  • esmurf
  • esmurf
02 Jun 2025 09:47
Replied by esmurf on topic ethercat-conf.xml pdoentry limits?
Category: EtherCAT
is this the <initcmd> tag?
  • Hakan
  • Hakan
02 Jun 2025 09:02
Replied by Hakan on topic ethercat-conf.xml pdoentry limits?
Category: EtherCAT
I don't know that, but if you have static data you can set that using the SDO instead.
  • esmurf
  • esmurf
02 Jun 2025 08:58
Category: EtherCAT
These servos have so many functions and parameters, that 10 is a really small limit.
Is there a way to split the pdoentry tags into multiple pdos?
Or change them during operation, e.g. have a different ethercat-conf.xml during homing vs. normal operation?
  • Hakan
  • Hakan
02 Jun 2025 08:11 - 02 Jun 2025 08:52
Category: EtherCAT
It is not uncommon for devices to have a limit on how much data they can exchange.
But do you need all of those PDOs? I guess not.
So just delete the ones you do not use from ethercat-conf.xml
  • Aciera
  • Aciera's Avatar
02 Jun 2025 07:35 - 02 Jun 2025 07:47
Replied by Aciera on topic Position: relative expected
Seems that there may actually be two printouts on the same line:
'joint 0 following error'
which comes from motion
'position: relative commanded'
which seems to come from the Axis GUI:
github.com/LinuxCNC/linuxcnc/blob/6f7753...s/tcl/axis.tcl#L1838
You are not giving us much else to go on. Are you getting getting following errors on joint 0 when using other Gcode or is it only with this particular program?
  • esmurf
  • esmurf
02 Jun 2025 07:32
ethercat-conf.xml pdoentry limits? was created by esmurf
Category: EtherCAT
i have the attached ethercat-conf.xml (for stepperonline A6 servos).
Each time i add more than 10 pdoentry tags, i get the following error in /var/log/messages:
Jun  2 09:04:11 cnc kernel: EtherCAT ERROR 0-1: SDO download 0x1A00:0B (4 bytes) aborted.
Jun  2 09:04:11 cnc kernel: EtherCAT ERROR 0-1: SDO abort message 0x06090011: "Subindex does not exist".
Jun  2 09:04:11 cnc kernel: EtherCAT WARNING 0-1: Failed to map PDO entry 0x60FD:00 (32 bit) to position 11.
Jun  2 09:04:11 cnc kernel: EtherCAT WARNING 0-1: Currently mapped PDO entries: 0x6041:00/16 0x6061:00/8 0x6064:00/32 0x606C:00/32 0x6077:00/16 0x60BA:00/32 0x60BC:00/32 0x60B9:00/16 0x603F:00/16 0x60F4:00/32 0x60FD:00/32. Entries to map: 0x6041:00/16 0x6061:00/8 0x6064:00/32 0x606C:00/32 0x6077:00/16 0x60BA:00/32 0x60BC:00/32 0x60B9:00/16 0x603F:00/16 0x60F4:00/32 0x60FD:00/32
Jun  2 09:04:11 cnc kernel: EtherCAT WARNING 0-1: Failed to configure mapping of PDO 0x1A00.
Jun  2 09:04:11 cnc kernel: EtherCAT 0: Domain 0: Working counter changed to 3/12.
Jun  2 09:04:13 cnc kernel: EtherCAT ERROR 0-1: Failed to set SAFEOP state, slave refused state change (PREOP + ERROR).
Jun  2 09:04:13 cnc kernel: EtherCAT ERROR 0-1: AL status message 0x001E: "Invalid input configuration".
Jun  2 09:04:13 cnc kernel: EtherCAT 0-1: Acknowledged state PREOP.
If i remove / comment out any one pdoentry, the error goes away.
master idx="0" has no error, idx="1" - idx="3" have the error.
There seems to be a limit of max 10 entries?
How can i work around this?
  • Kieran
  • Kieran
02 Jun 2025 04:11
GUI that somewhat resembles haas or fanuc workflow.
Hey yall. Im a machinist by trade. I initially learned cnc on linuxcnc about 10y ago. Now I run "Real" cnc machines using fanuc and Haas. Initially I missed linuxcnc, but now when I go back and use my little linux mill, I am annoyed by the tool table and just the "PC" feel in general. The Fanuc soft keys are actually super nice and you can quickly go between work offsets, tool offsets ect. I can for example go to my absolute position page, do some mental math, type a number in the control, switch pages to my offsets, and input+ that number in seconds to quickly set offsets and stuff. No need for a mouse or anything silly like that. Hass is very similar but its even better with dedicated buttons to kick into the offsets or positions pages. Honestly the mouse is a major pain in a shop environment. The fanuc/Hass button based interaction is crazy fast for me compared to scrolling around on linuxcnc. suggestions? also itd be nice to get rid of the X Y tool offset and just have length/wear and diameter/wear. is there an "industrial GUI" im missing out on?
  • PCW
  • PCW's Avatar
02 Jun 2025 02:41
Mesa card issues Maho MH800E Retrofit Project
Can you post the terminal log?
