İnstall glade
24 Aug 2024 09:29 #308523 by Moutomation
Replied by Moutomation on topic İnstall glade
wonderfull thanks a lot
25 Aug 2024 16:39 #308609 by Moutomation
I tried but I couldn't do it. How can I run this code to save with ctrl+c?
By default, the reaction of GladeVCP to a Ctrl-C event is to just exit - without saving state. To make sure that this case is covered, add a handler call on_unix_signal which will be automatically be called on Ctrl-C (actually on the SIGINT and SIGTERM signals). Example:
def on_unix_signal(self,signum,stack_frame):
print("on_unix_signal(): signal %d received, saving state" % (signum))
self.ini.save_state(self)
25 Aug 2024 17:02 #308611 by Aciera
Replied by Aciera on topic İnstall glade
Why do you want this?
This is only if you wanted to catch a <ctrl>+c in the terminal it has no effect in gmoccapy.
25 Aug 2024 17:13 #308612 by Moutomation
Sometimes people using the machine cut off the electricity by directly turning off the button of the machine. Automatic saving after values ​​change. Or can I add a separate save button?
25 Aug 2024 17:16 #308613 by Moutomation
Can gmoccapy be closed first and then the computer shut down when a button is pressed on the machine? If such a thing is possible, data can be recorded in this way.
25 Aug 2024 17:21 #308614 by Aciera
There is nothing that will automatically save in case of a powercut, so you will have to do with a save button. Not sure about the shutdown procedure as that usually requires elevated privileges.
25 Aug 2024 17:24 #308615 by Moutomation
I have no idea how to make the save button
25 Aug 2024 17:25 #308616 by Moutomation
How should I follow to save when I press the save button?
25 Aug 2024 17:42 #308617 by Aciera
Open the panel in glade, insert a button, add 'on_destroy' to the 'released' signal (not sure about the exact signal name but it should be fairly obvious)
25 Aug 2024 17:51 #308619 by Moutomation
This is great now. I'm using the test panel you sent. I can see the normal buttons in Hallshow. However, Toogle buttons are not visible in Hallshow. Can you teach me this too?
Moderators: newbynobi, HansU
Time to create page: 0.283 seconds
