  • acondit
  • acondit
16 Aug 2024 18:50
5i25/7i76 analog spindle control on Lathe spindle
Category: Basic Configuration
spindle-vel-cmd-rps is positive but spindle-vel-fb-rps is negative.
Should I use spindle-vel-fb-rps-abs???
So it seems that the comparison is destined to fail at the moment,
there is some (significant) difference in the value of the commanded vs reported speed.
If I can get it compare positive to positive maybe I can figure out the correct scale.
  • garthnoakes
  • garthnoakes
16 Aug 2024 18:48
Replied by garthnoakes on topic LED to indicate M3/M5 status
Category: GladeVCP
Where I'm struggling is with the widgets - managed to get a label and led onto a fixed window - but I can't figure out how to move them. They seem to only resize
  • PCW
  • PCW's Avatar
16 Aug 2024 18:38 - 16 Aug 2024 18:40
Mesa 7i96s firmware for Index (2.9 release)
All normal 7I96S firmware supports index on the encoder.
Did you mean stepgen index support?
  • PCW
  • PCW's Avatar
16 Aug 2024 18:27
qtplasmac (Operation Error: hm2/hm2_7i76e.0:) in middle of cut
Category: Plasmac
That should do it (until you reboot)
you can verify with
ethtool -c enp0s25
You might retry the ping test
  • chernogorsky
  • chernogorsky
16 Aug 2024 18:12 - 16 Aug 2024 18:34
Replied by chernogorsky on topic [QTDragon] blocking in hal_manualtoolchange dialog
Category: Qtvcp
Basically I have configured
o<pnc_tc_manual> call
which I want to run several times (manually) during the dialog
Jogging routin - as far as I understood it :
I press pause for jogging
do jogging / (in my case tool change)
press ok/cancel for the spindle speed up (not needed)
but it broke the procedure, means it does not work properly with auto_toolsetup
so the question is - is there a way of modifying the standard dialog by adding another button properly (like add some file in handled folder)
or its just easier to create my own hal based on hal_manualtoolchange with additional button
Added
so what Im aiming now - find a way of modify class ToolDialog(LcncDialog, GeometryMixin): from dialog_widget.py inside  custom qtdragon_hd_handler.py (or similar mechanism)
  • RLA
  • RLA
16 Aug 2024 17:53
Open Configuration tool issue was created by RLA
Category: Configuration Tools
Hi...new to linux here ...bought 7i96s and have powered but when trying to open Mesa Configuration tool...which I think I need as everything looks so foreign coming from mach 3...but when I open in debian I get error " Dependency is not satisfiable: Python 3 packaging.??
Thanks for any help,
Rick
  • karlhe
  • karlhe
16 Aug 2024 17:53
Replied by karlhe on topic löschen fehlerhafter topics
Category: Deutsch
meine topics, zumindest die unnötigen...
danke
  • karlhe
  • karlhe
16 Aug 2024 17:50 - 17 Aug 2024 10:20
Replied by karlhe on topic easyprobe linuxcnc
easyprobe linuxcnc
Category: Installing LinuxCNC
hallo aciera,
danke, das werde ich morgen ausprobieren...
 habe das augeführt,leider immer noch Fehler. Dann habe ich die probe_postgui.hal leer gemacht. Jetzt startet die Maschine und die probe icons sind zu sehen.Da die probe_postgui.hal leer ist, kann man die button aber nicht aktivieren, sie lösen nichts aus.Wenn ich die postgui einfüge, kommt wieder der Fehler..
Anhang Foto meine maschine und die postgui.hal
  • RMJ fabrication
  • RMJ fabrication
16 Aug 2024 17:27
Category: Plasmac
Did I do these steps correctly? Do I have IRQ coalescing disabled now?
  • vibram
  • vibram
16 Aug 2024 17:04
Hello,
I'm looking for firmware for Mesa 7i96s with Index pin (release 2.9)
I followed Talla83 tutorial on Efinity but I have no clue how to implement the Index stuff.
Thanks a lot for your support
  • cmorley
  • cmorley
16 Aug 2024 16:56
Category: Qtvcp
One cannot run MDI commands while in auto mode. When the tool change dialog pops up, you are still in auto mode.
Jog while paused is also not really available, though you can use an external offsets hack to get around that.
These are limits of linuxcnc not QtDragon.
So if that is what you need to do, the abort/restart hack is the only method I know that could work. (To be clear a dialog will pop up for automatic restart, but I haven't tested this feature in a long time.)
If the MDI commands are movements and are the same each time maybe a remap could cover it. Tell use more about that part please.
Chris
  • Aciera
  • Aciera's Avatar
16 Aug 2024 16:46 - 16 Aug 2024 16:47
Replied by Aciera on topic Troca de ferramenta em linha
I'm doing a tool change but I need to do the following
when tool m6t1 is on the spindle it has to go back to the same
place where it was removed to pick up T2, how do I do this?
If I understand correctly you have a rack toolchanger. Maybe this helps:
forum.linuxcnc.org/20-g-code/36441-anyon...-length-probe#131714
  • Aciera
  • Aciera's Avatar
16 Aug 2024 16:38
Replied by Aciera on topic 3 Achs Fräse mit MESA 7C80 und Raspi 4
Category: Deutsch
Ändere mal diese Zeile in deiner hal:
sets spindle-at-speed true
zu (musst noch deinen Eingangspin mit dem FU Signal einfügen)
net spindle-at-speed           <=  <dein_eingangs-pin>
  • HPW
  • HPW
16 Aug 2024 16:28 - 16 Aug 2024 16:30
Replied by HPW on topic 3 Achs Fräse mit MESA 7C80 und Raspi 4
Category: Deutsch
Hallo.
Meine 3 Achs Fräse läuft jetzt. Homing funktioniert. Referenzschalter sind eingebaut und funktionieren. Handrad funktioniert (fast). Jetzt möchte ich noch, dass spindle-at-speed mit einem Eingang verknüpft wird, der gesetzt wird (high) wenn die Zielfrequenz der Spindel am FU anliegt. Wie mache ich das? Mein FU schaltet ein Relais durch und damit liegt auf einem Eingang 24V an. Das Signal kommt an und der Eingang wird auch geschaltet. Nur wie mache ich jetzt die Verknüpfung zu spindle-at-speed?
Hat mir da jemand einen tipp?
LG
Hans Peter
  • PCW
  • PCW's Avatar
16 Aug 2024 16:24
Replied by PCW on topic Mesa 7I92TM Parallel port pin mapping
Category: PnCConf Wizard
Most common reason for lack of step/dir motion
is too short step lengths, So you might try doubling
those. Also check that the direction pin  to the step drive
changes state when jogging in either direction to verify
that the pinout is correct and that the  breakout board is
working as  expected.
Displaying 23011 - 23025 out of 25004 results.
Time to create page: 1.395 seconds
