  • PCW
  • PCW's Avatar
27 Nov 2024 17:20
Replied by PCW on topic Frage wegen Spindelencoder an 7i76
Category: Deutsch
For testing the individual inputs, setting them to single ended mode
allows you to test each signal by simply grounding the A+,B+,IDX+
inputs
  • WKS-3D
  • WKS-3D's Avatar
27 Nov 2024 17:10 - 27 Nov 2024 17:11
Replied by WKS-3D on topic Frage wegen Spindelencoder an 7i76
Category: Deutsch
if you jumper the 7I76 for TTL/single ended mode,
you can test each input by simply grounding each
encoder+ input (TB3 pins 7,10,13 = A,B,IDX) and
watching them in halshow.
W4, W5, W6 are in the right hand position. Mode is differential.
  • Zubrze
  • Zubrze
27 Nov 2024 17:05
Rotary axis in Qtdragon_hd was created by Zubrze
Category: Qtvcp
Hi, I am playing with qtdragon_hd and cannot seem to get a fourth rotary axis (XYZB) working in the preview in the way I would like. At the moment, in the simulation samples in the latest 2.9.3 release such as "qtdravon_hd_xyza", the rotary A-axis rotates the spindle. But in my setup, I want to rotate the stock. I've tried changing the "trivkins" in the INI file to other options, but then the machine doesn't even turn on for some reason! Does anyone have a working example they could share where the stock rotates rather than the spindle? Thanks!
  • PCW
  • PCW's Avatar
27 Nov 2024 17:03
Category: Deutsch
  • WKS-3D
  • WKS-3D's Avatar
27 Nov 2024 16:59
Category: Deutsch
Are the glass scales differential out or single ended?
The 7I76 encoder input needs to be jumpered to match the encoder type
Output Signal: EIA-422
The glas scales works fine, no problems on 7i85
  • Aciera
  • Aciera's Avatar
27 Nov 2024 16:43
Replied by Aciera on topic Original Gmoccopy setting all gone
Not sure but what you can do is this:
1. Open you config the way you are used to.
2. Close linuxcnc
3. open terminal and run (note the minus + letter 'L' which should automatically open the last config you used):
linuxcnc -l
  • Stanislavz
  • Stanislavz
27 Nov 2024 16:36
Replied by Stanislavz on topic LinuxCNC on Linux Mint Debian Edition 6
Category: Installing LinuxCNC
Hmm. Could some one point me how to configue dual corexy ? For each side separate axis.
  • shanham67
  • shanham67
27 Nov 2024 16:32
Plasma and Ethercat? was created by shanham67
Category: Plasma & Laser
Hey Guys,
I have retrofitted a lathe and two Bridgeport Interact Mills using Mesa 7i76e's.  I am happy with the 7i76e and pncconf but due to their availability (or lack thereof) I am considering doing my new 'from-scratch' plasma table build using an Ethercat interface.
My question is this: If I go down the Ethercat path will I be able to re-use all of the good work that has been done in the plasma area or will I be doing custom builds?  More specifically can I set up a plasma system using Ethercat by modifying .ini and .cfg files?  I am willing to recompile some fork of the main line of development but I don't really want to be on the 'bleeding edge' of the development effort.
Thanks in advance and Happy Thanksgiving!
JH
  • PCW
  • PCW's Avatar
27 Nov 2024 16:24
Category: Deutsch
  • Aciera
  • Aciera's Avatar
27 Nov 2024 16:03
Replied by Aciera on topic Frage wegen Spindelencoder an 7i76
Category: Deutsch
Kann ich damit auch was anfangen, ich brauche es nur für Gewindedrehen und vielleicht noch für den Vorschub beim Drehen, wäre praktischer als mit mm/min.
Nur ein Indexsignal wird leider nicht reichen.
  • raychar
  • raychar
27 Nov 2024 15:52
Replied by raychar on topic Original Gmoccopy setting all gone
Since you seem to be loading some custom panels you may have a Python/Gtk version issue. Linuxcnc version 2.9 and up no longer supports Python2 /Gtk2 but only Python3/Gtk3.
I would suggest to open a terminal (Ctrl + Alt + t) and start linuxcnc from the comand line:
linuxcnc
Choose your config and check the terminal output for errors.
Then, the Linux CNC Configuration Selector appears, on the left hand side, when I click all the showed ini files, the right hand side shows "No details available". Obviously, it didn't refer to mine one ? The path location of my ini. and other files are : /home/my_user_name/linuxcnc/config/my_LinuxCNC_machine. Are there something wrong?
  • WKS-3D
  • WKS-3D's Avatar
27 Nov 2024 15:51
Category: Deutsch
Can you try all encoder inputs with with one glass scale output?
Note that encoders are:
00  7I85 ENC0
01  7I85 ENC1
02  7I85 ENC2
03  7I85 ENC3
04  7I76 ENC
05  Aliased 7I76 (dont use)
Also you can debug with just a voltmeter across the A,/A B,/B pins
you can also check the input pins with halshow:
hm2_7i92.0.encoder.00.input-a
hm2_7i92.0.encoder.00.input-b
hm2_7i92.0.encoder.01.input-a
hm2_7i92.0.encoder.01.input-b
etc
I have now simply plugged the connector from the glass scale X (00 7I85 ENC0) into the encoder input of the 7i96 (04). When the X-axis moves, the yellow LED at A changes constantly between on and off, B remains on, Count changes between 0 and -1 during the movement, Velocity shows a value from time to time during the movement. I did not change anything on the HAL for the test.
Measured with the voltmeter at the outputs of the spindle encoder, there is no value, so A+ is measured with A- etc.
all this in the unplugged state. When the plug is plugged into the 7i76, I have values of 228 ohms.
  • raychar
  • raychar
27 Nov 2024 15:09
I think I did the stupid thing that I copied old LinuxCNC startup icon from the old computer screen and paste to new one, I haven't create a new one instead. Let me check all the things first
27 Nov 2024 14:58
Asrock Q1900M: Unexpected Realtime Delay, but Good Latency Values
Did you try from terminal? Is there any useful info there?
  • PCW
  • PCW's Avatar
27 Nov 2024 14:58
Category: Deutsch
00  7I85 ENC0
01  7I85 ENC1
02  7I85 ENC2
03  7I85 ENC3
04  7I76 ENC
etc
Displaying 17326 - 17340 out of 24053 results.
Time to create page: 0.564 seconds
