  • RotarySMP
  • RotarySMP's Avatar
31 Jul 2024 11:39
Replied by RotarySMP on topic Weiler 160 CNC Retrofit
Category: Show Your Stuff
Wow, that is a sweet machine. It sure makes sense to modernise machines like that rather than converting manual machines. If the analog drivers still work, this could be a really simple retrofit. Like I did with my Maho. Not having to touch mechanical aspects of the machine can save you a ton of time getting it up and running.
How did Weiler do the home/end switches on this one?
  • Mecanix
  • Mecanix
31 Jul 2024 11:39
The EDA I'm forced to use at work is win11 based. I know I know...
However my entire dev environment aka compilers, IDEs, ect, are all Debian/linux based. No substitute ;)
If you aren't friend with fine pitch then avoid the LV9QN88 part. Not much better than the ICE40UP5K to say the least. I'm with you though, prefer their LQFP pinouts...
  • Muftijaja
  • Muftijaja
31 Jul 2024 11:38
Replied by Muftijaja on topic Latency Test OK, dennoch Fehlermeldung
Category: Deutsch
Hi rodw, thanks for this hint. I havethis line in my hal file: Is that sufficient?loadrt hm2_eth board_ip="10.10.10.10"With the following settings the connection works at once:
My ping to 10.10.10.10:
What do you think about it?
THanks, Arno
  • rodw
  • rodw's Avatar
31 Jul 2024 11:33
Ethercat installation from repositories - how to step by step
Category: EtherCAT
Hi
waiting for a more suitable solution
I solved it almost like zylos146.
I searched and deleted all the ethercat-dkms folders, including the .deb
then I downloaded ethercat-stable-1.6 from
gitlab.com/etherlab.org/ethercat
followed the installation from install.md everything went well.
then I performed the standard installation here
it no longer returns errors
Hi
Not quite out of the woods. the changes were pushed to the LInuxcnc code on github.
I built a new image. The keys have been fixed but I am getting a dkms erorr so no joy.
I've updated the issue upstream, gitlab.com/etherlab.org/ethercat/-/issues/131
so hopefully  they will fix it soon. They have always beeen very good to me :)
  • meister
  • meister
31 Jul 2024 11:33
WOW   very nice !!!
I recently tried to build a board with an ICE40UP5K, but I'm somehow too stupid to get it to work :( The FPGA chips are just too small for me to solder them by hand.
It would be cool to have a complete rio board without having to use a plug-on devboard .
I just saw that you use Windows, rio unfortunately only runs under linux, vm is also ok, if it works in WSL I can't say unfortunately
  • Aciera
  • Aciera's Avatar
31 Jul 2024 11:28 - 31 Jul 2024 11:32
Replied by Aciera on topic Trying to update to Linuxcnc 2.9
Category: Installing LinuxCNC
'trying to overwrite' errors indicate a conflict with another package.
This worked for me:
sudo dpkg -P linuxcnc-doc-en
  • Mecanix
  • Mecanix
31 Jul 2024 11:26
First contrib; Feel free to replicate/publish/flame/others. Great liltle working-but-simple fpga dev board.
Schematic attached.
  • PhilipME
  • PhilipME's Avatar
31 Jul 2024 11:24 - 31 Jul 2024 11:31
I have full version of debian 12.6 installed on my machine
Do not enter a root password, if you do sudo is disabled and you won’t be able to complete the following steps
Interresting
I thought when I entered a password, I will be able to sudo
  • Mecanix
  • Mecanix
31 Jul 2024 11:18
I don't know what to say, that was too kind Meister. Thank you so much for taking the time.
I'm working off a GW1N-LV9QN88 part (custom dev board). Schematic and pcb mostly inspired from the infamous TangNano9K and so I have a good feeling this won't be too difficult to port hardware-wise.
Let me set-up, clone, learn your work during the coming days. As soon as I have a successful IDE compile/project I'll share it with you to upload on your repo.
So excited about this already. Thank you again. I'll update progress!
  • AndriySM
  • AndriySM
31 Jul 2024 10:57
Category: EtherCAT
jjdege .Thank you, I'll try to do that this evening, I hope to succeed
  • meister
  • meister
31 Jul 2024 10:51
@meister
Do you happen to have LinuxCNC-RIO ported for the Gowin IDE? I'd like to explore your awesome work however would be willing to do so in an environment that I'm semi-familiar with already (i.e. Gowin IDE).
Thanks, yes gowin toolchain is supported, it even generates a project file for the IDE.
However, it is easier (at least for me) to work without an IDE, so you are not so tied to one manufacturer.
Since everything is more or less generated here, an IDE is only suitable for troubleshooting and playing around
If so can you link me to a branch or point me in the correct direction to get started please. That'd be super cool.
ps. Goal; retrofit a co2 laser (stepper 3ax, 1 rot, 3 limit switches). Hardware at hand; gowin littlebee serie fpga
for new projects, the best branch is here:
github.com/multigcs/riocore/tree/dev
littlebee is not yet directly supported, but if there is a GW1N-9 on it, it should be no problem to use the TangNano9k configs as a template
copy the file: riocore/boards/TangNano9K.json to riocore/boards/LittleBee.json and edit it (type/family/clock-pin/speed), set toolchain to gowin
than copy riocore/configs/TangNano9K/config-uart.json to riocore/configs/LittleBee/config-uart.json and edit it (boardcfg and the pins / you can also remove all plugins and leave only the uart and blink for first tests)
then you can generate the Gateware with:
clear ; PYTHONPATH=. bin/rio-generator riocore/configs/LittleBee/config-uart.json
if all works, you will find a project file for gowin-ide here: Output/LittleBee/Gateware/rio.gprj
31 Jul 2024 10:30
Replied by tommylight on topic Can LinuxCNC work on a Rotary Transfer Machine?
Pretty sure something like that can be done with LinuxCNC, as almost all motions are unique and repeat all the time, so each station has a single motion to do.
Probably most can be done with separate stepgens or siggens and some hal fiddling to ensure the tools are in place before moving the main part holder.
Add a VCP for editing values tools have to move and....
This is from back when i started using LinuxCNC and thinking what can be controlled by it, so just stuff in my head as i never had a chance to try and build such a machine.
  • Mecanix
  • Mecanix
31 Jul 2024 10:15
@meister
  • Aciera
  • Aciera's Avatar
31 Jul 2024 10:08 - 31 Jul 2024 10:12
Ah, I see.
I'm afraid not. LinuxCNC is not multi-channel capable so it cannot synchronize axes moving along different tool paths at the same time.
[edit]
The only way this could work would be to use a different installation of LinuxCNC for each station and synchronize the program execution using digital IO
  • jjdege
  • jjdege's Avatar
31 Jul 2024 10:07 - 31 Jul 2024 10:21
Category: EtherCAT
Hi
Hi
Displaying 24196 - 24210 out of 25068 results.
Time to create page: 0.461 seconds
