  • PCW
  • PCW's Avatar
17 Oct 2024 04:03
  • Craigl
  • Craigl
17 Oct 2024 03:52
Mesa 7i92TF- Gecko540 - RealTEK 8111/- failed to launch error real time delay
Category: Basic Configuration
Team,
I need some help.  New to linuxcnd.    Linuxcnc  bookworm on N97 CPU, Mesa7i92TF,   fails to launch.
Error "Unexpected realtime delay on task0 with period 1000000"
hm2/hm2_7i92.0 erro finishing write! iter=2219.
i did update the driver  r8168kdms,  disable cpu power saving mode ,  set - c state  at level 2.  Please
  • Lcvette
  • Lcvette's Avatar
17 Oct 2024 03:43
Probe Basic machines won't update after modify in "Designer for PB"
Category: QtPyVCP
I just installed a new dev build from the Doc scripts and it is updating on save as expected. I would check your build, did you change the name when saving?
  • burnie
  • burnie
17 Oct 2024 03:36
Category: QtPyVCP
Yes, I use the launchers on the desktop, "Designer for PB Mill" and "Designer for PB Lathe", then launch LinuxCNC with "Probe Basic Mill" and "Probe Basic Lathe" launchers on the desktop.
  • Lcvette
  • Lcvette's Avatar
17 Oct 2024 02:32
Replied by Lcvette on topic Tool length sensor direction change
Category: QtPyVCP
It is also standard practice for cam software and tool length offset. Definitely need to change to standard practice, so reason to reinvent the wheel on this. With a work offset you will be setting zero wherever you want. But machine motion is always z moving down is negative direction.
  • spumco
  • spumco
17 Oct 2024 02:27
Replied by spumco on topic Tool length sensor direction change
Category: QtPyVCP
You should switch your Z=0 direction.  Machine Z-0 (G53) should be at top of stroke (or furthest from chuck for lathes).
This is standard practice on most machines, and is compatible with the qtpyvcp/probe basic tool setter routines.
You can set your G54 (and other) WCS wherever you'd like, of course.
  • spumco
  • spumco
17 Oct 2024 02:21
Replied by spumco on topic Control Box Design
Control Box Design
Category: Milling Machines
I like SSR's, but I don't trust them as main disconnect (i.e. Estop) devices.  SSR's tend to fail closed, not open.  Even if you don't use a dedicated, guided-contact estop relay, a magnetic contactor between your overcurrent protection device(s) and everything else is a safe bet.
Final suggestion - draw your wiring diagram before you settle on a control panel layout.  It will help you internalize what voltages go where so your layout makes sense.
Plenty of times I've had to add a relay, or stuff some un-accounted-for component because I hadn't finalized the wiring.  Or run out of field connectors for IO, or other dumb stuff - like switching from steppers to servos in the middle of a build.
  • Vair8
  • Vair8
17 Oct 2024 02:03
Replied by Vair8 on topic Control Box Design
Control Box Design
Good point! I do have a handful of 40 amp solid state relays I didnt draw in there yet that I plan on adding for powering on and off along with a couple of switches. had a solidworks update but I'll redraw some stuff and post it again!
This panel will probably be behind the mill and I'll make a separate control panel where my computer sits that will have e-stop and the other goodies. Possibly something similar to this 3d printed estop switch combo that I made for a rocket thrust stand.
Seriously thank you all for the suggestions! always good to get another viewpoint!
  • spumco
  • spumco
17 Oct 2024 01:38
Control Box Design
Current power supply is a 48v 10 amp meanwell.
Here’s the motor and drivers I currently have.
12 Nm Stepper Online
Just a quick search for toroidal supplies, my driver is rated for 80v, I could possibly do a single 72v supply like this one.
1440W 72V
Your drives can take 110VDC, or 80VAC.  Antek has toroid transformers or complete toiroid PSU's with rectifiers and caps.
I'd suggest running as close to the max voltage your drives will permit - this will give you better performance at higher RPM.
A simple toroid will be easier to mount (see @Benb's post) than a complete PSU, and be cheaper, too.  Just be sure to check your supply voltage... in my case I'm averaging 240-245VAC, and my "100VDC" PSU from Antek is actually putting out ~104VDC.  Pretty close to my drive max.
So if you get a 78V toroid and your supply voltage is on the high side, you might over-volt your 80V drives.
I didn't see any contactors or other power-handling components (fuses, breakers, etc.) in your layout.  Are you planning to just use the main disconnect switch as your 'off' control?  Yank the plug out of the wall 'estop'?
Do you have a way to start LCNC, your controller, and IO without powering up your VFD and stepper drives?
Print out a page with your components and use a crayon or pen to draw the conductor/cable paths through everything.
VAC-IN -> disconnect -> beakers/fuses -> distribution block -> contactor(s) -> VFD & stepper PSU/transformer & 24vdc/5vdc PSU's for IO & controller
  • Benb
  • Benb's Avatar
17 Oct 2024 01:22
Replied by Benb on topic Control Box Design
Control Box Design
The left wire duct should be twice as large as the others, since it will have bunch of cable going through it from the bottom of the panel to the stepper drives. You will also need room for relays for those heavy loads. It is better to have extra space in the panel. We usually add 10% for unseen. The example below  is pictue of control panel that shows a spider nest of cables hanging on the left. Also, the 1inch or 1.5” wire ducts are too small, they look cut but not practical.However, I like the way the toroidal transformer is mounted.
17 Oct 2024 01:20
Replied by tommylight on topic MPS2000/Taig Mill Driver Issue
Category: Driver Boards
I am using 2.7 and it is running great but I tried to install 2.8 and the latest 2.9 and using the same settings from 2.7... both result in the motors running rough like the is electrical noise but swapping it back to 2.7 it runs sweat again?
Most probably due to latency issues as the 2.7 ISO used the RTAI kernel that has better latency on older PC's, while new LinuxCNC versions use the RT-Preempt version of the kernel that is better suited for new-er PC's.
I would stick with 2.7.
  • ant0ny
  • ant0ny
17 Oct 2024 00:51 - 17 Oct 2024 00:57
Replied by ant0ny on topic MPS2000/Taig Mill Driver Issue
Tommy,
Thanks but I fixed it... I noticed the socket pins loose when I plugged the Zplug in with the lid off... so I just swapped the sockets around and using the Aaxis socket plugged into the Z driver and it works again. So I have to assume it was just the connection.
I do have another weird issue though, maybe someone could shine a light on.
I am assuming it's to do with the drivers and maybe in step config I should be using something other then "other"
  • kennetek
  • kennetek
17 Oct 2024 00:28
Replied by kennetek on topic Axes no longer home/move
Checked all 16, all of them still read 27 ohm
  • Vair8
  • Vair8
17 Oct 2024 00:01
Control Box Design
1440W 72V
16 Oct 2024 23:26
Replied by tommylight on topic Control Box Design
Control Box Design
How many amps does the power supply have?
If the picture is anything to go by size vise, 2 should be enough, maybe, just maybe 1 ...
Displaying 19966 - 19980 out of 24214 results.
Time to create page: 0.729 seconds
