- Ismacr63
- Ismacr63
15 Nov 2024 17:27
Replied by Ismacr63 on topic coolant mist pulses
coolant mist pulses
Category: QtPyVCP
Tried to test it but received an error. If I remove the lines that I have added in hal linuxcnc starts normallyYes, all this will work on a parallel port.
something like this:
loadrt siggen
addf siggen.0.update servo-thread
setp siggen.0.frequency .1 # 10 second period)
loadrt oneshot
addf oneshot.0 servo-thread
setp oneshot.0.width 2 # 2 second on time
loadrt not
addf not.0 servo-thread
net cool-trigger siggen.0.clock oneshot.0.in
net coolant-out oneshot.0.out [some_parallel_port_pin]
net coolant-on not.0.in
net gate-coolant not.0.out oneshot.0.reset siggen.0.reset # when coolant is off, reset both siggen and oneshot
15 Nov 2024 17:27 - 15 Nov 2024 17:30
Replied by PCW on topic Suggestion for a PCI EPP card for 7i43
You might try reversing the addresses based on the lspci order:
Region 0: I/O ports at d010
Region 1: I/O ports at d000
It may also be that the 7I43 is damaged
- juliankoenig87
- juliankoenig87
15 Nov 2024 17:18
Replied by juliankoenig87 on topic Suggestion for a PCI EPP card for 7i43
Mhmmm.
loadrt hm2_7i43 ioaddr=0xd000 ioaddr_hi=0xd010 epp_wide=0 config="firmware=hm2/7i43-4/SVST4_4.BIT num_encoders=0 num_pwmgens=0 num_stepgens=3"
gives me:
No parport registered at 0xd000. This is not always an error. Continuing.
hm2/hm2_7i43.0: board has FPGA '3s200tq144', but the firmware in hm2/7i43-4/SVST4_4.BIT is for FPGA '3s400tq144'
hm2_7i43.0: board at (ioaddr=0xD000, ioaddr_hi=0xD010, epp_wide OFF) not found!
hm2_7i43: rtapi_app_main: Invalid argument (-22)
gives me:
Warning: Spoiler!
15 Nov 2024 17:01 - 15 Nov 2024 17:12
0xd400 cannot be a valid address as its not listed by lspci
that is, "ioaddr_hi=0xd010" should be tested
Also hm2/7i43-2/SVST4_4.BIT is a bitfile for a 7I43-2, but you have a 7I43-4
- juliankoenig87
- juliankoenig87
15 Nov 2024 16:59
I can get some strange results:
loadrt hm2_7i43 ioaddr=0xd000 ioaddr_hi=0xd400 epp_wide=0 config="firmware=hm2/7i43-2/SVST4_4.BIT
Gives me:
hm2/hm2_7i43.0: invalid cookie, got 0x00000000, expected 0x55AACAFE
hm2/hm2_7i43.0: FPGA failed to initialize, or unexpected firmware?
hm2_7i43.0: board at (ioaddr=0xD000, ioaddr_hi=0xD400, epp_wide OFF) not found!
If I change to:
loadrt hm2_7i43 ioaddr=0xd010 ioaddr_hi=0xd410 epp_wide=0 config="firmware=hm2/7i43-2/SVST4_4.BIT
I have to change to the 7i43-4 firmware because linuxcnc said thats tghe wrong one. Wit 000 and 400 it is vise versa...
Gives me:
If I change to:
- Axolito
15 Nov 2024 16:54
Replied by Axolito on topic Unwanted actions with a touch screen
Category: Gmoccapy
This version doesn't have the jog buttons, but the problem was the same when they were displayed.
- juliankoenig87
- juliankoenig87
15 Nov 2024 16:42
Ok. that is new:
cnc@linuxcnc:~$ sudo mesaflash --epp --device 7i43 --addr 0xd000
[sudo] Passwort für cnc:
EPP device 7I43 at 0xD000:0xD400
15 Nov 2024 16:42
might be 0xd000 low 0xd010 high
- juliankoenig87
- juliankoenig87
15 Nov 2024 16:40
So. d010 and d000 ?
I tried 0xd000 without success.
