  • N3pu
  • N3pu
06 Oct 2025 18:02
Probescreen versa v1 Problem with XYZ Auto-Zero Gmoccapy LinuxCNC 2.9.1
Thanks for confirming it´s a bit strange :)
I´ve now tried again the newer probescreen v.2.9 where I didn´t connect the toolchange pins (this was the initial reason for using the older screen v1). It seems to gerneral work, too. But with a strange behavior like in v1.
Probing in Z seems to work fine. When I touch Probing from X-, Y- the machine starts moving in X+ direction until it prompts "finished without probing..". It should move in X- first, Z down, and then X+ for touching.. Crazy behavior.
In my case it starts directly moving X+ without moving Z..
I allready checkt the macro files. everything seems to be okay. any idea how to debug it?
  • N3pu
  • N3pu
06 Oct 2025 17:52
Replied by N3pu on topic door signal implementation
i have something similar implemented in my machine.
I have door closed signal, door locking signal (combined door sensor and locker). When TC is requested door is free of lock. When door is opened in manual mode when spindel is running. spindel stops.
Attached you´ll find my hall (linux cnc 2.9.1). Search for door in the hal file (should be at the end). Hope you can recycle something..
  • juergen-home
  • juergen-home
06 Oct 2025 17:51
toggle2nist hangs when pressing an other button at the same time
Category: HAL
Many thanks.
I compiled in your magic code in. With a puls-lenght of 50 my problems seem to be gone. This should become the standard toggle2nist.
Many thanks!
  • MatthiasCNC
  • MatthiasCNC
06 Oct 2025 17:47 - 06 Oct 2025 17:47
Replied by MatthiasCNC on topic CiA 402 in 1.15.0
CiA 402 in 1.15.0
Category: EtherCAT
Thanks.
Yes, I switched to the generic driver. After studying the nearly 1000 pages of documentation, I didn't see any advantages :-).
I can configure the converter very well directly.
The tip helped me. I had to remove “name=‘D1’” and add “configPdos=”true".
You have to pay attention to upper and lower case here.
<slave idx="0" type="generic" vid="0x0000001d" pid="0x007b1a95" configPdos="true">
Then there were a few minor things in the ini and hal files. Now my bus is running.
Now I just have to take care of the units.
  • Aciera
  • Aciera's Avatar
06 Oct 2025 17:03
Axis configuration not fully working on 2.9.6
Category: AXIS
I've just built the current 2.9 branch (ie 2.9.6) and tested "halui.machine.is-on" reacting to "halui.machine.on" and "halui.machine.is-off", works for me in both tested guis (axis, gmoccapy)
  • MusicCityMfg
  • MusicCityMfg's Avatar
06 Oct 2025 16:21
Replied by MusicCityMfg on topic LinuxCNC Lathe Retrofit ... Where Do I begin?
Category: Turning
Thanks! I saw your post and started reading it. There's a lot there.
Were you able to replace the resolvers with encoders? Are they part of the motors?
I ask because I found a video of some guy who did a Nakamura LinuxCNC retrofit and he opened up the Fanuc spindle motor and replaced the Fanuc encoder with one he bought off of Alibaba. He had to machine a custom mount for the encoder.
I don't know if the resolver process is similar or if I have to buy all new servos.
  • Aciera
  • Aciera's Avatar
06 Oct 2025 15:43
Replied by Aciera on topic Pin does not exist
Pin does not exist
Category: ClassicLadder
can you please show us the parameters you used?
'loadrt classicladder_rt .....'
  • Aciera
  • Aciera's Avatar
06 Oct 2025 15:41
Category: AXIS
If you open one of the sim configs and check "halui.machine.is-on" does it go true when you enable the machine with the gui button?
  • wusel0464
  • wusel0464
06 Oct 2025 15:11 - 06 Oct 2025 15:30
Replied by wusel0464 on topic Change camera resolution Qtdragon?
Category: Qtvcp
Hello,
Thank you for your effort and patience.
I didn't expect it to be so easy either.
I searched the code on the net to try whether it could work with the camera before I gave any nonsense.
I just let the whole thing run in studio code.
Since I hardly have any idea from programming, I was glad to have something to run at all.
My thought was that you could do something like that in the scaling function and to simply make it handlebar via the qtdragon.pref.
