  • PCW
  • PCW's Avatar
06 Sep 2024 20:37
Replied by PCW on topic Method for Zeroing a "c" axis
Category: Installing LinuxCNC
If you have a combined C axis/spindle, I think the position does really need to be
reset when going back into C mode (Ideally by homing to index or absolute position)
because if you simply do math on the accumulated spindle mode position, you will
eventually lose  position resolution as the position gets huge.
  • scottlaird
  • scottlaird's Avatar
06 Sep 2024 20:04
Replied by scottlaird on topic Beckhoff EK1828
Beckhoff EK1828
Category: EtherCAT
The EK1828 *should* work with recent versions of LinuxCNC-Ethercat. I have one of the other EK18xx models in a test system, and I'm petty sure it works.
  • jossen
  • jossen
06 Sep 2024 19:49
Beckhoff EK1828 was created by jossen
Beckhoff EK1828
Category: EtherCAT
Hello, I have a Beckhoff module that seems to be unsupported (EK1828)
I'm struggling to make this xml file and cannot figure out how it should be.
Is it possible to debug it? (It seems like I can write error in the file and LinuxCNC still open without any failures...)
Maybe some of you could look at my xml file, I have attached that and the other config files. I have also taken a output of ethercat slaves -v and ethercat pdos (I didn't get anything with the ethercat sdos)
  • jjdege
  • jjdege's Avatar
06 Sep 2024 19:36
Replied by jjdege on topic what am I missing ? no movement!
Category: EtherCAT
That line is fine as he is setting a signal not a pin:
thank you
sorry
i learned something new for me
  • crazycajun
  • crazycajun
06 Sep 2024 19:32
Replied by crazycajun on topic Keyboard mapping gmoccapy
i call it a game pad, its a touch mouse pad, mouse click, mini keyboard. same thing i assume.
  • Aciera
  • Aciera's Avatar
06 Sep 2024 19:26
Replied by Aciera on topic Keyboard mapping gmoccapy
For a gamepad you may want to have a look at the 'hal_input' component. Here is a little how to for keyboard. For a gamepad you would only need to modify the keyword in the 'loadusr' command line:
forum.linuxcnc.org/38-general-linuxcnc-q...s-in-gmoccapy#309096
You can then connect the gamepad pins to gmoccapy pins in the POSTGUI_HALFILE:
linuxcnc.org/docs/html/gui/gmoccapy.html#_jog_hal_pins
  • Aciera
  • Aciera's Avatar
06 Sep 2024 19:18
Replied by Aciera on topic what am I missing ? no movement!
Category: EtherCAT
linuxcnc.org/docs/stable/html/hal/basic-hal.html#sub:hal-setp
  • M4MazakUser
  • M4MazakUser
06 Sep 2024 19:09
Replied by M4MazakUser on topic Method for Zeroing a "c" axis
Yeah, I'm just using a cheap stepper drive but it does have an encoder built in so it dosent loose steps, I ran it yesterday for hours running in the gear teeth drive. And the gear engage command would do the g10 l20, so it should be accurate. I'll be testing this next week.
The bit that has me currently is converting 8.5674 etc to eight point five six seven four revolutions, and getting rid of the eight.
  • Aciera
  • Aciera's Avatar
06 Sep 2024 19:09
Post GUI HAL not loading and "Bad character '[' used" error on E-Stop
Category: QtPyVCP
Certainly works for me:
github.com/Sigma1912/LinuxCNC_Demo_Confi...ort_no_twp_reset.ngc
with this in the [RS247NGC] section of the ini:
 ON_ABORT_COMMAND = o <on_abort_no_twp_reset> call
  • machinedude
  • machinedude's Avatar
06 Sep 2024 18:40
What do you really get for a $350 desk top engraver ?
Category: Show Your Stuff
So i have been looking at a lot of belt drive idea's after doing this build. i have been playing around with a open ended reduction idea's and think i have something that would work and get a lot more from a smaller width belt. the down side to belts when you have some forces at play are what i believe to be minor flexing of the belt engagement into the drive pulley, belts just are not rigid like a ball screw in this respect so you either have to go to a wider belt or figure out a way to get more surface contact with the smaller belt.
