  • nartburg
  • nartburg
30 Sep 2024 07:23
Replied by nartburg on topic Mesa 7i96s pktUAT on P1
Category: Driver Boards
Perfect!
We established that P1 is Working and the on board rs-485 is working.
Now we can move on to the start:
How to implement pktUART on P1?
  • believerbuilds
  • believerbuilds
30 Sep 2024 06:58
Rebuilding linucnc for a robotic project was created by believerbuilds
Hi Community,
I’m a hobby developer, relatively new to CNC systems, and I’m working on a project where I plan to use LinuxCNC as the controlling software for a robotic component. My use case requires only a limited subset of the CNC functionality, and I’m planning to develop a custom UI for the system. However, I’m struggling to fully grasp how LinuxCNC operates as a system, especially regarding control flow.
I understand that communication happens through NML (Neutral Messaging Language), but so far, I’ve mainly seen the configuration files, scripts, and binaries. What I’m trying to figure out is how the control flows when I jog each axis — how does LinuxCNC communicate down the stack, from generating G-code to sending signals to the motors?
Could anyone point me toward the right resources or provide a simplified overview of the LinuxCNC control flow? Any guidance would be greatly appreciated!
Thanks in advance!
  • besriworld
  • besriworld
30 Sep 2024 06:47
Replied by besriworld on topic gmocappy clock
gmocappy clock
Category: Gmoccapy
For some reason, the pins are not being created.
net machine timer_4.machine_on <= halui.machine.is-on
net spindle timer_4.spindle_on <= halui.spindle.0.is-on
net running timer_4.running <= halui.program.is-running
After I commented them out, the program started, and I have a timer.
  • onceloved
  • onceloved's Avatar
30 Sep 2024 05:36
Replied by onceloved on topic new hardware trouble
Category: EtherCAT
There is also a simpler way to turn off eoe by modifying the parameters in the firmware
  • newbynobi
  • newbynobi's Avatar
30 Sep 2024 04:54
Replied by newbynobi on topic gmocappy clock
gmocappy clock
Category: Gmoccapy
Start LinuxCNC from terminal and watch for the output, you might see errors.
Norbert
  • cmorley
  • cmorley
30 Sep 2024 02:33
Replied by cmorley on topic Receiving GStat messages in GladeVCPs
Category: GladeVCP
This stems from the short coming of linuxcnc's status process or maybe better a lack of development of GUI communication process.
Gstat is an intermediate communication process between linuxcnc status and the GUi, that is easily modified/extended for the GUI needs.
If a single Gstat instance could be used/communicated to by all GUIs - that would be much better. You can kind of do this by using ZMQ etc to broadcast some data. I don't know if using ZMQ for all linuxcnc status would be fast enough. I was toying with adding it to HALUI as a test but again only some messages.
Or if linuxcnc's status was more easily extended and allowed GUIs to send messages that would be better too.
Chris
This is mostly beyond my programming skills.
30 Sep 2024 02:09
Replied by tommylight on topic Email Notification?
Email Notification?
Category: Forum Questions
Did you check the spam folder?
I did get the notification about your post just now as i get them for every post, and about 30% end up in spam, not in inbox, although they are originating from the same address. No idea why, except it's yahoo so it's a bit senile ! :)
  • Todd Zuercher
  • Todd Zuercher's Avatar
30 Sep 2024 01:26
Replied by Todd Zuercher on topic Email Notification?
Email Notification?
No, I didn't receive any notification.
  • Diegot
  • Diegot's Avatar
30 Sep 2024 00:55
Replied by Diegot on topic Latency and Graphics Card
I did some testing minths ago and have the same results.
With the Rt kernel, AMD graphics have the lowest latency numbers, with the onborad graphics disable into Bios.The onboard Intel ghaphics was 2a and the worst and I don't recommend to use was Nvidia cards. I teste one 1050 and a Quadro and the results are the same. For some reason the native drivers from Debian to Nvidia dont like the RT kernel, and I could no find a soluntion for it.
  • rodw
  • rodw's Avatar
30 Sep 2024 00:40
Replied by rodw on topic Showstopper Plasma Cutter retrofit
Category: Show Your Stuff
This is awesome Rod !!!! Great work.
I'm just about to begin on my next cnc plasma so we may be in touch again as we move forward with this.
Thanks, drop in any time. You know where to find me
  • RNJFAB
  • RNJFAB
30 Sep 2024 00:01
Replied by RNJFAB on topic Showstopper Plasma Cutter retrofit
  • vre
  • vre
29 Sep 2024 22:07
Replied by vre on topic New update on STMBL
New update on STMBL
this drive supports fanuc pulsecoders
siemens resolvers and biss-ssi encoders?
  • Benb
  • Benb's Avatar
29 Sep 2024 21:31
Replied by Benb on topic Button Toggle
Button Toggle
Category: HAL
Attached is a Function Block Diagram (FBD) and netlisting for toggling halui machine on/off. Since we are using FBD, signal names are insignificant in this case.  n.1 means net 1 ... etc. Hope this helps
# Load realtime Components and their counts
loadrt and2         count= 4
loadrt not            count= 4
loadrt or2            count= 2
loadrt toggle       count= 1
# Add functions to threads
addf and2.0                   servo-thread
addf and2.1                   servo-thread
addf and2.2                   servo-thread
addf and2.3                   servo-thread
addf not.0                      servo-thread
addf not.1                      servo-thread
addf not.2                      servo-thread
addf not.3                      servo-thread
addf or2.0                      servo-thread
addf or2.1                      servo-thread
addf toggle.0                 servo-thread
# Set parameters
setp toggle.0.debounce                           5
# Connect hal signals to hal component Pins
net gui.pb                     or2.1.in1
net halui.mc.is-on         halui.machine.is-on  not.2.in
net halui.mc.off             and2.3.out  halui.machine.off
net halui.mc.on             and2.1.out  halui.machine.on
net mc.pnl.pb                or2.0.in0
net n.1                          or2.0.out  or2.1.in0
net n.2                          toggle.0.in  and2.0.in0  and2.3.in1  or2.1.out
net n.4                          toggle.0.out  not.0.in
net n.5                          and2.2.in0  not.1.in  not.0.out
net n.6                          not.3.in  not.2.out  and2.1.in1
net n.7                          and2.0.in1  not.1.out
net n.8                          not.3.out  and2.2.in1
net n.9                          and2.0.out  and2.1.in0
net n.10                        and2.2.out  and2.3.in0
net pendant.pb             or2.0.in1
29 Sep 2024 20:55
Interesting/Useful Ryzen CPU Latency Results on Non-Hyperthreaded Cpus
Or get a used Dell or HP Z210 with parallel ports or headers, usually from 30 to 100$, built like tanks and never fail. Well they do, but very, very rarely.
  • besriworld
  • besriworld
29 Sep 2024 20:08
gmocappy clock
Category: Gmoccapy
Does this work with linuxcnc v2.9.3 ? I am trying to add this timer.But the panel is not created. After starting the program, linuxcnc creates the necessary file to store the times . am i doing something wrong or are there new files for this version
Displaying 20746 - 20760 out of 24439 results.
Time to create page: 0.474 seconds