- juliankoenig87
- juliankoenig87
15 Nov 2024 16:37
lspci -vv:
00:00.0 Host bridge: Intel Corporation Core Processor DMI (rev 11)
Subsystem: Lenovo Core Processor DMI
Control: I/O- Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Capabilities: <access denied>
00:03.0 PCI bridge: Intel Corporation Core Processor PCI Express Root Port 1 (rev 11) (prog-if 00 [Normal decode])
Subsystem: Lenovo Core Processor PCI Express Root Port 1
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 28
Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
I/O behind bridge: e000-efff [size=4K] [16-bit]
Memory behind bridge: fa000000-fb0fffff [size=17M] [32-bit]
Prefetchable memory behind bridge: c0000000-d1ffffff [size=288M] [32-bit]
Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA+ VGA16+ MAbort- >Reset- FastB2B-
PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
Kernel driver in use: pcieport
00:08.0 System peripheral: Intel Corporation Core Processor System Management Registers (rev 11)
Subsystem: Device 00aa:0059
00:08.1 System peripheral: Intel Corporation Core Processor Semaphore and Scratchpad Registers (rev 11)
00:08.2 System peripheral: Intel Corporation Core Processor System Control and Status Registers (rev 11)
00:08.3 System peripheral: Intel Corporation Core Processor Miscellaneous Registers (rev 11)
Status: Cap- 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
00:10.0 System peripheral: Intel Corporation Core Processor QPI Link (rev 11)
00:10.1 System peripheral: Intel Corporation Core Processor QPI Routing and Protocol Registers (rev 11)
00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06)
Subsystem: Lenovo 5 Series/3400 Series Chipset HECI Controller
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Latency: 0
Interrupt: pin A routed to IRQ 32
Region 0: Memory at fb145000 (64-bit, non-prefetchable)
Kernel driver in use: mei_me
Kernel modules: mei_me
00:19.0 Ethernet controller: Intel Corporation 82578DM Gigabit Network Connection (rev 06)
DeviceName: Onboard LAN
Subsystem: Lenovo 82578DM Gigabit Network Connection
Latency: 0
Interrupt: pin A routed to IRQ 29
Region 0: Memory at fb120000 (32-bit, non-prefetchable) [size=128K]
Region 1: Memory at fb144000 (32-bit, non-prefetchable) [size=4K]
Region 2: I/O ports at f040
Kernel driver in use: e1000e
Kernel modules: e1000e
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06) (prog-if 20 [EHCI])
Subsystem: Lenovo 5 Series/3400 Series Chipset USB2 Enhanced Host Controller
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 16
Region 0: Memory at fb143000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci-pci
Kernel modules: ehci_pci
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06) (prog-if 20 [EHCI])
Latency: 0
Interrupt: pin A routed to IRQ 23
Region 0: Memory at fb142000 (32-bit, non-prefetchable) [size=1K]
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev a6) (prog-if 01 [Subtractive decode])
Subsystem: Lenovo 82801 PCI Bridge
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Latency: 0
Bus: primary=00, secondary=02, subordinate=02, sec-latency=32
I/O behind bridge: d000-dfff [size=4K] [16-bit]
Memory behind bridge: [disabled] [32-bit]
Prefetchable memory behind bridge: [disabled] [64-bit]
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR+ NoISA- VGA- VGA16+ MAbort- >Reset- FastB2B-
00:1f.0 ISA bridge: Intel Corporation Q57 Chipset LPC Interface Controller (rev 06)
Subsystem: Lenovo Q57 Chipset LPC Interface Controller
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 6 port SATA AHCI Controller (rev 06) (prog-if 01 [AHCI 1.0])
Subsystem: Lenovo 5 Series/3400 Series Chipset 6 port SATA AHCI Controller
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin B routed to IRQ 30
Region 0: I/O ports at f090
Region 1: I/O ports at f080
Region 2: I/O ports at f070
Region 3: I/O ports at f060
Region 4: I/O ports at f020
Region 5: Memory at fb141000 (32-bit, non-prefetchable) [size=2K]
Kernel driver in use: ahci
Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 06)
Subsystem: Lenovo 5 Series/3400 Series Chipset SMBus Controller
Control: I/O+ Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Interrupt: pin C routed to IRQ 18
Region 0: Memory at fb140000 (64-bit, non-prefetchable)
Region 4: I/O ports at f000
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
01:00.0 VGA compatible controller: NVIDIA Corporation GT218 [GeForce 310] (rev a2) (prog-if 00 [VGA controller])
Subsystem: Micro-Star International Co., Ltd. [MSI] GT218 [GeForce 310]
Interrupt: pin A routed to IRQ 31
Region 0: Memory at fa000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at c0000000 (64-bit, prefetchable) [size=256M]
Region 3: Memory at d0000000 (64-bit, prefetchable) [size=32M]
Region 5: I/O ports at e000
Expansion ROM at 000c0000 [disabled] [size=128K]
Kernel driver in use: nouveau
Kernel modules: nouveau
01:00.1 Audio device: NVIDIA Corporation High Definition Audio Controller (rev a1)
Subsystem: Micro-Star International Co., Ltd. [MSI] High Definition Audio Controller
Interrupt: pin B routed to IRQ 17
Region 0: Memory at fb080000 (32-bit, non-prefetchable) [size=16K]
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
02:0a.0 Parallel controller: Timedia Technology Co Ltd SUN1888 (Dual IEEE1284 parallel port) (rev 01) (prog-if 02 [ECP])
Subsystem: Timedia Technology Co Ltd PAR4008A
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping+ SERR- FastB2B- DisINTx-
Interrupt: pin A routed to IRQ 20
Kernel driver in use: parport_pc
Kernel modules: parport_pc
ff:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-Core Registers (rev 04)
Subsystem: Intel Corporation Core Processor QuickPath Architecture Generic Non-Core Registers
Latency: 0
ff:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 04)
Subsystem: Intel Corporation Core Processor QuickPath Architecture System Address Decoder
Latency: 0
ff:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 04)
Subsystem: Intel Corporation Core Processor QPI Link 0
Latency: 0
Kernel driver in use: i7core_edac
Kernel modules: i7core_edac
ff:02.1 Host bridge: Intel Corporation Core Processor QPI Physical 0 (rev 04)
Subsystem: Intel Corporation Core Processor QPI Physical 0
Latency: 0
ff:03.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller
Latency: 0
ff:03.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Target Address Decoder (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Target Address Decoder
Latency: 0
ff:03.4 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Test Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Test Registers
Latency: 0
ff:04.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Control Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Control Registers
Latency: 0
ff:04.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Address Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Address Registers
Latency: 0
ff:04.2 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Rank Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Rank Registers
Latency: 0
ff:04.3 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Thermal Control Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 0 Thermal Control Registers
Latency: 0
ff:05.0 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Control Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Control Registers
Latency: 0
ff:05.1 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Address Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Address Registers
Latency: 0
ff:05.2 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Rank Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Rank Registers
Latency: 0
ff:05.3 Host bridge: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Thermal Control Registers (rev 04)
Subsystem: Intel Corporation Core Processor Integrated Memory Controller Channel 1 Thermal Control Registers
Latency: 0
Warning: Spoiler!
