  • zarfld
  • zarfld
09 Nov 2024 21:33
Pokeys_homecomp EncoderSearch / Encoder Arm Topic: Pos_Fb Following errors
Category: HAL
the comp In "Page 10" can Just read/write Pins ( digital in) for movement you'd need to use the PEv2 as Pulse generator for stepoers. In 2.8 i got IT working so that o could move the axes, but the came to the homing topic which caused that i Had to move to 2.9.2 where had Strange issues (AS reported in one of my previous Posts Here).
Some weeks ago i started to Work in that topic again an currently found Out that in 2.9.3 some of the issues reported before we're Not reproducible. But still have Performance issues when i add the pokeys_homecomp in the ini for homing
My actual configuration can be found Here github.com/zarfld/LinuxCnc_PokeysLibComp i did a rough description maybe that helps a bit ( it's far from being a full and structured technical documentation) For now i think to keep IT running in Carport until i could fix the homing topic, i you want to give IT a try i could also Help on updating your HAL and ini based on your machine.
  • MaHa
  • MaHa
09 Nov 2024 21:27
Replied by MaHa on topic Conditional block - Probing routine
Category: O Codes (subroutines) and NGCGUI
You can try #<tool_in_spindle> instead of #<_current_tool>
  • Jeff in Wa
  • Jeff in Wa
09 Nov 2024 20:55
Conditional block - Probing routine was created by Jeff in Wa
; New stand-off position for the probe (T99)
#<_ProbeStandOffX> =   1135.0    ; X coordinate for probe stand-off
#<_ProbeStandOffY> =    516.0    ; Y coordinate for probe stand-off
O120 IF [ #<_current_tool> EQ 99 ]
        G53 G1 F[#<_TravelFeed>] Z[#<_TravelZ>]                ; Move Z0 for traveling
        G53 G0 X[#<_ProbeStandOffX>] Y[#<_ProbeStandOffY>]  ; Move to probe stand-off position
     ELSE
        G53 G1 F[#<_TravelFeed>] X[#<_ToolChangeX>] Y[#<_ToolChangeY>]  ( Moves to tool setter for manual tool change )
O120 ENDIF
The top section never gets qualified, even though variable #5400 has 99 stored in it.
I'm not sure this will work anyway.  I want to put in the typical M6 T99, and perform the tool setter routine.  But in my case,
I want T99 to send the probe to a fixed location instead.  All other tools, ie;  M6 T2 would go to the tool setter.
  • JT
  • JT's Avatar
09 Nov 2024 20:04
Replied by JT on topic Flex GUI Import a Python Module
Category: Other User Interfaces
And for you probe fans Flex can now get user parameter values on startup and change them from the GUI.
Quite a few folks on the IRC use Flex GUI.
Is anyone here using Flex GUI?
JT
  • juliankoenig87
  • juliankoenig87
09 Nov 2024 19:19 - 09 Nov 2024 19:25
Replied by juliankoenig87 on topic Suggestion for a PCI EPP card for 7i43
The card arrived. PCI to parport Sunix. Looks like it works.
But I try to power the 7i43 and it looks like it is faulty. With W4 and W5 down I can make the 3 leds on the bottom light a little bit at 2,9V and 0,5A. But at 5V and around 0,4A nothing shines anymore. Looks like somithing is wrong.
  • Aciera
  • Aciera's Avatar
09 Nov 2024 19:15 - 09 Nov 2024 19:16
Replied by Aciera on topic Fast Hole EDM from Hacked Parts
Yes, reverse feed is possible and also used in EDM machines that use linuxcnc,
  • Gluca
  • Gluca
09 Nov 2024 19:11
Remora rp2040 compile issues. was created by Gluca
Hi all!
I've been trying to use wiznet w5500-evb-pico as step generator for linucnc.
I was successfull loading remora-rp2040-2.0.0.uf2, from github.com/scottalford75/Remora-RP2040-W5500
But, when trying to compile, i was less lucky:
/tmp$> cmake -DPICO_SDK_FETCH_FROM_GIT=on ./Remora-RP2040-W5500-main/
/tmp$> make
I've got some include errors like: pico_bootrom/bootrom.c:9:10: fatal error: boot/picobin.h: No such file or directory
#include "boot/picobin.h"
The same for: runtime_init.h,runtime.h
But those files are available in the sdk source.
My Q&D solution was to copy locally to complete the build.
After that, the build made a loadable uf2 image.
But the rp2040 has been crashing during my tests.
Suggestions?
Gluca.
09 Nov 2024 18:43
[SOLVED] Rigid tapping problem - tristate_bit and index-enable?
Was this on another topic a while back, or is it another setup/machine?
  • spumco
  • spumco
09 Nov 2024 17:59 - 09 Nov 2024 18:01
O.M.G. - I should RTFM
spindle.M.revs IN FLOAT
For correct operation of spindle synchronized moves, this signal must be hooked to the position pin of the spindle encoder.
Ignorance is NOT bliss.
  • spumco
  • spumco
09 Nov 2024 17:35
It should still work with the tristate bit connected, as long as the tristate enable pin is false.
Thanks, I'll reconnect it.
Shocking development: I've managed to get the spindle orienting without using the shot-pin, and without having to set index-enable true and rotate the spindle to re-find the index.
Based on Andy's advice a couple years ago, I had connected pid.o.error to pid.o.Pgain through a lincurve array.  After watching things in halshow today, I discovered that Pgain wasn't changing in response to the orient error; i.e. lincurve wasn't doing anything.
Turns out I had the lincurve starting x-values set to an order of magnatude smaller than required for lincurve to adjust the output.  Result was that lincurve didn't 'kick-in', ever.  The shot-pin was required to lock it in place because the pid wasn't adjusting - just causing the spindle to wag back and forth.
After changing the values and connecting pid.o.index-enable the spindle now orients from any position.  No shot-pin, no pre-orient spin-the-spindle index-enable dance.
Sadly, this hasn't fixed the rigid tapping failure.
  • PCW
  • PCW's Avatar
09 Nov 2024 17:10
  • spumco
  • spumco
09 Nov 2024 16:58
The index-enable is getting cleared when the index pin goes true.
Just tested that by disconnecting the tristate_bit and manually setting the index-enable signal high and running the spindle for a second.
  • PCW
  • PCW's Avatar
09 Nov 2024 16:54
If you manually set the index enable signal true
and is is not over-driven by some other source,
it should get cleared at the index position by the
physical index signal. If this does no happen, you may
have a hardware issue with the index signal.
  • spumco
  • spumco
09 Nov 2024 16:34 - 09 Nov 2024 16:36
I think I just found the point in history where I blew past the fact that pid.o.index-enable needed to be connected to something.
forum.linuxcnc.org/24-hal-components/458...-yay?start=40#245756
09 Nov 2024 16:13
Replied by tommylight on topic Retro fitting
Retro fitting
LinuxCNC can do this on it's own, easily
forum.linuxcnc.org/show-your-stuff/50177...ny-solder-bot#314119
No need for cams, just a simple lathe with spindle encoder.
Displaying 18406 - 18420 out of 24125 results.
Time to create page: 1.187 seconds
