Replied by DerKlotz on topic Glade Hal Meter Spindle Speed -> postgui
Category: GladeVCP
net Spindelrpm => gladevcp.Spindel
Got that... i just created the signal.name Spindel.rpm which is linked to gladevcp.Spindel.
There is still my problem where to get the float.out(?) from and link it to Spindel.rpm. My "favorite" spindle.0.speed-out is already linked -> Error "custom_postgui.hal:9: Pin 'spindle.0.speed-out' was already linked to signal 'spindle.0.speed-out'"
Sorry... German beginner
15 Oct 2025 06:03
Replied by tommylight on topic LinuxCNC v2.9.6 Released
Category: LinuxCNC Announcements
Shortly after the release of 2.9.5 it was
noticed that a fix for a graphics bug in Gmoccapy had resulted in the
Axis touch-off dialog box no-longer working for non-zero entries.
I've been refraining from commenting on this till now, but i have to, i would absolutely prohibit changing anything that affects Axis GUI in any way, shape or form, from other GUI's or anything else.
Axis is and should remain bullet proof, that is the main reason i use it on all my machines (over 40 by now).
Destroying basic functionality on Axis to fix something already broken in GmoccaPy is plain absurdity.
I can absolutely understand if it was a mistake, but from a bit of reading it does not seem to.
I really hope i am wrong...
  • Hakan
  • Hakan
15 Oct 2025 05:38
Recorded the voltage between tip and work piece during some 5 minutes. Was cutting a bunch of small holes.
They all look like this one, with some variation.
This was on a dry work piece. There is a clear voltage drop, somewhat slow, delayed recovery.
Triggered contact condition was a one-cycle voltage drop of 5 Volts.
  • unknown
  • unknown
15 Oct 2025 05:12 - 15 Oct 2025 22:50
fixing "raspi firmware" errors on the official amd64 ISO
Quick Update.
Using "Trixie" branch from here; salsa.debian.org/live-team/live-build/-/...rixie?ref_type=heads
I built a live-build package on a machine running Bookworm from the above repo. Installed the built package and was able to successfully build a Linuxcnc ISO without the raspi-firmware. As noted above hostmot2 firmwares are installed, a test run of Axis with the default gcode produced no errors, apart from latency due to being run in a virtual machine.
Building live-build packages from the above sources also works for building ISO on Linux Mint 22.1 Xia.
The goal would be to pin Linuxcnc to 2.9.4 during the ISO creation, as there seems to be a few issues reported by users with either the 2.9.5 or 2.9.6 branch.
Displaying 8701 - 8715 out of 16967 results.
Time to create page: 0.590 seconds
