  • bertoldo
  • bertoldo
11 Sep 2024 16:33
Replied by bertoldo on topic Gmoccapy SCARA EtherCAT drive - joint error
Category: Gmoccapy
I'm trying to get my Scara to work with Ethercat too. However, so far in 3 months the only progress has been in finding the slave on the Raspberry Pi4 terminal.
How do I configure the LinuxCNC software from scratch so that the Scara robot can run with Ethercat? Could you give me some guidance?
  • bertoldo
  • bertoldo
11 Sep 2024 16:25
Replied by bertoldo on topic Scara tutorial
Scara tutorial
Hi, I'm also doing one with ethercat motors. I'm having a lot of trouble. I recently managed to communicate in ethercat and now I'm having trouble connecting ethercat instead of pulse in scara. Does anyone have any other links or manuals?
  • PCW
  • PCW's Avatar
11 Sep 2024 16:05
Replied by PCW on topic Following Error keeps creeping up
Yes, a good default P term for the stepgen  is 1/servo-period
so 1000 for a 1 mS servo period.
The physical meaning of a 1/servo-period P term is that any
measured position deviation is corrected by the next servo period
A P term higher than 1/servo-period will result in correction overshoots
A P term higher than 2/servo-period will result in oscillations.
Having a 0 P term will eventually cause following errors as the stepgen position
drifts due to small differences in the hardware and LinuxCNC clocks.
11 Sep 2024 15:39
Replied by tommylight on topic Following Error keeps creeping up
Depends on servo period, for 1 million it is 1000, for 2 million it is 500, and so on.
11 Sep 2024 15:38
Lcnc on LMDE6 with rt 6.1.0.18/20 -- realtek problem --- solved by krn. 6.10.6
Category: Installing LinuxCNC
Write and edit in a text editor of your choice, save, copy the on the forum click on "source" button, then paste.If you add pictures, do that first then click on "insert all" again after pressing source button, then add text.
  • Darium
  • Darium
11 Sep 2024 15:26 - 11 Sep 2024 15:27
Replied by Darium on topic Following Error keeps creeping up
I used the template from PnCconf for 7i96 and modify to fit 7i95
Those number was from that config
My host computer is a Rpi4 so the servo period is higher
The axis are driven by Yaskawa sigma 5 servo motors
What should the P value be for servo system?
  • bkt
  • bkt's Avatar
11 Sep 2024 15:21
@tommylight ..... html wisiwig is terrible on these sites .... if need to write a structured post and edit again, everytime all goes out of order ....  is possible change wisiwig editor?? think you use ckeditor .... not so used on drupal10 for these things I think .... on drupal8 and 9 have the same "problem" ..... Not check if kunema forum use drupal .... but seems same module.
Sorry everyone for criticism .... hope can be a positive suggestion istead ...
  • elovalvo
  • elovalvo
11 Sep 2024 15:12
  • crazycajun
  • crazycajun
11 Sep 2024 15:02
Replied by crazycajun on topic Probe Basic / Touch Probe
Well, i got a couple spare cards that should work. I ordered a case because the Inspiron has a slim and Nothing fits LOL
  • PCW
  • PCW's Avatar
11 Sep 2024 14:55
Configuration for Lathe Tool on 7i95t boards
Category: AXIS
Does the spindle encoder have single ended or differential wiring?
(and is the 7I95t spindle encoder input jumpered to match)
What is the maximum spindle RPM?
Do you get a precise 1.0000 increase in the spindle position for each forward turn of the spindle?
(watch spindle-revs)
Did you verify index operation:
watch spindle-index-enable then
sets spindle-index-enable 1
turn spindle slowly by hand
at the index position (and nowhere else)
spindle-index-enable should go false again
  • Unlogic
  • Unlogic
11 Sep 2024 14:52
Replied by Unlogic on topic Probe Basic / Touch Probe
That's Core 2 Duo/Quad era hardware.
Unfortunately the built in graphics in those chipsets don't support the required pixel shader version. So a separate graphics card needs to be installed.
I found that out myself last winter while CNC converting my mill...
  • crazycajun
  • crazycajun
11 Sep 2024 14:41
this is what dell has listed under the drivers: Intel G31/G33/Q33/Q35 Graphics Controller, v.7.15.10.1472, A00
i cant seem to find much since its so old. inspiron 545s, E5300 cpu.
  • thomasfbe
  • thomasfbe
11 Sep 2024 14:21
looking to buy a new custom built pc, anyone experience with the shop?
Hello! I’m looking into getting a new PC and came across a custom builder called Fenn Systems (they're from Belgium). The builds look great and the reviews are always good, but I’m wondering if anyone here has ordered a build from Fenn before, and specifically has experience with their shipping and service? Thanks for the help!
  • Unlogic
  • Unlogic
11 Sep 2024 14:14
So the integrated graphics arent good enough?
It depends on which integrated graphics you have, they come in many different varieties.
  • Unlogic
  • Unlogic
11 Sep 2024 14:09
Displaying 21466 - 21480 out of 24723 results.
Time to create page: 0.393 seconds
