  • Aciera
  • Aciera's Avatar
25 Aug 2024 18:44 - 25 Aug 2024 18:47
Replied by Aciera on topic İnstall glade
İnstall glade
Category: Gmoccapy
Shouldn't be much different from a hal_button,
open panel in glade add 'HAL_ToggleButton' and assign some ID (eg 'hal_togglebutton1') to it, save
Start config, open 'Halshow' and the pin should be visible as 'testpanel.hal_togglebutton1'
25 Aug 2024 18:23
Replied by Cant do this anymore bye all on topic Editing Bitfile on 7i97t for extra smart serial connections
Category: Driver Boards
Ahh I messed up there my apologies.
  • _skinner
  • _skinner
25 Aug 2024 18:18 - 25 Aug 2024 18:26
Replied by _skinner on topic Raspberry Pi 4 with Mesa 7c81
I'll appreciate it. I'd like to connect via P1 because i leave it for encoders in future and time has come (based on other users experience). I already use P2 and P7 for communication with mx4660.I've tried to add configuration to pncconf but TXEN2 TXDATA2 and RXDATA2 don't want appear, do someone know what I'm doing wrong?
Thats what inside file:
    ['7c81-Internal Data', '7c81', '7i77 + MX4660X2', '7c81', 'hm2_rpspi',
         7,3, 0,0, 1,1, 0,0, 4,2, 1,2,[],0,0,0,0,0,0,0, 1, 57, 100, 200,[1,2,7],
        # TAB 1
        [S.TXEN2,0],[S.TXDATA2,0],[S.RXDATA2,0],[S.SS7I77M1,0],[S.RXDATA1,0],[S.SS7I77M0,0],[S.RXDATA0,0],[S.MXES,0],[S.MXE0,0],[S.MXE1,0],
        [S.MXEI,0],[S.MXE0,1],[S.MXE1,1],[S.MXEI,1],[S.MXE0,2],[S.MXE1,2],[S.MXEI,2],
        [S.NUSED,0],[S.NUSED,0],[S.NUSED,0],[S.NUSED,0],[S.NUSED,0],[S.NUSED,0],[S.NUSED,0],
        # TAB 2
        [S.GPIOI,0],[S.PWMP,0],[S.STEPA,0],[S.GPIOI,0],[S.STEPB,0],[S.STEPA,4],[S.STEPA,1],[S.GPIOI,0],[S.STEPB,1],[S.STEPA,2],
        [S.STEPB,2],[S.STEPA,3],[S.STEPB,3],[S.ENCA,7],[S.ENCB,7],[S.ENCI,7],[S.GPIOI,0],
        # TAB 7
        [S.GPIOI,0],[S.GPIOI,0],[S.GPIOI,0],[S.GPIOI,0],[S.GPIOI,0],[S.GPIOI,0],[S.GPIOI,0],[S.GPIOI,0],[S.GPIOI,0],[S.GPIOI,0],
    # TAB 5
    [S.TXDATA0,0],[S.TXEN0,0],[S.RXDATA0,0],[S.NUSED,0],
        [S.NUSED,0],[S.NUSED,0],[S.NUSED,0],[S.NUSED,0],[S.NUSED,0],[S.NUSED,0],[S.NUSED,0], [S.NUSED,0],[S.NUSED,0],[S.NUSED,0],
    # TAB 6
    [S.TXDATA1,0],[S.TXEN1,0],[S.RXDATA1,0],[S.NUSED,0],
        [S.NUSED,0],[S.NUSED,0],[S.NUSED,0],[S.NUSED,0],[S.NUSED,0],[S.NUSED,0],[S.NUSED,0], [S.NUSED,0],[S.NUSED,0],[S.NUSED,0],],
  • Moutomation
  • Moutomation
25 Aug 2024 17:51
Replied by Moutomation on topic İnstall glade
İnstall glade
Category: Gmoccapy
This is great now. I'm using the test panel you sent. I can see the normal buttons in Hallshow. However, Toogle buttons are not visible in Hallshow. Can you teach me this too?
  • besriworld
  • besriworld
25 Aug 2024 17:47
Replied by besriworld on topic Amplifier Fault ECT60 Closed Loop
Category: EtherCAT
"MAX_ACCELERATION = 5000 "
try with less acceleration ...
