20 Nov 2024 20:44
Replied by tommylight on topic System homes but unresponsive
Category: Installing LinuxCNC
Does it have any spindle feedback?
Is the spindle.at-speed set to true?
Use the "show hal configuration" from the "machine" menu to watch the pins.
  • floris
  • floris
20 Nov 2024 20:40
Best version for Parport machine and how to install
Thanks! You're a legend. Got it to work and the jitter dropped to about 12000ns.
I've tried to edit the grub file so it loads the RTAI kernel by default as a quality of life improvement. Unfortunitely, editing GRUB_DEFAULT didn't work because the kernal options are in the "advanced options" menu. I'd love to know how to get the system to boot using the RTAI kernal without having to intercept the GRUB menu every time.
  • robocidalmaniac
  • robocidalmaniac's Avatar
20 Nov 2024 20:39
Replied by robocidalmaniac on topic scorbot-er-3
scorbot-er-3
If it helps here is the User Manual for the Logitech Dual Action F310 Controller
20 Nov 2024 20:37
Installing LinuxCNC on Ubuntu 24.04 LTS is not possible.
sudo apt update
sudo apt install linuxcnc-uspace
No idea if it works on Ubuntu 24 but it did on 22 or 23.
The above also works on Linux Mint Debian Edition 6, should also work on Debian 13.
20 Nov 2024 20:34
How to configure pause/resume over pin 10 of parallel port?
Category: HAL
Leave them in breaks cleaning fluid for a night, should unclog... hopefully
Use an LED and a resistor on a parallel port pin and gnd, look at them turning on and off while joging in LinuxCNC.
  • robocidalmaniac
20 Nov 2024 20:28
scorbot-er-3
To get the Logitech Dual Action F310 controller to work as a Pendant for the Scorbot-ER-3 using LinuxCNC 2.9.2, after making previous changes mentioned earlier in this forum, do the following:
Open the "scorbot-er-3.hal" file in the /linuxcnc/configs/by_machine.scorbot-er-3/ folder and add these 2 lines (after the "loadrt differential" line);
loadusr -W hal_input -KRAL Logitech
loadrt mux16 names=jogspeed
then add (after the "addf differential.0 servo-thread" line):
addf jogspeed servo-thread
save and close the file.
next open the pyvcp.hal file and add the following (at the bottom):
# connect miscellaneous signals
# ---HALUI signals---
net axis-select-x halui.axis.x.select
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-y halui.axis.y.select
net jog-y-pos halui.axis.y.plus
net jog-y-neg halui.axis.y.minus
net jog-y-analog halui.axis.y.analog
net y-is-homed halui.joint.1.is-homed
net axis-select-z halui.axis.z.select
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.2.is-homed
net axis-select-a halui.axis.a.select
net jog-a-pos halui.axis.a.plus
net jog-a-neg halui.axis.a.minus
net jog-a-analog halui.axis.a.analog
net a-is-homed halui.joint.3.is-homed
net axis-select-b halui.axis.b.select
net jog-b-pos halui.axis.b.plus
net jog-b-neg halui.axis.b.minus
net jog-b-analog halui.axis.b.analog
net b-is-homed halui.joint.4.is-homed
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
net spindle-manual-cw halui.spindle.0.forward
net spindle-manual-ccw halui.spindle.0.reverse
net spindle-manual-stop halui.spindle.0.stop
net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
# ---USB device jog button signals---
# connect selectable mpg jog speeds
net jog-speed-a => jogspeed.sel0
net jog-speed-b => jogspeed.sel1
net jog-speed <= jogspeed.out-f
setp jogspeed.in00 150.000000
setp jogspeed.in01 300.000000
setp jogspeed.in02 600.000000
setp jogspeed.in03 1200.000000
net jog-speed-a <= input.0.btn-base
net jog-speed-b <= input.0.btn-base2
net jog-x-pos input.0.abs-hat0x-is-pos
net jog-x-neg input.0.abs-hat0x-is-neg
net jog-y-pos input.0.abs-hat0y-is-neg
net jog-y-neg input.0.abs-hat0y-is-pos
net jog-z-pos input.0.abs-rz-is-neg
net jog-z-neg input.0.abs-rz-is-pos
net jog-a-pos input.0.abs-y-is-neg
net jog-a-neg input.0.abs-y-is-pos
net jog-b-pos input.0.abs-x-is-pos
net jog-b-neg input.0.abs-x-is-neg
net Pgm-run <= halui.program.run <= input.0.btn-thumb
net Pgm-stop <= halui.program.stop <= input.0.btn-thumb2
net Pgm-pause <= halui.program.pause <= input.0.btn-top
net Pgm-resume <= halui.program.resume <= input.0.btn-trigger
net Pgm-step <= halui.program.step <= input.0.btn-base4
net Estop-activate <= halui.estop.activate <= input.0.btn-base3
save the file.
Special note: The Pendant will not work until you home the Scorbot-ER-3. After Homing the coordinates will change to cartesian coordinates (X,Y,Z,A,B). After you make these changes the pendant will work as follows:
The left joy stick controls X, and Y axis.
The right joy stick controls the Z axis.
The D-Pad controls the rotation and turning of the gripper A, and B axis.
The bottom finger triggers control the rate of movement;
nothing 150
left only 300
right only 600
both 1200
Last is the buttons:
Button 9 is estop, if pressed you have to use the keyboard to reset
Button 2 is run G-Code
Button 4 is pause program, press Button 1 to Resume
Button 3 Stop program if if press Button 2 it goes back to beginning and starts
over again
Button 10 you must first press Button 4 this will run the code one line at a time
Button 1 Resume (after Button 4, or Button 10)
I have not yet figured out how to open and close the gripper through the G-Code file or the Logitech F310 Pendant. Only the GUI interface (+ -) works for the gripper.
