06 Nov 2024 23:10
Replied by Cant do this anymore bye all on topic Suggestion for a PCI EPP card for 7i43
BTW it works with my custom hardware running a modified version of 7c81 bitfile that communicates via EPP.
06 Nov 2024 23:07
Check the Lenovo motherboard for a lot header. If there is one but the Lenovo header cable, that will enable the parallel port in the bios. Without going into too many details the cable shorts a pin on the MB enabling the parallel port.
Worked on the Lenovo tower I picked up by the side of the road.
  • Sziggy_NC
  • Sziggy_NC
06 Nov 2024 22:49
Replied by Sziggy_NC on topic 7i97t Spindle has 0v or 10v
Thank you for noticing my bonehead move. I commented it out when I was trying the pwm gen copied from pncconf with an 7i92/7i77. (I tried re-naming stuff to 7i97 unsuccessfully.)
Sadly I am still doing something wrong with the pwmgen. I no longer have AOUT4 stuck at 10v, but it is now stuck at 0v.
I have un-commented what you noted in my hal file. Changing [SPINDLE_0]SCALE to SPINDLE_0]OUTPUT_SCALE and adding OUTPUT_SCALE = 10000.0 to my ini file under spindle_0.
The pwmgen that you found was copied from my X axis and renamed for the spindle. It came from Mesa CT.
I am re-reading the pwmgen component in the docs, but I am having trouble understanding what I need to do.
  • spumco
  • spumco
06 Nov 2024 22:11
Replied by spumco on topic Trajectory Planner using Ruckig Lib
Amazing, thank you Grotius!
Assuming this can be integrated in LCNC (for non-coders), the next step would be figuring out how to re-name axes or add more axis letters and define the axis type (linear or rotary).  Such as X1/X2, Y1/Y2, Z1/Z2, C1/C2, etc.
I've not programmed a Swiss lathe, but the twin-turret lathe I've fiddled with uses n1/n2 for the four duplicated axes (XYZC).
  • sin-do-re
  • sin-do-re
06 Nov 2024 21:53
Mesaflash not possible - no 7i96s card found
Hey everyone.
im trying to mesaflash the 7i96s_dpl for multiple encoder use. but I get consecutive errors of not finding the card. the card is connected at 10.10.10.10 and the lcnc works perfectly , 0.100 ms of ping, but i can’t identify it with mesaflash which is up to date.
any suggestions?thanks in advance.
  • NTULINUX
  • NTULINUX's Avatar
06 Nov 2024 21:37
Gentoo LinuxCNC builds for ARM64 be of interest?
Category: Installing LinuxCNC
Hello,
I was wondering, would it be of any interest to provide Gentoo ARM64 images for a few boards with PREEMPT_RT?
I don't think I have any besides a Pi 4 stashed away somewhere, but there's quite a lot of topics and messages about people getting LinuxCNC on Raspberry Pis and whatnot. What if there was a be-all and end-all solution that had Gentoo fully ready to go for LinuxCNC? Would anyone care or want this? What device(s) has/have the most interest/popularity among LinuxCNC users?
Cheers!
  • PCW
  • PCW's Avatar
06 Nov 2024 21:08
Replied by PCW on topic hm2/hm2_7i92.0: Error finishing read!
Category: Driver Boards
0.161/0.163/1.240/0.005 ms
That's more that 1 ms so a reason for timeouts
You might try a 2 ms servo thread
(2000000 ns in the ini file)SERVO_PERIOD = 2000000
  • Lcvette
  • Lcvette's Avatar
06 Nov 2024 20:57
Error getting packages on fresh install on Raspberry Pi 5
Category: QtPyVCP
Okay - we found the problem and after some tests believe it is fixed. a stray full-stop ina file name pattern.
Thanks Joco!
  • angelnu
  • angelnu
06 Nov 2024 20:56
Replied by angelnu on topic hm2/hm2_7i92.0: Error finishing read!
Sorry for my ignorance, I don't understand network addresses.
Here are the results:
sudo chrt 99 ping -i .001 -q 10.10.10.10 -c 50000
[sudo] contraseña para angel:
PING 10.10.10.10 (10.10.10.10) 56(84) bytes of data.
--- 10.10.10.10 ping statistics ---
50000 packets transmitted, 50000 received, 0% packet loss, time 50007ms
rtt min/avg/max/mdev = 0.161/0.163/0.462/0.002 ms
angel@orangepi5:~$ sudo chrt 99 ping -i .001 -q 10.10.10.10 -c 50000
50000 packets transmitted, 50000 received, 0% packet loss, time 50003ms
rtt min/avg/max/mdev = 0.161/0.163/1.240/0.005 ms
50000 packets transmitted, 50000 received, 0% packet loss, time 50006ms
rtt min/avg/max/mdev = 0.161/0.163/0.215/0.001 ms
  • Philip Lydin
  • Philip Lydin
06 Nov 2024 20:50
Replied by Philip Lydin on topic Brother TC-225 / TC-229 adventure!
Category: CNC Machines
does anyone know what the r210 and s210 cables coming from the spindle motor is and what the et pin on the drive is
  • aleksamc
  • aleksamc's Avatar
06 Nov 2024 20:48
Replied by aleksamc on topic Trajectory Planner using Ruckig Lib
I saw "Supper imposed" function on modern sinumerik cnc this summer. I supposed, "yes it woould be nice to see same on linuxcnc. But maybe it will be never realized". But you make it so easy!!! I very impressed about that!
06 Nov 2024 20:32 - 24 Mar 2025 15:52
Used Laptops tested with LinuxCNC and Mesa Ethernet boards
Lenovo X1 Carbon Yoga laptop/tablet, no RJ45, touch screen, foldable tablet, 14"
-TouchScreen as it is laptop/tablet combo,
-no RJ45 connector,
-tested using a USB-A to GigaBit Ethernet adapter
-LinuxCNC 2.10 on Linux Mint 22 with RT kernel 6.10.12, Mesa 7i92 on a production machine,
-No GRUB changes, no isolcpus nor anything else, no BIOS changes
==disabling hyperthreading and Intel AMT gets rid the warnings
-Plugging and unplugging power does cause latency warning, but machine continues to work
-disabling TPM does NOT help much
==disabling SGX and virtualization DOES help a lot,
-no more warnings even playing videos during running of LinuxCNC and doing other stuff,
- WiFi does not work with this kernel
No video yet, will update when i get to it.
  • furkanuzal
  • furkanuzal
06 Nov 2024 20:32
Ethercat installation from repositories - how to step by step
Category: EtherCAT
Hello. I installed ethercat following all the instructions. I can see my servo motors. But I can't do anything else. I cannot create the lcec.conf file. Please can you help? (I can't find a clear source because I use Google translate)
06 Nov 2024 20:31
Displaying 18556 - 18570 out of 24130 results.
Time to create page: 0.612 seconds
