  • cmorley
  • cmorley
21 Jul 2024 19:08
Replied by cmorley on topic Spindle Inhibit while Probing.....
Category: Qtvcp
Since versa probe is part of the screen you must connect pins in a _postgui_ HAL file.
Did you do that?
Since you are using the optional spindle-raise-on-pause, (which uses spindle.0.inhibit) you must add an OR component so either 'spindle pause' or 'probe installed' will inhibit the spindle.
  • jg00163206
  • jg00163206's Avatar
21 Jul 2024 19:05
Replied by jg00163206 on topic watchdog and network connection problems
Category: Installing LinuxCNC
here it is after a reset of the mesa 7i96s
ip a ;
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host noprefixroute
2: enp4s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether a4:1f:72:67:47:1f brd ff:ff:ff:ff:ff:ff
inet 10.10.10.1/8 brd 10.255.255.255 scope global enp4s0
inet6 fe80::a61f:72ff:fe67:471f/64 scope link proto kernel_ll
3: wlp3s0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue state UP group default qlen 1000
link/ether 9c:2a:70:32:72:49 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.106/24 brd 192.168.1.255 scope global dynamic noprefixroute wlp3s0
valid_lft 42120sec preferred_lft 42120sec
inet6 2603:7080:e936:2933::12d8/128 scope global dynamic noprefixroute
valid_lft 603721sec preferred_lft 603721sec
inet6 fd00:f405:95cf:605a::12d8/128 scope global dynamic noprefixroute
inet6 fd00:f405:95cf:605a:bc86:6ca6:e17a:1d65/64 scope global temporary dynamic
valid_lft 603722sec preferred_lft 84841sec
inet6 fd00:f405:95cf:605a:9e2a:70ff:fe32:7249/64 scope global dynamic mngtmpaddr noprefixroute
valid_lft 604775sec preferred_lft 604775sec
inet6 2603:7080:e936:2933:6b4b:639:ebcd:c3eb/64 scope global temporary dynamic
inet6 2603:7080:e936:2933:9e2a:70ff:fe32:7249/64 scope global dynamic mngtmpaddr noprefixroute
inet6 fe80::9e2a:70ff:fe32:7249/64 scope link noprefixroute
still not able to ping
  • bkt
  • bkt's Avatar
21 Jul 2024 19:03 - 23 Jul 2024 06:18
LMDE6 change default gcc to gcc9
quite and fast question .... linuxcnc work quite well ... now need to dowgrade to gcc9 from stndard gcc12 .... can i have some problem compilingf for example a new custom kinematics?
Ask these because sees all new kernel request for running linuxcnc 2.9.1, 2.9.2 and 2.10 have as default minimum gcc10 ..... and never try install lcnc 2.9.2 in a system with less than gcc9 .....
  • jg00163206
21 Jul 2024 19:01
this machine will work for a few days in Axis gui and then stops communicating. Resource temporarily unavailable. no communication lights on the rj45 connector on the mesa 7i96 and unable to ping 10.10.10.10. i didn't change anything. im also having some other communication problems within Axis when it was running. my servo spindle will have a long delay before linuxcnc tells it to turn on. minutes agter i turn it on, it comes on. i checked the wiring. its the same issue ive been having. its not new. a reinstall of the os would be a work around but ultimatley, that doesn't fix anything. i am not getting the watchdog error light(red light on the mesa 7i96s. )
here is ip a;
2: enp4s0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc mq state DOWN group default qlen 1000
valid_lft 42363sec preferred_lft 42363sec
valid_lft 603964sec preferred_lft 603964sec
valid_lft 603965sec preferred_lft 85084sec
valid_lft 604537sec preferred_lft 604537sec
destination unreachable with ping.
  • andypugh
  • andypugh's Avatar
21 Jul 2024 18:55
Replied by andypugh on topic 4 axis foam cutter configuration
Category: AXIS
Don't try to fix this by shuffling the axes. Leave the system set up as XYUV.
As far as I can tell your issue is purely with the display on the screen?
Try editing glnav.py around line 444. (on a very slow connection on a train, can't check where the file is, but probably /usr/share/linuxcnc
The self.lat and self.lon numbers set the view in sperical coordinates. So set htese to alter the orientation of the default perspective view.
It's a Python file, so no need to recompile. Thogh you may need to restart linuxcnc.
  • CHEROKEE-Laredo
  • CHEROKEE-Laredo
21 Jul 2024 18:42
Brauche bitte Hilfe bei der Steuerung des Werkzeugrevolvers
Category: Deutsch
Hallo Olli
Leider beginnt beim Homing der Motor sofort zum drehen, du müstest den Zylinder manuell betätigen.
Beim Werkzeugwechsel wird das Magnetventil durch das Unterprogramm
o<Ventil_an> sub
M66 P0 (Eingang ob Druck ausreichend ?)