I hope someone smarter then me can help to figure this out, and add a replay.
Thank You all
  • nigelh
  • nigelh's Avatar
20 Nov 2024 20:17 - 20 Nov 2024 21:09
System homes but unresponsive was created by nigelh
I've been automating a small Mill.
I keep running into problems and people here have helped - thank you.
Mesa 7i95t et al.
I've got to the point where I can click the home icons on my Gmoccapy screen and it homes all three axes.
Then I move the head onto the middle of the bed with the on screen jog buttons and load a piece of program
that is basically just a set to G54 mode and do a G0 X20 rapid flip 20mm positive on the model hence the bed should move left.
Once I have that it's just relearning g code time.
But nothing happens.
I add a growing number of lines to set things up.
Still nothing. It gets to that line, highlights it and just sits there probably waiting for something or feeding at 0 so it will never end.
I've spent most of the day trying new ideas.
This is where I've got to. What do I try next? What do I take out? What obvious thing have I missed?
What do I have to do to make it move?
Is it my code? My configuration? Is it offended at my accent? Does it just hate me? (it feels a bit like that)
G54 G17 G21 G90 G94 M5 M9
G92 X0 Y0 Z0
F50.
S200.
G0 X20
M2
G1 changed back to G0, I was trying G1 as a test and it didn't help
  • Steffen
  • Steffen
20 Nov 2024 20:05
Replied by Steffen on topic Download Lube component
Category: Deutsch
So, es läuft jetzt, vielen Dank Aciera, ist genauso wie ich es haben wollte, alle 2 min einen Intervall ohne viel drumherum.
Die Verknüpfungen haben mir das Leben noch etwas schwer gemacht, den interval.enable habe ich mit machine-is-enabled verknüpft, ging problemlos.
Beim interval.out kam immer der Fehler, dass der Pin nicht vorhanden ist, letztendlich habe ich Hilfe von Sven die Verknüpfungen in die Postgui_call_list geschrieben, damit ging das dann auch.
In LinuxCNC 2.8x läuft das ganze wenn man in der Interval.py aus python3 python macht.
Grüsse
Steffen
  • LabOuest
  • LabOuest
20 Nov 2024 20:02 - 20 Nov 2024 20:12
Yeah, that's what I though, the direction signal going to 0 at every step is dubious at best. Especially looking at your older posts which clearly show a logic analyser graph with the expected step dir behavior.
I made a short video so we can all better understand what's happening, would you mind taking a look ?
(Keep in mind, these are differential signal, the dir pulse is not going in the other direction between step pulse, it's just going to the mid point, 0v)
  • digiex_chris
  • digiex_chris
20 Nov 2024 19:45
Flex Gui forces machine into Manual mode when any other process switches to MDI
Category: Other User Interfaces
Thanks, that works perfectly!
Yes it seems I have mistakenly used qtpy instead of PyQt6, and so needs qtpy installed. I'll align with flexgui on QT6.
  • scotta
  • scotta's Avatar
20 Nov 2024 19:40
Are you sure the blue trace is the Dir pin. It should only change from high to low on a direction change. I doubt you are changing direction every step pulse.
The LinuxCNC component does not control the setup and hold times. This is done in the firmware.
  • tiagounderground
  • tiagounderground
20 Nov 2024 18:45
Replied by tiagounderground on topic linuxcnc trajectory planner
hi
will this version from your repository control an real machine with ethercat servos?
it already works with linuxcnc 2.9.3, its a cutting machine with XYA axis, A is tangential to the path. today it has very jerky moves as linuxcnc doesnt blend rotary axis. i would like to test the blend features you developed. in the previous videos there was an tool direction that i could use to control the tangencial axis, is this avaliable in this version?
  • Aciera
  • Aciera's Avatar
20 Nov 2024 18:44 - 20 Nov 2024 19:18
Replied by Aciera on topic Inconsistent values from Versaprobe
Category: Qtvcp
Strange enough is the value of #5070 probe fail/succeed passes each time with a one(1) succeed.
#5070 returns '1' if the probe succeeds which seems to be case. Looking at the 3 screenshots indicates that the actual probing works fine as the resulting 'calculated offset' values are very close.
Seems to me that the problem is somewhere after the actual probing has taken place.
[edit]
I wonder from where in the code this comes from:
'Return to original tool-tip position using new z-offset: ...'
  • LabOuest
  • LabOuest
20 Nov 2024 18:15 - 20 Nov 2024 18:20
Looking at the oscilloscope I found out that my timing is wrong.
There isn't any Dir Hold or Dir Setup in my signal as is required by my drivers.
(Yellow: Step pin  Blue: Dir pin)
Following Scott's post I edited and uploaded my config.txt
Unfortunately, looking at the scope, there still isn't any Dir Hold or Dir Setup in my signal !
I made sure my config was updating properly by changing the timing and looking at the scope, which it does.
I made sure the dir signal was wired correctly to the scope by moving the axis back and forth, which it is.
I reinstalled remora ethernet component by downloading the repo and doing sudo halcompile --install remora-eth-3.0.c inside Remora-RT1052-cpp-main/LinuxCNC/components/Remora-eth/
Is there a bug, did I overlook something ?
  • PCW
  • PCW's Avatar
20 Nov 2024 18:00
Help: configure a Servo motor with (PUL/DIR) as a Spindle by Par-port stepconfig
Category: StepConf Wizard
The limit will likely be the rate at which steps can be generated by the parallel port
If you set the stepgen velocity with RPM and you have 800 steps/turn the step scale should
be 800/60 = 13.3333.  With a 55 usec base period and 800 steps per turn, this limits you to 1350 RPM
Displaying 17731 - 17745 out of 24071 results.
Time to create page: 0.420 seconds
