  • OT-CNC
  • OT-CNC
26 Jul 2024 02:56
Replied by OT-CNC on topic Yaskawa incremental encoder and Mesa 7i48
Category: Driver Boards
If you are looking to drive this motor with a generic drive, in my case an AMC AB30A200I, I gave up on the UTOPI encoder and fitted a US digital EC35 that has digital hall with 8 pole option. It works smooth CW/CCW just past 3000 rpm but have possible torque ripple at very slow rpm. I was getting the same slow speed behavior with the stock encoder. Is this possibly due to trapezoidal commutation? Drive manufacturer couldn't enlighten me further...
The test setup uses another encoder in the video, disregard that. You can hear the clicking and I'd like to know if that's normal with trapezoidal commutation.
I wanted to share this in case you are thinking of going a similar route. I'm just not 100% happy with the outcome.
  • OT-CNC
  • OT-CNC
26 Jul 2024 02:11
Replied by OT-CNC on topic 7i77 encoder split to amp and servo
I ended up using the encoder y board from mesa which seems to be working fine with the addition of having swapped the servo drive to an isolated version.
  • OT-CNC
  • OT-CNC
26 Jul 2024 01:58
Replied by OT-CNC on topic 7i77 isol
7i77 isol
I wanted to report back that the solution here was to switch to an isolated version of the amc servo drive.
In addition I have added chockes/toroids as suggested.
  • vre
  • vre
26 Jul 2024 01:13
how to make my own custom page for qtdragon_hd?
Category: Qtvcp
How can add a latch button with led like the flood on/off and mist on/off from qtdesigner?
26 Jul 2024 01:07
difference between machine coordinate systems and CAD software
Category: AXIS
Your fist picture = you are looking at the part from behind, any particular reason for it?
Moving table and moving head are two different types of machines, despite being the same functionally, but very different when looking at them and using them, i have a feeling you are mixing these.
  • onceloved
  • onceloved's Avatar
26 Jul 2024 00:41
xyzab to xyzac was created by onceloved
xyzab to xyzac
Category: QtPyVCP
How to convert the B axis to the C axis? Including pictures. The default is XYZAB. I need XYZAC.
  • my1987toyota
  • my1987toyota's Avatar
26 Jul 2024 00:35
Replied by my1987toyota on topic Mostly 3D Printed CNC Foam cutter
Category: CNC Machines
 spend half hour looking for something you found a few days earlier with the same exact name, nothing, zero, zilch,! All those have become like PMS with mood swings! :)
couldn't help but laugh at that one
  • rodw
  • rodw's Avatar
26 Jul 2024 00:22
Possibility of a Retrofit on Alcor 220CNC
Mesa Cards have seperte MPG inputs (5 v signal) Often  only 2 but I'm sure different firmware can add a third at the expense of some inputds
Ref: linuxcnc.org/docs/stable/html/examples/mpg.html
(Example is Single MPG  with multiple axis select but easy to make it for a single axis.)
  • rodw
  • rodw's Avatar
26 Jul 2024 00:11
Category: AXIS
I think your X axis needs to be rotated in F360 so its the same direction of the machine movement.
  • PCW
  • PCW's Avatar
25 Jul 2024 23:46
Replied by PCW on topic RCpwmgen
RCpwmgen
The RCPWM outputs 0..3 are on DB25 pins 6,7,8,9
with 7i96s_5abobrcd.bin firmware. These are fast 5V
CMOS buffered outputs on the common Mach 5 axis BOB
P1-01/DB25-01          34   IOPort       PWM              1        PWM             (Out)
P1-02/DB25-14          35   IOPort       None
P1-03/DB25-02          36   IOPort       StepGen          5        Step/Table1     (Out)
P1-04/DB25-15          37   IOPort       None
P1-05/DB25-03          38   IOPort       StepGen          5        Dir/Table2      (Out)
P1-06/DB25-16          39   IOPort       None
P1-07/DB25-04          40   IOPort       StepGen          6        Step/Table1     (Out)
P1-08/DB25-17          41   IOPort       None
P1-09/DB25-05          42   IOPort       StepGen          6        Dir/Table2      (Out)
P1-11/DB25-06          43   IOPort       RCPWM            0        PWM             (Out)
P1-13/DB25-07          44   IOPort       RCPWM            1        PWM             (Out)
P1-15/DB25-08          45   IOPort       RCPWM            2        PWM             (Out)
P1-17/DB25-09          46   IOPort       RCPWM            3        PWM             (Out)
P1-19/DB25-10          47   IOPort       None
P1-21/DB25-11          48   IOPort       None
P1-23/DB25-12          49   IOPort       None
The 7I96S requires Efinix's Efinity toolset to compile new bitfiles
  • Project_Hopeless
  • Project_Hopeless's Avatar
25 Jul 2024 23:33
Replied by Project_Hopeless on topic RCpwmgen
RCpwmgen
Ok, I think I know the issue, The firmware I'm using has the rcPWM on the Mach 3 BOB P11 an opto output.  Should be on P1 the PWM for the BOB ???
Is Xilinx Design Suite still used to compile firmware for the 7i96s?
  • Muftijaja
  • Muftijaja
25 Jul 2024 23:23
Replied by Muftijaja on topic Linuxcnc 2.9 startet nicht mehr ??
Category: Deutsch
Thanks a lot, PCW! That worked great!
Greetings, Arno
  • spumco
  • spumco
25 Jul 2024 23:02
Replied by spumco on topic Carousel Toolchanger
I'm using a stepper in position command for my ATC, where carousel.countes-target drives the stepgen.nn.position-command.  That's the basic connection between carousel and a position-mode motor.
Unfortunately, I'm not expert in LCNC enough to know if there's a similar way to connect carousel.comp to an analog torque or velocity-mode servo.  I can see why you're inclined to stick with the ATC-axis scheme.
Can you post your config files, including the toolchange ngc files?
Also - what servo motor and drive is being used?  Just asking, as maybe there's an alternative command signal available that doesn't require a massive wiring change.
  • PCW
  • PCW's Avatar
25 Jul 2024 23:00 - 25 Jul 2024 23:01
Replied by PCW on topic Linuxcnc 2.9 startet nicht mehr ??
Category: Deutsch
Start linuxcnc from the command line,
(by typing "linuxcnc" in a terminal window)
select the desired configuration, click
the "Create Desktop Shortcut" check box,
and then hit OK
Displaying 24571 - 24585 out of 25133 results.
Time to create page: 0.395 seconds