M64 P0 (Ausgang setzen für Ventil an)
G4 P2
o100 if [#5399 EQ -1] (Stop falls kein Druck. M0)
(DEBUG,STOP: kein Druck!)
(DEBUG,Druckluft einschalten dann weiter mit Start oder Programm abbrechen! Crash Gefahr!)
M0 (Porgrammstop, mit Start geht es weiter)
o100 endif
betätigt.
  • Roguish
  • Roguish's Avatar
21 Jul 2024 18:05 - 21 Jul 2024 18:07
Replied by Roguish on topic Spindle Inhibit while Probing.....
Category: Qtvcp
Chris,
still not working.......fixing typos is good, but what about the logic ????
see both images.
also, If i add   qtversaprobe.probe-loaded   to a .hal file loaded through the .ini, qtdragon fails to start with './spin.hal:2: Pin 'qtversaprobe.probe-loaded' does not exist'  error.
so, how, exactly, should this be coded in .hal ???  and how loaded ???
I do appreciate your efforts.
note:  after your change, I do a git pull, and a complete rebuild and install
  • WKS-3D
  • WKS-3D's Avatar
21 Jul 2024 18:04
Category: Deutsch
Danke für den Tipp.
Bin bei dem Video fast eingeschlafen
Ich habe das alles soweit übernommen was er da gemacht hat, aber das scheint sich mit meiner Konfiguration nicht zu vertragen:
loadrt [KINS]KINEMATICS
loadrt hostmot2
loadrt hm2_eth board_ip="10.10.10.10" config="num_encoders=6 num_pwmgens=0 num_stepgens=5 sserial_port_0=1000000x"
setp   hm2_7i92.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.z,pid.s
Ich brauche also leider eine andere Lösung
  • robforbes
  • robforbes
21 Jul 2024 17:47
Lag in MPG response after updating from 2.7 to 2.9
I have been using individual step jogging
Rob
  • stirra
  • stirra
21 Jul 2024 16:49
4 axis foam cutter configuration was created by stirra
Category: AXIS
I have a rebuilt 4-axis foam cutter working with 2.9.3, but I would like to change how it is displayed in Axis.  The default display is XY; UV, with the wire vertical.  In reality, the axes are YZ; VW, with the wire horizontal.  I have tried changing all occurrences of XYUV to YZVW in the axis_foam.ini simulation, which does not give any error messages, but no change is visible in the Axis preview.  It still shows the UV plane above the XY plane with the wire between.
Any suggestions on how to achieve this?
Thanks,
-- Ralph
  • PCW
  • PCW's Avatar
21 Jul 2024 16:34 - 21 Jul 2024 16:58
Replied by PCW on topic RCpwmgen
RCpwmgen
Category: Driver Boards
The store should be back online (had to update the DNS so make take a while to propagate)
In the mean time, this should work:
freeby.mesanet.com/software/parallel/7i96s.zip
  • CHEROKEE-Laredo
  • CHEROKEE-Laredo
21 Jul 2024 16:32
Category: Deutsch
Hallo Olli
Prima das Dein Zylinder Sensoren hat.Leider können wir nicht meine HAL nehmen weil ander Voraussetzungen vorliegen. Schaue Dir mal folgendes Video an
Wichtig ist die Klemmung der Achse.
Gruß Josef
  • Project_Hopeless
  • Project_Hopeless's Avatar
21 Jul 2024 16:29
Replied by Project_Hopeless on topic RCpwmgen
RCpwmgen
Under MesaCT I don't see that particular firmware as an option, and none have rcpwm.
When I go to the Mesa site to download that firmware it comes up "account suspend"!
Is there another location to grab firmware files?
  • besriworld
  • besriworld
21 Jul 2024 16:11 - 21 Jul 2024 16:12
Replied by besriworld on topic Mesa Configuration Tool
Category: Configuration Tools
I am trying to unlock the spindle menu.  Without success .  I am trying to make an example configuration for a closed loop spindle with a +-10V PWM/Dir signal   With maximum error protection - Maximum difference between set rpm and actual rpm . The spindle is a servo motor.
  • PCW
  • PCW's Avatar
21 Jul 2024 16:08
Replied by PCW on topic Aktuelle hardware mit PCI
Category: Deutsch
Das Problem ist, dass der 5I25 für den Betrieb mit 5 V und 3,3 V ausgelegt ist PCI-kompatible Motherboards haben also Steckplätze für beide Arten von Motherboards Tasten. Wie tommylight sagt, ist dies in einem normalen Fall in Ordnung, in dem Sie nicht Stecke es rückwärts ein, aber eine Gefahr mit einem Adapter. Schade, dass die PCI SIG Die Tasten symmetrisch gemacht.
Displaying 24766 - 24780 out of 25232 results.
Time to create page: 0.441 seconds