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
Latency: 0
15 Nov 2024 16:10
You would need the
lspci -vv
option to show addresses
lspci -vv
- juliankoenig87
- juliankoenig87
15 Nov 2024 16:08
Ok. Everytime I use only the terminal I can get a connection to the 7i43.
Once I try to start linuxcnc I get an error. After that the pc freezes when I try to reacg for the card by the terminal.
15 Nov 2024 16:04
Replied by PCW on topic Only one of the gantry joints move
Category: Basic Configuration
Can you post your hal/ini files?
- juliankoenig87
- juliankoenig87
15 Nov 2024 16:00 - 15 Nov 2024 16:05
Thank you for the support.
lspci:
It is a Sunix 4008T card. I have a Sunix PAR6408A card for pci-e, but cant use it.
Tried also "cat /proc/ioports":
cnc@linuxcnc:~$ cat /proc/ioports
0000-0000 : PCI Bus 0000:00
0000-0000 : dma1
0000-0000 : pic1
0000-0000 : timer0
0000-0000 : timer1
0000-0000 : keyboard
0000-0000 : PNP0800:00
0000-0000 : rtc0
0000-0000 : dma page reg
0000-0000 : pic2
0000-0000 : dma2
0000-0000 : PNP0C04:00
0000-0000 : fpu
0000-0000 : vga+
0000-0000 : serial
0000-0000 : pnp 00:06
0000-0000 : ACPI PM1a_EVT_BLK
0000-0000 : ACPI PM1a_CNT_BLK
0000-0000 : ACPI PM_TMR
0000-0000 : ACPI CPU throttle
0000-0000 : ACPI GPE0_BLK
0000-0000 : gpio_ich.2.auto
0000-0000 : iTCO_wdt.1.auto
0000-0000 : ACPI PM2_CNT_BLK
0000-0000 : pnp 00:03
0000-0000 : pnp 00:01
0000-0000 : PCI conf1
0000-0000 : PCI Bus 0000:02
0000-0000 : 0000:02:0a.0
0000-0000 : parport0
0000-0000 : PCI Bus 0000:01
0000-0000 : 0000:01:00.0
0000-0000 : 0000:00:1f.3
0000-0000 : i801_smbus
0000-0000 : 0000:00:1f.2
0000-0000 : ahci
0000-0000 : 0000:00:19.0
0000-0000 : ahci
0000-0000 : ahci
0000-0000 : ahci
0000-0000 : ahci
mesaflash:
cnc@linuxcnc:~$ sudo mesaflash --device 7i43 --addr 0xd010 --epp
EPP device 7I43 at 0xD010:0xD410
cnc@linuxcnc:~$ sudo mesaflash --device 7i43 --addr 0xd010 --epp --readhmid
Speicherzugriffsfehler
cnc@linuxcnc:~$
lspci:
Warning: Spoiler!
Warning: Spoiler!
0000-0000 : dma1
0000-0000 : pic1
0000-0000 : timer0
0000-0000 : timer1
0000-0000 : rtc0
0000-0000 : pic2
0000-0000 : dma2
0000-0000 : fpu
0000-0000 : vga+
0000-0000 : serial
0000-0000 : ahci
0000-0000 : ahci
0000-0000 : ahci
0000-0000 : ahci
0000-0000 : ahci
mesaflash:
Warning: Spoiler!
cnc@linuxcnc:~$
- meister
- meister
15 Nov 2024 15:30
Replied by meister on topic LinuxCNC-RIO - RealtimeIO for LinuxCNC based on FPGA (ICE40 / ECP5)
Wellcome back Mecanix
there are two new cool boards:
github.com/digiexchris/rio-solidwater-shield
github.com/festlv/rioctrl-hw
and little bugfixes in the software
@all
gitano from the german forum 'https://www.cnc-aus-holz.at'has put together a cool logo
what do you think of it ?
@all
Time to create page: 0.460 seconds
