  • mille5
  • mille5
01 Jun 2025 06:52
Replied by mille5 on topic Compensation between B and C with moveoff?
Hello Aciera, thanks for the reply.
I haven't had anything to do with the kinematics module yet. I'll stick with the experiment in the HAL for now.
(but ​​that will definitely happen sometime...)
I've been experimenting a bit with "moveoff-external." With a fixed offset value, it looks quite promising.
Now it's about creating a variable from the B-axis value to put it into mv.offset-in-4 (C-axis).
For the calculation, I'll use mult2 with a fixed constant of 1/51
mv.offset-in-4 = mv.pos-3 * (1/51)
I've looked at some values ​​in the HAL show and I'm not quite sure which would be the best:
bpos-cmd, bpos-rel, or mv.pos-3.
I'll play around a bit more.
Best regards,
Kai
  • Hakan
  • Hakan
01 Jun 2025 05:55 - 01 Jun 2025 05:56
Replied by Hakan on topic Huanyang GT Series VFD Issues
If standard Modbus works one can wonder why there is a hal componenet for this vfd?
The old Huanyang vfds use something similar to but not quite Modbus so there it is needed.
  • unknown
  • unknown
01 Jun 2025 04:51
Replied by unknown on topic Using the preinstalled vnc server
Category: Installing LinuxCNC
Yeah I'd take what that user says with a grain of salt, unfortunately he can be a little unreliable or completely off the mark.
Try this command to see what is installed
dpkg -l | grep vnc
  • kubes
  • kubes
01 Jun 2025 04:16
Replied by kubes on topic Huanyang GT Series VFD Issues
Confirmed is a SW issue.
I replaced the hy_gt_vfd driver with mb2hal, which is a generic modbus HAL component, no HW changes, and it works.
  • amir73
  • amir73
01 Jun 2025 03:43
Replied by amir73 on topic QtDragon Customize
QtDragon Customize
Category: Qtvcp
nice....thanks
  • PCW
  • PCW's Avatar
01 Jun 2025 03:42 - 01 Jun 2025 03:45
Replied by PCW on topic Mesa modbus and pktUart
Category: Other User Interfaces
For configurations with specific daughtercards, the daughtercard
name is included in the file name and you can use the .pin file
to determine the content and pinout of the firmware, for example
the 7i76eu_7i76x1_pktv2d.pin file shows that the configuration
includes a V2 PktUART ( the TX and RX halves )
  • SebastianM
  • SebastianM
01 Jun 2025 03:23
Replied by SebastianM on topic Mesa modbus and pktUart
Thx.
Just out of curiosity…
Is there an overview what all those firmwares do / are meant for?
Or how could I have found that out myself?
Regards
  • PCW
  • PCW's Avatar
01 Jun 2025 03:17
7i76eu_7i76x1_pktv2d.bin
Would be the correct firmware
You will also need to update LinuxCNC to the lastest version
sine the hm2_modbus driver is quite new.
  • SebastianM
  • SebastianM
01 Jun 2025 01:42
Replied by SebastianM on topic Using the preinstalled vnc server
this post says that vnc is preinstalled.
forum.linuxcnc.org/38-general-linuxcnc-q...time?start=30#328405
however - thx for your feedback, I will just manually install one.
  • SebastianM
  • SebastianM
01 Jun 2025 01:29
thank you.
I know I need to update / flash my 7i76eu.
The "bundle" from your webpage contains 20+ different firmware files... I would assume that 7i76eud.bin/pin are the correct ones, right? (for a standalone 7i76eu without any extensions)
01 Jun 2025 01:29
How to refresh the Axis screen after setting offsets G10 L20
Category: AXIS
G10 L20 P0 X0 Y0 \  %halcmd setp axisui.refresh 1
This should work for 2.8 and up, notice the hal command at the end for refreshing the Gremlin (plotter).
  • bondglen
  • bondglen
01 Jun 2025 00:51
Category: AXIS
Thanks. With you and juliankoenig and the links, I have plenty to work with.
I really appreciate you guys taking time to reply and share your knowledge.
  • bondglen
  • bondglen
01 Jun 2025 00:48
Category: AXIS
Not really what I wanted, but I think it will work.
Thanks for the link to the example code.
Thanks for your help.
01 Jun 2025 00:34
Replied by tommylight on topic Using the preinstalled vnc server
I recall there was chat about including it, i was against it as it is a huge security risk and not required for machine control.
If it is included, it does require setting up the password for VNC explicitly, at least it did 10 or more years back.
  • epineh
  • epineh
01 Jun 2025 00:20 - 01 Jun 2025 00:22
The ICE40 module is very nice, unfortunately for us living in Australia the $34 module has an $86 shipping fee, then converted to AUD it will be close to $190 AUD...the ECP5 kit will land here for about $100, and has a lot more IO.
When you say programming the ECP5 is slow, is that via USB within Riocore and are we talking minutes or half an hour ? I can stock extra coffee !
Cheers.
Russell.
Displaying 2611 - 2625 out of 24952 results.
Time to create page: 0.256 seconds