( start Linuxcnc from the terminal and copy-paste the messages printed )
The previous error indicated an issue with a (probably USB) input device like a MPG
I would create  a configuration without the added input device to get past this error
for now
  • Cooped-Up
  • Cooped-Up
02 Jun 2025 02:13
Replied by Cooped-Up on topic Mesa card issues Maho MH800E Retrofit Project
I have spent some more time trying to troubleshoot why I cant launch the software, I cant seem to figure out where I am going wrong, I have it real barebones. I am sure I am configuring something wrong I just cant get past the error message when I click the launch icon. it tells me to look at the inputs config or whatever but I am not even sure what that is. I think I am supposed to enter a serial port number somewhere for setting the mode that the 7i77 is in but I cant find that in the hal or ini file...
  • langdons
  • langdons
02 Jun 2025 01:03
Replied by langdons on topic Position: relative expected
"[sic]" Love that!
Someone needs to work on their German (not you).
Still better than the plethora of typos in this license file: mipav.cit.nih.gov/license/CopyrightInfo.html
Pretty concerning that US government screwed up on basic English writing.
  • BlownCorona
  • BlownCorona
01 Jun 2025 21:40
Replied by BlownCorona on topic Mesa 7i97T & LinuxCNC setup struggles
Category: Installing LinuxCNC
Thanks everyone, ill dig into the above suggestions.
And yes, i should have been a little clearer, im not worried about the following error stuff, i was just happy to be seeing signs of life.
  • h_munktell
  • h_munktell
01 Jun 2025 20:45 - 01 Jun 2025 20:48
Replied by h_munktell on topic Dust Collection Shoe with independent Z control
Ok, think I have figured it out, most of it at least. Had to make a visual representation of the HAL finnstrom posted. See attachement. Also got it sort of working on my machine. Tanks so much!Some things I'll try to adopt
  • Instead of controlling with coolant-mist, I would do it with a motion.digital-out pin controlled with M62 and M63
  • Trying to get the w_offset from actual w0 in current coordinate system. My thought is to touch of both Z to the work piece, and set w0 in G54 (for example) at the desired height. Then, somehow in HAL, calculate the w0 offset from w joint zero. In the (unlikely) event that I need dust shoe for G55 etc, this should enable this to work.
  • In conjunction with above, I think I need jogging to work (in qtdragon) to easy set w0 current coordinate system.
  • akim14
  • akim14
01 Jun 2025 20:14
LinuxCNC Dual-Head Gantry Setup Assistance Request
Thank you so much I am still having problems setting up the limit and home switches in the main hal , I used mesa CT here are my files, I noticed you used the code down below but i cant seem to replicat it without error
# --- MIN-HOME-X ---
net min-home-x <= hm2_5i25.0.7i77.0.0.input-00-not
# --- MAX-X ---
net max-x <= hm2_5i25.0.7i77.0.0.input-01-not
# --- MIN-HOME-Y ---
net min-home-y <= hm2_5i25.0.7i77.0.0.input-02-not
# --- MAX-Y ---
net max-y <= hm2_5i25.0.7i77.0.0.input-03-not
# --- MIN-Z ---
net min-z <= hm2_5i25.0.7i77.0.0.input-07-not
# --- MAX-HOME-Z ---
net max-home-z <= hm2_5i25.0.7i77.0.0.input-06-not
# --- MIN-W ---
net min-w <= hm2_5i25.0.7i77.0.0.input-05-not
# --- MAX-HOME-W ---
net max-home-w <= hm2_5i25.0.7i77.0.0.input-04-not
# --- X_READY ---
#net X_Ready <= hm2_5i25.0.7i77.0.0.input-08
# --- Y_READY ---
#net Y_Ready <= hm2_5i25.0.7i77.0.0.input-09
# --- Z_READY ---
#net Z_Ready <= hm2_5i25.0.7i77.0.0.input-10
# --- W_READY ---
#net W_Ready <= hm2_5i25.0.7i77.0.0.input-11
# --- Z_SPINDLE_RUNNING ---
net Z_Spindle_running <= hm2_5i25.0.7i77.0.0.input-12 => and2.0.in0
# ---setup home / limit switch signals---
net min-home-x => axis.0.home-sw-in
net min-home-x => axis.0.neg-lim-sw-in
net max-x => axis.0.pos-lim-sw-in
  • kworm
  • kworm
01 Jun 2025 18:00
Replied by kworm on topic Merging operations NGC files Fusion 360
Category: CAD CAM
You are correct I have a paid license. I used to use the free version some time ago and I don't remember it having that limitation but I know they have made multiple license changes over time for the free version which is unfortunate. Glad to see you have made a solution to work around it.
I don't use axis but this post may be similar to what you are looking for:
forum.linuxcnc.org/20-g-code/36186-use-m...messages-my-solution
  • poesel
  • poesel
01 Jun 2025 17:46
Position: relative expected was created by poesel
I'm trying to run a little test program, and it aborts with the fault message: 'Motor 0 Positionssfehler (sic!) Position: relativ erwartet' ('motor 0 positioning error position: relative expected').
The program is this:
(G90: Set to Absolute Positioning)
G90
(G94: Feed Rate Mode Units per Minute)
G94
(G17: Select XY plane for arc moves for G2 G3)
G17
(G21: Set Units to Millimeters)
G21
(G54: Select coordinate system 1)
G54
G1 X0 Y0 F1000
G1 X10 Y0
G1 X10 Y10
G1 X0 Y10
G1 X0 Y0
M30
I'm a bit surprised since I'm setting G90. What am I doing wrong?
Thanks!
P.S. little typo: 'Positionssfehler' should be 'Positionsfehler'
Displaying 2521 - 2535 out of 24961 results.
Time to create page: 0.209 seconds