Tommy i know how you do your reductions and i have looked at your designs quite a bit. The omega configuration on the open-ended side is a good way to get a few extra teeth engaged and is the basic configuration on my build minus the reduction. what i have built works mostly because the motors are oversized for the size of the machine. Keeping the design simple was a good base line to see what works and spot the tiny issues. for me it's surface finish between step downs
the idea i want to test is something like a serpentine belt reduction for open ended belts that would do away with the closed loop belt reduction on the drive shaft of the omega configuration that i see you using. my thoughts with a serpentine configuration is you end up with a lot more surface area in contact with the toothed pulley's which i would think would translate to a stiffer drive system.
I did some rough sketches to see what kind of footprint it would have and it seemed pretty compact  doing a 3 to 1 reduction with 3mm pitch belt. roughly 4.5 inched by 7.5 inches.
  • PCW
  • PCW's Avatar
06 Sep 2024 18:26
Replied by PCW on topic 7i95 sserial port as gpio
Category: HAL
With standard firmware P1 is all GPIO regardless of driver settings
man hostmot2
For GPIO setup information
(GPIO starts up as inputs so pins used for outputs
must be set into output mode)
Note that the P1 pins are 5V tolerant but have 3.3V output levels
Suggest using a cheap parallel port breakout if you want buffered 5V levels
  • ekbiker
  • ekbiker
06 Sep 2024 18:23
Replied by ekbiker on topic 7i95 sserial port as gpio
Category: HAL
I need 5V outputs. I'll drive some low power relays using these GPIO's.
  • RLA
  • RLA
06 Sep 2024 17:44
Replied by RLA on topic Debian 12 Bookworm Update problem
Hi...got the same result as posted above...below is pasted result...do I need to reinsert usb that had ISO?
sudo apt update
Ign:1 cdrom://[Debian GNU/Linux 12 _Bookworm_ - Snapshot amd64 LIVE/INSTALL Binary 20240721-21:05] bookworm InRelease
Err:2 cdrom://[Debian GNU/Linux 12 _Bookworm_ - Snapshot amd64 LIVE/INSTALL Binary 20240721-21:05] bookworm Release
Please use apt-cdrom to make this CD-ROM recognized by APT. apt-get update cannot be used to add new CD-ROMs
Hit:3 www.linuxcnc.org bookworm InRelease
Get:5 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease [1,575 B]
Err:5 download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease
The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project <science:EtherLab@build.opensuse.org>
Hit:4 repository.qtpyvcp.com/apt develop InRelease
Reading package lists... Done
E: The repository 'cdrom://[Debian GNU/Linux 12 _Bookworm_ - Snapshot amd64 LIVE/INSTALL Binary 20240721-21:05] bookworm Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: download.opensuse.org/repositories/science:/EtherLab/Debian_12 ./ InRelease: The following signatures were invalid: EXPKEYSIG A94819A7CB97A204 science:EtherLab OBS Project
ra@debian:~$ sudo apt update
[sudo] password for ra:
Hit:4 www.linuxcnc.org bookworm InRelease
Hit:3 repository.qtpyvcp.com/apt develop InRelease
ra@debian:~$ sudo apt upgrade
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remo
  • COFHAL
  • COFHAL
06 Sep 2024 17:35
Ethercat installation from repositories - how to step by step
Category: EtherCAT
I have a question: I have already installed ethecat and linuxcnc-ethercat. With the command sudo systemctl status ethercat.service I see that the service is running. With the command ethercat master I try to see which master is configured and I get the error: Failed to obtain number of masters: ioctl() version magic is differing: /dev/EtherCAT0: 37, ethercat tool: 30
The question is: do I necessarily have to have a device connected that supports ETHERCAT to confirm that I have everything installed correctly, or why does this error appear and how to solve it?
06 Sep 2024 17:27
Replied by tommylight on topic Debian 12 Bookworm Update problem
sudo apt update
then
sudo apt upgrade
Displaying 21766 - 21780 out of 24851 results.
Time to create page: 0.364 seconds
