  • Farmerted
  • Farmerted
27 May 2025 14:15
Replied by Farmerted on topic How to set up parallel port in Debian
Thanks, I went through referenced thread, not sure I understood any of it.
I have an Asix Electronics Corporation AX99100 PCIe to Multi I/O Controller (prog-if 03 [IEEE1284]),
If there are known cards I could buy I’d rather buy a known working card.
This is for a CNC machine, so just the first step of many.
Thanks,
Ted
  • npostma
  • npostma's Avatar
27 May 2025 14:15 - 27 May 2025 17:32
Protecting My Mesa 7i76EU: Wiring Questions for Home Sensors and Touch Probe
Category: Basic Configuration
Ofcourse!
I've included them as an attachment.
I hope you have some good insights into my setup.
Thanks in advance.
EDIT:
I now also use the following step timing:
DIRSETUP   = 500
DIRHOLD    = 500
STEPLEN    = 1000
STEPSPACE  = 1000
STEP_SCALE = 1000
In addition, I changed the |DISPLAY|MAX_VELOCITY and the |TRAJ| VELOCITY settings. I have also increased the other velocity limits accordingly.The machine is now performing better than ever!
Surprisingly, I'm no longer getting any following errors—I'm not entirely sure why, but I’m definitely not complaining. ?Thanks to everyone for the input and suggestions!
  • cmorley
  • cmorley
27 May 2025 13:00
Replied by cmorley on topic QTDragon_hd with mechanical dial tool setter
Category: Qtvcp
QtDragon has not put any extra effort to facilitate a manual setter, but I don't see why you couldn't use one. Could you describe the process you wish to use for setting tool length?
  • ihavenofish
  • ihavenofish
27 May 2025 12:48
  • iastate_tka
  • iastate_tka
27 May 2025 12:35
Omron/Generic Ethercat Driver - Communications Synch Error
Category: EtherCAT
Hi there,
Not sure how much help I can be as I've never gotten the 83 error before. I did find this on the forum, not sure if you've seen it ( www.forum.linuxcnc.org/ethercat/45007-et...hen-exiting-linuxcnc ) but it only applies to exits.
If you'd like I can run upstairs later today and grab my config files to share, although I don't think I really messed with them much beyond the PID from the files tpa58 shared.
  • langdons
  • langdons
27 May 2025 12:32
Spindle Speed Settings only from file, no MDI possible?
Does the Chinese VFD still work?
Is there any downside to it compared to the Hitachi?
AFAIK, Hitachi has not made elctronics for a long time.
How old is this thing?
  • langdons
  • langdons
27 May 2025 12:25
installing linuxCNC 2.7.14 under Hyper-V Manager
Category: Installing LinuxCNC
Using Hyper-V is probably a bad idea.
QEMU will probably be better.
Though you will get awful latency compared to a bare-metal install.
  • Muftijaja
  • Muftijaja
27 May 2025 12:23
Hello Community,
many things are working nowadays with  Linuxcnc 2.9.2 with Probe Basic on a MESA 7i76e. But:
A few weeks ago I had to change my Hitachi VFD because it had no 10V output for spindle supply from the beginning. I sent it to service in April and I had to get the 10V from a separated power supply, this worked fine with a chinese VFD for the time the Hitachi VFD was in service.
Last week the Hitachi came back from service, the 10V Out was working, but surprisingly I cannot make MDI speed commands any more. I set S6000 or S12000, press Enter, in the spindle display on the right side 22000 occurs and I can press FWD Button but nothing happens.
IN the HALSHOW there is
0 at spindle-out
0 at spindle.0.speed.out
0 at spindle.0.on
0 at spindle.0.forward. Tested with S6000, S12000 S24000.
All this worked fine with the chinese VFD before.
So, I thought my 7i76e card is burnt up (I did not change any of my HAL or INI files since I sent my Hitachi away), but surprisingly further experiments could deny that.
Speed instructions from a file are working as they should. E.g. my warmup file - spindle turns in the right direction, right speed, right display down right.
Parameters are the same in the Hitachi as before.
Do you have any idea what could have happened here? I'm totally clueless...
Thanks for any hint and help!
Hanno
HAL and INI Files:
File Name: Hanno_Nr5_...5-27.hal
File Size:12 KB
File Name: Hanno_Nr5_...5-27.ini
File Size:6 KB
  • Todd Zuercher
  • Todd Zuercher's Avatar
27 May 2025 11:47
Replied by Todd Zuercher on topic Mecanumeric MF2040 LI retrofit (Pantograph)
Category: Milling Machines
Presuming there is nothing wrong with the original servo systems, then usually the best option is to reuse them. You will need to figure out how the existing cnc controlled the servos. If they were using step/dir signals then the 7i76e should be a good option for the retrofit. If the servos were commanded using analog signals or some other way (such as some kind of serial bus), then some other hardware might be more appropriate.
  • zz912
  • zz912's Avatar
27 May 2025 11:28
Replied by zz912 on topic versa-probe vs probe_screen_v2.9
Category: Gmoccapy
What is the difference between your psng and lib/python/gladevcp/builtin-panels/versa-probe ?
  • my1987toyota
  • my1987toyota's Avatar
27 May 2025 11:24 - 27 May 2025 11:36
Replied by my1987toyota on topic Why does it seem like everyone here is Australian?
I am not sure how the OP defines long term members. That said I have been around linuxcnc for years. I am in the USA.
Though I don't care much for the politics from either side. Too much bribery and B.S. from all of them, and that's not limited
to just the USA. I would have replied earlier but I was busy playing the video game Satisfactory. Highly recommended.
great for when you're tired of the regular world. LOL
  • CADdy
  • CADdy's Avatar
27 May 2025 11:23 - 27 May 2025 11:24
Fehler in Dokumentation entdeckt was created by CADdy
Category: Deutsch
Hallo beisammen,
ich weiß nicht, an wen ich mich wenden kann, deshalb hier im Forum. In der Dokumentation habe ich folgenden Fehler gefunden:
linuxcnc.org/docs/master/html/de/config/python-interface.html
Der Begriff "tool_table" wurde in dem Programmschnipsel ins deutsche übersetzt. Richtig wäre
print(s.tool_table[0].zoffset)
Peter
  • CADdy
  • CADdy's Avatar
27 May 2025 09:20
Replied by CADdy on topic Indicators on Push Buttons
Category: Qtvcp
Thanks Chris, I thought that was a standalone widget. Thanks for the info.
Peter
  • Hakan
  • Hakan
27 May 2025 09:04 - 27 May 2025 11:52
Replied by Hakan on topic Modbus via Ethercat (Beckhoff)
Category: EtherCAT
No the EL6021, modbus is usually RS-485 signalling. Not so different from RS-232 but differential signals.
Edit. The USB to RS-485 is a much better option in this case to avoid the vertical learning curve.
Displaying 2941 - 2955 out of 24892 results.
Time to create page: 0.329 seconds
