  • jonesmg1
  • jonesmg1
01 Nov 2024 20:48
Replied by jonesmg1 on topic Puma 6 axis Robotic Arm with Mesa 7i80/7i40
Good point.. I've set all of the axes to 9.5 but it didn't resolve my issue.
  • PCW
  • PCW's Avatar
01 Nov 2024 20:24
Replied by PCW on topic Mesa 7i96s P1 basics and MPG
Category: Driver Boards
You should not need series resistors.
Just make sure that the ground return
of the switches goes only to the 7I96S
ground.
  • GDTH
  • GDTH's Avatar
01 Nov 2024 20:23
Problems with Lichuan Ethercat servo drive
Category: EtherCAT
sorry for this silly questions.
in the comp it is written as 'stat_switched_on' but in hal it becomes 'stat-switched-on'.
I did not know this yet. the same with spaces:
net z-brake cia402.0.stat-switched-on =>lcec.0.4.dout-2 #lcnc freaks out because there is not space after '=>'
Tomorrow i will try to connect the brake to the driver instead of LCNC. as i will get following error when the brake is a bit late. I could maybe fix this with comps however i think the driver should handle this.
Also i need to find a way to reset this driver error through lcnc when it happens.
I hope i will be able to show you a video next week of the ethercat bridgeport :)
  • PCW
  • PCW's Avatar
01 Nov 2024 19:51 - 01 Nov 2024 19:52
Replied by PCW on topic Raspberry pi 4 problems
Is it  possible you have lost the link? (maybe 7I96S 5V power issue)
What does:
sudo chrt 99 ping -i .001 -q -c 10000 10.10.10.10
report?
(will run 10 seconds and report ping statistics)
  • Wassim_b
  • Wassim_b
01 Nov 2024 19:46
Replied by Wassim_b on topic Mesa 7i96s P1 basics and MPG
Thank you for the quick reply. I will try to figure out how to flash the modified firmware.
As for the wiring (first question): do i need any resistors to limit the current or can i pull the pins directly to ground (common)?
  • PCW
  • PCW's Avatar
01 Nov 2024 18:55
qtplasmac (Operation Error: hm2/hm2_7i76e.0:) in middle of cut
Category: Plasmac
Try running this script to see if it helps:
File Name: pinirq_2024-11-01.txt
File Size:1 KB
first chmod +x pinirq.txt
then
 sudo ./pinirq.txt enp0s25
(from wherever you browser downloads stuff, probably ~/Downloads)
(this is temporary and will get reset by rebooting)
The best current PC I have for network latency is a HP 8300 USDT
(AMT needs to be turned off in the BIOS) It will run for weeks at a 3 KHz
servo thread rate while doing normal PC web/compiling/etc stuff
01 Nov 2024 18:54
Category: Plasmac
Might be a stab in the dark, but i would change the 5V and 24V power supplies first.
  • PCW
  • PCW's Avatar
01 Nov 2024 18:46 - 01 Nov 2024 18:46
I would use 7i96sd_mpgp1.bin firmware as that was designed for this use.
You can use a software MPG encoder but since the inputs are sampled
at the (relatively slow) servo thread rate it will not work very well.
Take a look at this thread:
forum.linuxcnc.org/39-pncconf/51733-7i96...-configurator#295487
  • RMJ fabrication
  • RMJ fabrication
01 Nov 2024 18:34
Category: Plasmac
My problem just got worse. Now the error has returned even while using "sudo ethtool -C enp0s25 rx-usecs 0". Its just like before popping up every 5-10 minutes and stopping my cut in the middle of the process forcing me to recover the cuts and it is very difficult. Any ideas of what can be causing this error? and also can you guys maybe recommend working pc models so I could maybe swap the computer for one that works how it is supposed to.
  • Wassim_b
  • Wassim_b
01 Nov 2024 18:33
Mesa 7i96s P1 basics and MPG was created by Wassim_b
Hi everyone,
This is my first post in this forum, so first of all i want to say that i am really impressed by this community. You have been a great help in my cnc building journey. So Thanks you
I upgraded my controller setup from an old PC with parallel port interface to a Mesa 7i96s card connected to a newer PC. Now i am working on my pendant/mpg and have modified it to be directly plugged into the P1 expansion port.
Since i am new to the mesa hardware i want to make sure that my setup does not have a fatal flaw. I basically have two questions
1- my pendant has 6 push buttons and two rotary switches (for axis and jog speed selection). Each button is wired this way, for example Pin 3 and Button 3:
Pin3 (P1) -> button 3 -> ground.
So the pin gets pulled to ground when the button is pushed (active low). I read it should be done this way since the P1 pins have pullup resistors and are always high when the board is powered up. Is this wiring ok? Do i need extra resistors to limit the current? Many buttons can be pushed at the same time.
2- concerning the mpg/rotary encoder. i have read several posts talking about custom bit files to add encoder "functions" to some pins. Is this step really needed? My former setup had the a and b channels of the encoder connected to normal pins, the signal management was done in the hal. I want to avoid flashing new bitfiles if possible at this stage because i am still not very comportable with this new (to me) hardware.
Thanks !!
  • PCW
  • PCW's Avatar
01 Nov 2024 18:30
Replied by PCW on topic Maximum step rate with MESA
Yes, the maximum steprate for Mesa FPGA cards is only dependent
on the hardware. It is independent of the host controller.
This is because the steprate is set by a digital oscillator.
The host does determine the update rate of the steprate,
so even though you could have a 10 MHz steprate at a 1 Hz
update rate it would not work at any reasonable acceleration rate.
  • PCW
  • PCW's Avatar
01 Nov 2024 18:21 - 01 Nov 2024 19:17
Novakon Mill Conversion - Getting Started
Category: CNC Machines
At first glance:
Change  step times from 500 to 4000
The charge pump needs to be done with stepgen 4
(the software charge pump will not work)
Recent versions of pncconf know how to setup a stepgen as a charge pump
  • Aciera
  • Aciera's Avatar
01 Nov 2024 18:03
Replied by Aciera on topic xml tool Table
xml tool Table
I'm not aware of an XML import.
It is possible to use an external database for tool management:
linuxcnc.org/docs/devel/html/tooldatabase/tooldatabase.html
As an alternative it might be possible to convert the xml tool data to ordinary list data used in linuxcnc (eg by a custom python script):
linuxcnc.org/docs/devel/html/gcode/tool-....html#sec:tool-table
  • Aciera
  • Aciera's Avatar
01 Nov 2024 17:51 - 01 Nov 2024 17:53
Replied by Aciera on topic Help to understand axes directions
Homing defines your absolute zero position (ie G53), whenever you actually cut a part you will be using a work coordinate system (ie G54 ... G59) that is set to a corner of your machine vise or the part to be machined.
  • rmavalente
  • rmavalente
01 Nov 2024 17:34
Replied by rmavalente on topic Help to understand axes directions
Okay, thats why they were opposite, homing vs traveling direction, as I believe, I guess I'm missing some very basic concepts here.
I`m trying to understand how my machine should be set for home.
The travels are X 1000 mm, Y 450 mm and Z 400 mm.
How should I set the homing to be as trivial and safe as possible?
I thought as my first post:
I'm setting my home positions and to order to:
1st: Z all the way down, nearest to the floor at value 0.0
2nd: X all the way to the left, nearest the lathe at value 0.0
3rd: Y all the way back, nearest to the wall at value 0.0
Should I set 0 values for all axes? This would make my machine runs on negative coordinates all the time, right? What would be typical for a machine like this?
I really appreciate your help, guys.
Displaying 18871 - 18885 out of 24119 results.
Time to create page: 0.496 seconds
