  • Aldenflorio
  • Aldenflorio's Avatar
13 Nov 2024 17:57
Replied by Aldenflorio on topic Pipe Cutting Plasma CNC
Yes exactly like that! I tried looking for more information about that build specifically but couldn’t seem to find the right keyword to pull it up.
I would love more information on the design of that, the motor used, the way Linuxcnc is best incorporate to fit that, and all.
i don’t think I realized that was your video, is it?
13 Nov 2024 17:45
Replied by tommylight on topic Mesa 7i96s / Network no longer working
Category: Driver Boards
That looks OK.
Did you use the Network Manager to set up the network?
If yes, you need to check the "use this connection for local ..... " not sure what exactly it says as i am on the phone.
That is for wired network only, IPV4 settings.
You also have a wireless network and if that connects before the Lan, it will send all trafic through wifi, if the above is not set for wired network.
  • PCW
  • PCW's Avatar
13 Nov 2024 17:39
Replied by PCW on topic Mesa 7i96s / Network no longer working
Sounds like something has gone wrong with the Ethernet section of the 7I96S card.
It should be repaired/replaced under warranty, Contact Mesa or your dealer for instructions
13 Nov 2024 17:39
Replied by tommylight on topic Pipe Cutting Plasma CNC
Like this?
Also 3 axis only, X is rotating, made several configs for each pipe diameter/perimeter as there is no need for more than one revolition ever.
This made a huge border crossing "tent"? "Palapa"? Whatever that is called, it is all round pipes with 73 and 193mm diameters.
  • greg23_78
  • greg23_78
13 Nov 2024 17:14
  • schnellmued
  • schnellmued
13 Nov 2024 17:12
Replied by schnellmued on topic Mesa 7i96s / Network no longer working
On the PC, what does
ip a
in a terminal return?
xx@lxcnc-l540:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host noprefixroute
2: enp0s25: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc fq_codel state UP group default qlen 1000
    link/ether 3c:97:0e:d3:69:0e brd ff:ff:ff:ff:ff:ff
    inet 10.10.10.2/24 brd 10.10.10.255 scope global noprefixroute enp0s25
3: wlp2s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
    link/ether 5c:51:4f:8c:69:69 brd ff:ff:ff:ff:ff:ff
    inet 192.168.37.146/24 brd 192.168.37.255 scope global dynamic noprefixroute wlp2s0
       valid_lft 863940sec preferred_lft 863940sec
enp0s25 is the nic connected directly to the mesa card, wlp2s0 wifi to my home router
schnellmued
  • schnellmued
  • schnellmued
13 Nov 2024 17:08 - 13 Nov 2024 17:10
>>If you get the link LED (Yellow) on the RJ45, its not likely a firmware issue
>>but rather an Ethernet issue.
>>If you ping the card, do the green LEDs on the 7I96S count up?
no, the green LED stay off.
If i connect to the other card in my lathe and ping it the green LED start to blink
schnellmued
  • PCW
  • PCW's Avatar
13 Nov 2024 16:00
Mesa, Linuxcnc with step direction servo's for axis and analog servo spindle.
Category: Basic Configuration
That's analog servo (7I77) setup
if you make a (different name!) pncconf configuration for a 7I76E
it will make a step/dir setup as an example
  • Aldenflorio
13 Nov 2024 14:55
Sorry I may have explained it weirdly. It will only be a 3 axis machine. X is the pipe rolling, y is the fixed are torch holder moving, and z is the torch probing.
the torch will be fastened to fixed arm centered on the pipe. The arm itself will move the fixed torch on the y axis with a stepper motor.
  • B.Reilly01
  • B.Reilly01
13 Nov 2024 14:50
Replied by B.Reilly01 on topic Linear move exceeds joints positive limit
I think the linear move causing the error is actually line 19, the G43 Z15 H7. I'm willing to bet your tool length + the 15 in Z is pushing you out of your envelope.
  • cakeslob
  • cakeslob
13 Nov 2024 14:48
Replied by cakeslob on topic Remora rp2040 compile issues.
are you compiling with release or debug? idk which one but people report trouble with one
  • mjones@welfab.ca
  • mjones@welfab.ca
13 Nov 2024 14:41
This is what my hal shows for one of my axis servos, should be stp/dir. Does this look like a step/dir or analog code.
# AXIS X JOINT 0
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp pid.x.maxerror 0.000500
net x-index-enable <=> pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-pos-fb => pid.x.feedback
net x-output <= pid.x.output
# ---PWM Generator signals/setup---
setp hm2_7i76e.0.7i77.0.3.analogout1-scalemax [JOINT_0]OUTPUT_SCALE
setp hm2_7i76e.0.7i77.0.3.analogout1-minlim [JOINT_0]OUTPUT_MIN_LIMIT
setp hm2_7i76e.0.7i77.0.3.analogout1-maxlim [JOINT_0]OUTPUT_MAX_LIMIT
net x-output => hm2_7i76e.0.7i77.0.3.analogout0
net x-pos-cmd joint.0.motor-pos-cmd
net x-enable joint.0.amp-enable-out
# enable _all_ sserial pwmgens
net x-enable hm2_7i76e.0.7i77.0.3.analogena
#setp hm2_7i76e.0.encoder.01.counter-mode 0
#setp hm2_7i76e.0.encoder.01.filter 1
#setp hm2_7i76e.0.encoder.01.index-invert 0
#setp hm2_7i76e.0.encoder.01.index-mask 0
#setp hm2_7i76e.0.encoder.01.index-mask-invert 0
#setp hm2_7i76e.0.encoder.01.scale [JOINT_0]ENCODER_SCALE
net x-pos-fb <= hm2_7i76e.0.encoder.01.position
net x-vel-fb <= hm2_7i76e.0.encoder.01.velocity
net x-pos-fb => joint.0.motor-pos-fb
net x-index-enable joint.0.index-enable <=> hm2_7i76e.0.encoder.01.index-enable
net x-pos-rawcounts <= hm2_7i76e.0.encoder.01.rawcounts
# ---setup home / limit switch signals---
net x-home-sw => joint.0.home-sw-in
net x-neg-limit => joint.0.neg-lim-sw-in
net x-pos-limit => joint.0.pos-lim-sw-in
  • snowgoer540
  • snowgoer540's Avatar
13 Nov 2024 14:40
Replied by snowgoer540 on topic Pipe Cutting Plasma CNC
You should be aware that Linuxcnc is limited to 3 axis look ahead. I’m not sure what that looks like for you, sounds like maybe you’re going to lock out the X axis or the design has it centered over the chuck permanently. But if you’re planning to have XYZA, then know that motion may be jerky (running similar to 3+1), and will not be coordinated with the smooth transitions you’re probably used to seeing out of a 4/5 axis plasma cutter. This will probably be problematic for cut quality.
Of course do your own simulation/testing but wanted you to be aware of the limitations software side.
  • Aldenflorio
13 Nov 2024 14:21
Pipe:
-up to 4 feet but generally no longer than 1 foot
-up to 10” possibly
-2 roller supports bearing the weight of the pipe
The torch will move on the Y axis and the Z axis. The pipe will rotate on the X axis
13 Nov 2024 14:17
What length pipe?
What diameter pipe?
Moving torch or moving pipe?
Displaying 18196 - 18210 out of 24118 results.
Time to create page: 0.804 seconds
