  • Stran_ge
  • Stran_ge
24 Oct 2024 21:08
Replied by Stran_ge on topic Spindle servo step/dir Problems
well that comment is from the creator of the spindle section (tall83). It is not from my servo so it should be unrelated to my setup.
Unfortunately my manual does not give any info for the step scale.
  • PCW
  • PCW's Avatar
24 Oct 2024 20:56 - 24 Oct 2024 20:56
Replied by PCW on topic Spindle servo step/dir Problems
I think the output scale should be 166.6666 (or -166.6666) as the ini file comment suggests.
This is completely unrelated to the encoder scale (which seems to have been factored in)
(at least assuming 10000 steps per turn)
  • Stran_ge
  • Stran_ge
24 Oct 2024 20:36
with both you mean the step scale and encoder scale i suppose.
Yes i agree, the problem is i dont really have a way to find that out myself i believe.
The parameter that shows the factory default says 1024 motor resolution per revolution.
  • cakeslob
  • cakeslob
24 Oct 2024 20:34
Machine moves when you stop program in the middle
you should give it a shot if you are able, unrelated to probe
but the on abort stuff doesnt look like it will effect probe stuff, as it is advised to use the probe abort button on the probe panel [x] button
  • PCW
  • PCW's Avatar
24 Oct 2024 20:30
That indicates the original issue, the scaling in incorrect (on one or both)
  • Stran_ge
  • Stran_ge
24 Oct 2024 20:22 - 24 Oct 2024 20:28
i did invert it to:
OUTPUT_SCALE = -68.26667
and now the spindle turns correct.
The Problem with the difference between spindle-fb-rps and spindle-speed-rps still persists tho. spindle-fb-rps is negative and spindle-speed-rps is positive (in case of m3).
This lead to spindle-at-speed never beeing true.
Edit: even when i invert the encoder scale the difference btw. the fb rps and speed rps(commanded) is too big for spindle at speed to be true.
  • PCW
  • PCW's Avatar
24 Oct 2024 20:14
Its this (in the ini file)
OUTPUT_SCALE = 68.26667
24 Oct 2024 20:10
Replied by tommylight on topic Spindle servo step/dir Problems
Edit the ini file, not the hal file.
  • Stran_ge
  • Stran_ge
24 Oct 2024 20:08
i get what you mean but i dont have a step scale/ direction output in my hal.
  • PCW
  • PCW's Avatar
24 Oct 2024 19:56
You need to reverse the sign of the step scale (or invert the direction output)
to reverse the spindle
  • besriworld
  • besriworld
24 Oct 2024 19:40 - 26 Oct 2024 21:46
Replied by besriworld on topic Modbus Help - MB2HAL
Hello, I am trying to read the spindle load using Modbus. It works fine with the Windows program, but with Linux and mb2hal, it does not. The problem occurs when I attempt to read address 420—it does not return any value, only increments the error counter. Some addresses can be read, but others cannot. What am I doing wrong?Here is the configuration, along with a screenshot of the working Windows setup.
File Name: modbus_con....ini.txt
File Size:5 KB
ps now working!  i just changed this parameter MAX_UPDATE_RATE
  • RyanB
  • RyanB's Avatar
24 Oct 2024 19:31
Could use some help with a tandem axis homing issue
Category: Basic Configuration
This is going to sound so stupid, but might as well own up to it.
I found out the problem was not the switch but the motor connection. I have a nuc and the mesa board in a mobile station I can roll around the shop while the CNC router, drivers, power supply, etc are stationary. The reason I designed it this way was to use the mobile station for testing stuff I intend to convert into CNC (lathe, mill, etc). It looks like my solder job for one of the motor signal connectors was somewhat faulty and allowed it to only be driven in 1 direction. Probably a cold joint, which also explains why it was happening only occasionally.
My guess is that the cnc attempted to hold the motor still after the limit was hit (hence the delay) but only received one direction signal and not the other, there by pushing the motor into the switch.
  • mylastpolo
  • mylastpolo
24 Oct 2024 19:24
Replied by mylastpolo on topic Fanuc Servos Single Phase
So it says 142v on the servo but then it says 200v inverter on the same tag. The machine they were removed from was on a 400v 3 phase supply, my 230v being one of those phases to neutral. I do have a transformer capable of the current requirement.
  • Stran_ge
  • Stran_ge
24 Oct 2024 19:22
i edit the line:
setp hm2_7i95.0.encoder.05.scale - [SPINDLE_0]ENCODER_SCALE
with a minus but that alone does not change the direction of m3/m4.
If i now go ahead and change a direction parameter on my servo drive to reverse
the spindle turns cw via m3 and ccw via m4 while spindle-fb-rps and spindle-speed-rps signal are both positive at least tho still slightly different values.
So i guess i can hack my way around the m3/m4 problem but still the problem with the speed is not solved by this.
at a certain speed close to 1000 rpm and above the spindle-at-speed never becomes true.
  • Grotius
  • Grotius's Avatar
24 Oct 2024 19:12
Replied by Grotius on topic linuxcnc trajectory planner
Hi Bkt,
You can install it "rip" only, but you can not run the new trajectory planner. It's still being coded.
custom kins is the same as 2.10?
I don't know wich kins versions are in. Its a recent linuxcnc git clone.
Displaying 19291 - 19305 out of 24145 results.
Time to create page: 1.557 seconds