What Qtdragon shows, I noticed when comparing the image with other programs and even if you use the zoom function, the image becomes pixelated very quickly.
Various Linux tools first read only 640x480 as a kind of standard.
v4L2-ctl --list format-ext shows the following resolutions:
640x480
352x288
320x240
176x144
160x120
800x600
1280x960
1600x1200
When I start GuvcView, the camera is first displayed 640x480, it can then select and the image quality changes.
Small addendum, you can see it even better:
Qtvcp -d -o Cam number = 14 cam_align
Two cameras are just connected here:
Port 1 Andostar
[QTvcp.QTVCP.WIDGETS.CAMVIEW_WIDGET][DEBUG]  Port 1 is working and reads images (480.0 x 640.0) (camview_widget.py:520)
Port3 webcam
[QTvcp.QTVCP.WIDGETS.CAMVIEW_WIDGET][DEBUG]  Port 3 is working and reads images (480.0 x 640.0) (camview_widget.py:520)
Thank you for your efforts and all the best, Frank.
  • Tchefter
  • Tchefter's Avatar
06 Oct 2025 15:04
Replied by Tchefter on topic Tipps für aktuelle LinuxCNC Hardware gesucht
Category: Deutsch
Servus Bernhard,
hier im cnc-aus-holz.at  Forum gibt es den Olli aka meister23
Er hat einiges ans Rasp Sachen gemacht. Evtl. hilft dir das weiter.
Good Luck,
Gruß Fritz
  • PCW
  • PCW's Avatar
06 Oct 2025 14:17
Replied by PCW on topic 5i25t firmware screwup
Category: Driver Boards
Does the 7I77 have field power?
  • jschulze
  • jschulze
06 Oct 2025 14:10
Replied by jschulze on topic LinuxCNC Lathe Retrofit ... Where Do I begin?
Category: Turning
Here's a guy that did a QT8 retrofit.  Could try reaching out to him to see what was involved. I'd try to find out what issues the lathe has and plan from there.  From a very quick look it looks like the servos have resolvers, so you'll have to plan for that with your choice of controlled cards or plan on replacing the servos and drives with something more modern with encoders.
  • Gartenzwerg
  • Gartenzwerg
06 Oct 2025 13:36
Category: Deutsch
Hallo zusammen!
Ich heiße Bernhard, bin Mitte 40 und komme aus dem Osten Österreichs.
Beruflich bin ich in der IT unterwegs, und habe auch etwas Erfahrung mit Linux.
Daher war das ausstatten meiner vor 5 Jahren angeschafften kleinen CNC Fräse (Mutronic Diadrive) mit LinuxCNC logisch, und das funktionierte auch im großen und ganzen sehr gut.
Die letzten 5 Jahre lief ein PC mit einem ASUS Mainboard aus 2005, an dessen Parallel-Port direkt die Fräse hing.
Wie zu erwarten, macht das natürlich irgendwann Probleme. Im Moment wird die Festplatte (SSD) nicht mehr erkannt.
Ich krieg das grundsätzlich zwar sicher wieder hin, aber möchte das eigentlich gleich nutzen um auf aktuelle Hardware umzusteigen.
PCs mit Parallel-Port zu finden die dann auch akzeptabel funktionieren dürfte eher die Nadel im Heuhaufen sein.
Alles was mir so in den letzten Jahren vor die Füße gefallen ist, hat im Latency Test grausam abgeschnitten.
Daher meine Frage an die Wissenden:
Was nehme ich 2025 für Hardware, um eine Fräse anzusteuern die einen Parallel-Port Eingang hat.
Ich lese was von Raspberry Pi, Mesa Karten, ..., blicke aber ehrlich gesagt nicht durch wie das alles zusammenspielt.
Eine Raspberry Lösung fände ich sehr sexy, aber was nehme ich dann als Umsetzer zur Fräse?
Habt ihr eventuell Links zu funktionierenden und dokumentierten Setups, oder Tipps in welche Richtung ich mich weiter schlau machen sollte?
hilfesuchende Grüße,
Bernhard
  • ckuecker
  • ckuecker
06 Oct 2025 13:19
Replied by ckuecker on topic EasyProbe buttons not moving axes
Apparently, it is waiting for me to complete an M6 tool change, which is not set up in my hal file. I'll keep digging.
Displaying 9181 - 9195 out of 16972 results.
Time to create page: 0.272 seconds
