  • zmrdko
  • zmrdko's Avatar
23 Jun 2025 05:00
Replied by zmrdko on topic Do I need a better PC?
Category: EtherCAT
can you share your full config?
  • zmrdko
  • zmrdko's Avatar
23 Jun 2025 04:52 - 23 Jun 2025 05:00
  • Kieran
  • Kieran
23 Jun 2025 03:57
Replied by Kieran on topic Do I need a better PC?
Category: EtherCAT
youtube.com/shorts/vI0LGnGjhmI?si=QLHawiX2xE67YjWh
youtube.com/shorts/FzLijBCwhX8?si=wHB4NtbOI7QP0iu-
Here's 2 clips, one "gravel mode" and one right after restarting linuxcnc running smooth.
  • unknown
  • unknown
23 Jun 2025 03:25
Replied by unknown on topic How to design new driver for my own board
Category: Driver Boards
Basically you can make an FPGA design that uses a Spartan 6 and use the mesa hostmot2 firmware. No need to develop fpga code or write a new driver.
Here's an example
github.com/ozzyrob/Linuxcnc-FPGA
  • behai
  • behai
23 Jun 2025 03:06
Please help -- Mesa 7I96S 24VDC Contactor Wiring
That is correct.
Thank you PCW.
Best regards,
...behai.
  • Kieran
  • Kieran
23 Jun 2025 02:58
Category: EtherCAT
my servo latency was 178,165 base was 79,029
now its around 72000 and is working without alarming my servos.
  • PCW
  • PCW's Avatar
23 Jun 2025 02:11
  • Kieran
  • Kieran
23 Jun 2025 02:04
Category: EtherCAT
interesting. Im playing with the servos now. Today im getting an error code ErC1.1 Synchronization loss on all 5 drives. and ErC2.0 SYNC signal loss on some drives sometimes. I will power cycle PC and see what happens. my 3 axis config seems ok.
  • behai
  • behai
23 Jun 2025 02:00
Please help with how to wire a 24VDC contactor to the Mesa 7I96S to switch on a wood router from LinuxCNC.
I would like to switch a wood router from LinuxCNC. I have the below 24VDC contactor and flyback diode:
- Contactor: www.tropac.com.au/10-Pole-24VDC-Coil-5.5...Contactor-LS-Metasol
- Flyback diode: www.jaycar.com.au/diode-fr307-1000v-3a-d027-pack-10/p/ZR1052
I've learned how contactor works. I have wired and able to switch on a Dremel grinder via this contactor.
I think this is how I should wire it:
Is it correct, please?
Thank you and best regards,
...behai.
  • TheTinkeringMechanic1
23 Jun 2025 00:55
Replied by TheTinkeringMechanic1 on topic Spindle speed?
Spindle speed?
Category: Basic Configuration
Hectic weekend...
  • Yaroslav
  • Yaroslav
23 Jun 2025 00:01
Mesa 7i95T spindle step/Direction setup using stepgen
Hello. I have a lathe with a spindle on a servo motor and step/dir control and feedback via the encoder of the same drive on 7i96s. Everything works well. I also have an unfinished project on 7i97, where the spindle still works in an analog way. Step/dir is also planned. I can send the working files of the lathe.
  • PCW
  • PCW's Avatar
22 Jun 2025 23:22
Modbus connection issue mesa 7i76eu pktUART
You cannot use the standard release as they are only updated about once a year.
For a binary update, you need to use the image built by the LinuxCNC buildbot:
buildbot.linuxcnc.org/
(The page is a bit old as 2.10 is the current LinuxCNC master version and 2.9
is the current release version)
 The other option is to build from source:
www.linuxcnc.org/docs/devel/html/code/building-linuxcnc.html
  • meister
  • meister
22 Jun 2025 23:19
Replied by meister on topic How to design new driver for my own board
Comp-Style:
github.com/jzolee/HAL2UDP/blob/2.0/LinuxCNC%20driver/udp.comp
pure C/C++
github.com/scottalford75/Remora-NVEM/blo...emora-nv/remora-nv.c
what FPGA you want to use ? Verilog, VHDL, nmigem ,... ?
Open Source or closed ?
  • AdelRTP
  • AdelRTP
22 Jun 2025 22:20
Replied by AdelRTP on topic Modbus connection issue mesa 7i76eu pktUART
Ther is no 2.10, where can i find it and i download the 2.9 now, and same problem help please
  • vitali
  • vitali
22 Jun 2025 21:58
Hi.
I am new in Linuxcnc. I am going to design my own board use FPGA. I do not know how to make driver. I have experience in c c++. May be somebody knows how to do it, or where i can take any sample driver or any information.
Displaying 1036 - 1050 out of 25181 results.
Time to create page: 0.226 seconds
