  • PCW
  • PCW's Avatar
13 Sep 2025 13:58 - 13 Sep 2025 14:08
Replied by PCW on topic Glasmaßstab EIA-422 an Mesa 7i85 (S)
Category: Deutsch
Actually you can:
setp  hm2_7192.0.encoder.00.index-enable true
As long as hm2_7192.0.encoder.00.index-enable is not connected to
a signal in the hal fiie. It will be set true once at LinuxCNC startup.
The error you have is that you did not comment out the net command connecting
hm2_7192.0.encoder.00.index-enable to the signal x-index-enable:
# ---Indexsignal GMS fuer Referenzpunkt X (NICHT MIT NORMALEM ENDSCHALTER)
net x-pos-fb  <=  hm2_7i92.0.encoder.00.position
net x-vel-fb  <=  hm2_7i92.0.encoder.00.velocity
net x-pos-fb  =>  joint.0.motor-pos-fb
net x-index-enable  joint.0.index-enable  <=>  hm2_7i92.0.encoder.00.index-enable
net x-pos-rawcounts  <=  hm2_7i92.0.encoder.00.rawcounts
But for testing it's better to do this in halshow
Note that while you cannot change hm2_7192.0.encoder.00.index-enable
in halshow (or the hal file) if it's connected to a signal, you can
change the signal ( x-index-enable) in halshow for testing.
  • unknown
  • unknown
13 Sep 2025 13:49
  • Martin.L
  • Martin.L
13 Sep 2025 13:23
Replied by Martin.L on topic Probe Basic ATC Setup Problems
Category: QtPyVCP
I reply into this because I had the same problem and solved it (thanks to Crish as always for the help) you probably are not calling tool prepared, or something iocontrol.x.tool related that "hangs" the toolchange
In my case was something like calling M64P7 with:
net ATC-pocket-reached motion.digital-out-07 iocontrol.0.tool-prepared
  • ccc774
  • ccc774
13 Sep 2025 13:21
Replied by ccc774 on topic Can the OPI5 be Configured to Run LCNC?
I got Linuxcnc to start, thanks for the guidance.
Regarding 3D acceleration, it's clearly something in the kernel that I can't get it to work.
I also made an overlay to block mali at startup and load Panfrost. It loaded but with an error.
~$ sudo modprobe panfrost
dmesg | tail -20 | grep -i "panfrost\|drm"
[   60.606789] panfrost: unknown parameter 'enable_mmu' ignored
~$ XDG_RUNTIME_DIR=/tmp glxinfo -B | grep "OpenGL renderer"
OpenGL renderer string: llvmpipe (LLVM 19.1.7, 128 bits)
I made the system with: Armbian_25.8.1_Orangepi5_trixie_vendor_6.1.115_minimal.img. After that I installed Cinnamon. I have Mesa 25.0.7-2 installed.
  • Jmp97
  • Jmp97's Avatar
13 Sep 2025 12:44
5-axis CNC recommendation was created by Jmp97
Hello, everyone.  I'm new to this. I'm from Spain, and I can hardly find any information about LinuxCNC for 5-axis machining centres. Let me explain. I have a robust 3-axis desktop CNC, running on Arduino + CNCShield. I am designing and building a table to add A/B axes and make it 5-axis. What controller board do you recommend for using LinuxCNC? My knowledge is limited. The drivers for my motors with encoders have Step/Dir. If there is a post from someone who has built a 5-axis CNC using LinuxCNC, I would appreciate it. Thank you.
  • wrecks
  • wrecks
13 Sep 2025 12:15
Replied by wrecks on topic I'm missing something about Glade
Category: GladeVCP
I solved this problem. When I installed from the .iso, the drives for the computer wifi were not available, so I installed without an internet connection. This evidently creates a system that only mostly works. The apt app was broken. I connected to the the internet with a cable and re-installed the .iso. Now, I've been able to do sudo apt install glade without issue.
  • Hakan
  • Hakan
13 Sep 2025 12:13 - 13 Sep 2025 12:13
Replied by Hakan on topic Glasmaßstab EIA-422 an Mesa 7i85 (S)
Category: Deutsch
We would like to see the error you get.
Nevertheless, I happen to know why. It's because index-enable is an IO pin, it's both input and output, a bit special.
So you can not set it to true, only connect it to a pin that is IO both input and output. Such as joint..index-enable
Relevant links www.linuxcnc.org/docs/html/drivers/hostmot2.html#_pins_5
linuxcnc.org/docs/html/man/man9/motion.9.html#JOINT%20PINS
  • WKS-3D
  • WKS-3D's Avatar
13 Sep 2025 12:03
Replied by WKS-3D on topic Glasmaßstab EIA-422 an Mesa 7i85 (S)
Category: Deutsch
Sind noch alle im Urlaub?
So ruhig geworden hier
  • amanker
  • amanker
13 Sep 2025 07:37 - 13 Sep 2025 09:31
I changed according to your suggestion. But same issue "joint follwing error"
I am not seeing any mismatch of imperial vs metric units. I think I have defined only mm.
Yes I have set jumpers correctly. I tried flashing grblhal.. everything was working. So its not related to hardware or jumpers
  • Bruno
  • Bruno
13 Sep 2025 07:37 - 13 Sep 2025 15:59
Replied by Bruno on topic Mostly 3D Printed CNC Foam cutter
Category: CNC Machines
Do you need it to cut 4 axis or just 2 axis?
  • mal136
  • mal136
13 Sep 2025 06:17
Replied by mal136 on topic Plasmac Post Processors
Category: Plasmac
IInteresting—I used the Fusion360 post processor from the first page of this thread (forum.linuxcnc.org/plasmac/38438-plasmac...t-processors?start=0). After rereading the PDF, it doesn’t explicitly say so, but I think I need to create separate 2D profiles for each feature I’m cutting. Since the post processor doesn’t generate Z movements, would that mean making individual profiles for all 12+ holes plus the part outline? and i assume plasmaC will control Z when it goes to probe for each cut?  I also tried Inkscape (which I like), but it skips certain splines and rounded corners in my parts. Redesigning everything just to fit Inkscape’s gcode output would be counterproductive.
Thank you so much Tommylight for your reply, i greatly appreciate your help!
  • Rookie0
  • Rookie0
13 Sep 2025 05:24
Replied by Rookie0 on topic How to use "FIXED PDO Mapping" on LinuxCNC
Category: EtherCAT
I don't understand what you mean.
Perhaps you should directly describe the actual problem you are facing.
  • tar_san
  • tar_san
13 Sep 2025 01:56
Category: EtherCAT
Hi, guys.
Does anyone know how to write FIXED PDO MAPPING in "ethercat-conf.xml"?
  • Lcvette
  • Lcvette's Avatar
13 Sep 2025 00:52
Probing routines changing mode from G90 to G91
Category: QtPyVCP
You can use M70-M73 for this type situation normally, but they require a return or ending call to be activated. the issue is that a probe abort does not allow any further interpreter action. It's an absolute stop of the que on the G38.x line which also leaves the subroutines in a hung state. I tried finding a work around a few years ago, but I couldn't sort out how to go about it.
My guess is something in lcnc would need to be added to error output maybe?
  • tar_san
  • tar_san
13 Sep 2025 00:51
Replied by tar_san on topic Problems with Lichuan Ethercat servo drive
Category: EtherCAT
I'm sorry to be late to publish my codes.
This is my repository for it.
github.com/k-s-saki/LinuxCNC_EtherCAT/tr...in/Lichuan/LC10E-INC
Displaying 9961 - 9975 out of 17027 results.
Time to create page: 0.443 seconds
