  • crazycajun
  • crazycajun
05 Sep 2024 16:26 - 05 Sep 2024 16:36
First time linux cnc user - no stepper movement.
I cam from a "working" mach3/uc100 setup over to a 7i96s setup. K4030 drivers. terminal pings the mesa board. I have dir +/- and step +/- wired to the k4030 and 7i96s. a cell phone charger to power the 5v of the 7i96s.
steppers dont move. i have no limit switches hooked up yet and i configured the settings to not need to home first.
i tried connecting the 24/36v psu ground to com on the 7i96s, i tried connecting the 7i96s 5v to the dir + & step + (which is how mach3 was configured; and the dir/step - was 2 pins on the serial board).
when i connected 5v to dir/step +, and started linuxcnc, i did get "unexpected real time delay on task0 with period 1000000"
what do i have wrong?
once i get this figured out im going to make a video on all of this to help me next time and others. i have been on the struggle bus thus far.
side note, with just the 5v input and dir/step +/- hooked up, i get 5.09v between gnd & 5v, i get 5.09v between step + & gnd, i get .23v between dir - & gnd, and dir + to gnd i get 4.81v. on unused step/dir ports its the same except i dont get the .23v reading, its 0 instead.
  • Todd Zuercher
  • Todd Zuercher's Avatar
05 Sep 2024 16:12
Replied by Todd Zuercher on topic install over version 2.8
Category: Installing LinuxCNC
Details and instructions for updating from 2.8 to 2.9 are covered in the doccumention. I don't think there were any significant configuration changes, and none that would be incompatible with a 2.8 config.
linuxcnc.org/docs/stable/html/getting-st...dating-linuxcnc.html
I don't think there are or were any changes in Classiclader for version 2.9
Change log for 2.8 to 2.9 is here.
linuxcnc.org/2023/11/04/LinuxCNC-2.9/
  • Vorms
  • Vorms
05 Sep 2024 15:53
install over version 2.8 was created by Vorms
Hello, I would like to know if it'a possible to install the new version over the version 2.8 ?
Are config files compatible ?
Is the classic ladder compatible ?
Is the gui of the classic ladder better in version 2.9 ?
what are the main difference of the new version ?
Best regards
Thierry Vorms
  • Traken
  • Traken
05 Sep 2024 15:40
7i76e step dir signal missing for stepgen type 0
Category: Driver Boards
https://ibb.co/HCckPX5this is my driver's manualhttps://ibb.co/HCckPX5
  • Traken
  • Traken
05 Sep 2024 15:37
Ok, I increased the step time and set it to type 0, it works, but I set everything to 10000
  • juliankoenig87
  • juliankoenig87
05 Sep 2024 15:27
Replied by juliankoenig87 on topic durchmesser stimmt nicht
Category: Other User Interfaces
Hi.
Teile mal deine Tooltable. Also entweder screenshot oder die Textdatei.
Das Kalibrieren ist entscheidend. Ich habe das so programmiert, dass der tolltable Durchmesser nur für Sicherheitsfeatures relevant ist. Alles andere erfolgt durch die Klaibrierung.
Julian
  • PCW
  • PCW's Avatar
05 Sep 2024 15:18
Its most likely a hal file setting thats wrong: The step length
  • Traken
  • Traken
05 Sep 2024 15:15
How can I diagnose why it's not type 0? Maybe it's the Ethernet cable's fault?
  • PCW
  • PCW's Avatar
05 Sep 2024 15:03
All modes work (0,1,2), but the steplength setting
only  affects the step length in modes 0 and 1.
  • Traken
  • Traken
05 Sep 2024 14:52
Is this correct for it to work on stepgen type 2?
  • PCW
  • PCW's Avatar
05 Sep 2024 14:45
Maybe you have the step length too short for the scope to catch
  • juliankoenig87
  • juliankoenig87
05 Sep 2024 14:41
Replied by juliankoenig87 on topic What does CMM machines use in software
Hi.
I recently wrote some macros for a pyvcp panel. Tilman and I called it easyprobe. (github->hausen8->easyprobe) In the newest version I implemented a routine to measure as many points one like an write the values in a txt file.
So yes. One xould build some kind of panel or screen and get some usefull results. Maybe of intrest.
Best regards
Julian
  • Traken
  • Traken
05 Sep 2024 14:41
Yes i see signal type 2 step length 5us
  • PCW
  • PCW's Avatar
05 Sep 2024 14:39
Do you see a signal with type 2?
What is the step length set to?
  • mighty_mick
  • mighty_mick's Avatar
05 Sep 2024 14:34
Displaying 21856 - 21870 out of 24869 results.
Time to create page: 0.401 seconds