  • Aciera
  • Aciera's Avatar
25 Aug 2024 17:42
İnstall glade
Category: Gmoccapy
Open the panel in glade, insert a button, add 'on_destroy' to the 'released' signal (not sure about the exact signal name but it should be fairly obvious)
  • Moutomation
  • Moutomation
25 Aug 2024 17:25
İnstall glade
Category: Gmoccapy
How should I follow to save when I press the save button?
  • Moutomation
  • Moutomation
25 Aug 2024 17:24
İnstall glade
Category: Gmoccapy
I have no idea how to make the save button
  • Aciera
  • Aciera's Avatar
25 Aug 2024 17:21
İnstall glade
Category: Gmoccapy
There is nothing that will automatically save in case of a powercut, so you will have to do with a save button. Not sure about the shutdown procedure as that usually requires elevated privileges.
  • Moutomation
  • Moutomation
25 Aug 2024 17:16
İnstall glade
Category: Gmoccapy
Can gmoccapy be closed first and then the computer shut down when a button is pressed on the machine? If such a thing is possible, data can be recorded in this way.
  • Moutomation
  • Moutomation
25 Aug 2024 17:13
İnstall glade
Category: Gmoccapy
Sometimes people using the machine cut off the electricity by directly turning off the button of the machine. Automatic saving after values ​​change. Or can I add a separate save button?
  • Aciera
  • Aciera's Avatar
25 Aug 2024 17:02
İnstall glade
Category: Gmoccapy
Why do you want this?
This is only if you wanted to catch a <ctrl>+c in the terminal it has no effect in gmoccapy.
  • Aciera
  • Aciera's Avatar
25 Aug 2024 16:44
Replied by Aciera on topic durchmesser stimmt nicht
Category: Other User Interfaces
Probe_postgui.hal:22: Pin 'halui.mdi-command-00' does not exist
ini Datei unter [HAL] diese Zeile hinzufügen:
HALUI = halui
Ich gehe davon aus, dass du dies immernoch in deiner ini hast:
[HALUI]
MDI_COMMAND = G54
MDI_COMMAND = G55
MDI_COMMAND = G56
MDI_COMMAND = G57
MDI_COMMAND = G58
MDI_COMMAND = G59
MDI_COMMAND = G59.1
MDI_COMMAND = G59.2
MDI_COMMAND = G59.3
MDI_COMMAND = O <probe_toolchange>  CALL [1]
MDI_COMMAND = O <probe_toolchange>  CALL [2]
MDI_COMMAND = O <probe_toolchange>  CALL [3]
MDI_COMMAND = O <probe_x_plus>      CALL
MDI_COMMAND = O <probe_x_minus>     CALL
MDI_COMMAND = O <probe_y_plus>      CALL
MDI_COMMAND = O <probe_y_minus>     CALL
MDI_COMMAND = O <probe_z_minus>     CALL
MDI_COMMAND = O <probe_pocket>      CALL
MDI_COMMAND = O <probe_operations>  CALL [1]
MDI_COMMAND = O <probe_operations>  CALL [2]
MDI_COMMAND = O <probe_operations>  CALL [3]
MDI_COMMAND = O <probe_manual_set>  CALL [0]
MDI_COMMAND = O <probe_manual_set>  CALL [1]
MDI_COMMAND = O <probe_manual_set>  CALL [2]
MDI_COMMAND = O <probe_manual_set>  CALL [3]
MDI_COMMAND = O <probe_escape>      CALL
MDI_COMMAND = O <probe_calibration> CALL
  • Moutomation
  • Moutomation
25 Aug 2024 16:39
İnstall glade
Category: Gmoccapy
I tried but I couldn't do it. How can I run this code to save with ctrl+c?
By default, the reaction of GladeVCP to a Ctrl-C event is to just exit - without saving state. To make sure that this case is covered, add a handler call on_unix_signal which will be automatically be called on Ctrl-C (actually on the SIGINT and SIGTERM signals). Example:
def on_unix_signal(self,signum,stack_frame):
print("on_unix_signal(): signal %d received, saving state" % (signum))
self.ini.save_state(self)
  • karlhe
  • karlhe
25 Aug 2024 16:03
Replied by karlhe on topic durchmesser stimmt nicht
Hallo,
leider immer noch ein fehler..
karlhe
Displaying 22531 - 22545 out of 24900 results.
Time to create page: 0.436 seconds
