  • Aciera
  • Aciera's Avatar
27 May 2025 07:48 - 27 May 2025 08:12
Replied by Aciera on topic Gmoccapy 3.5.0 - opinions needed
Category: Gmoccapy
Thanks for the update!
A minor thing but you might want to rename the 'turtle jog' to something that applies to all the icon themes. Maybe 'Slow/Fast Jog'
- I would VERY much like  a column for rotation in the offset table instead of having just the currently active 'Rot' value.
- I would suggest to rename the  column 'Offset Name' to 'Comments' and have it's values empty by default. That would be more consistent with the tool table.
- I would suggest to change 'G92' to 'G52/G92' as those parameter values are actually shared by the two offsets.
  • atrex77
  • atrex77's Avatar
27 May 2025 07:40 - 27 May 2025 07:47
W5100S-EVB-PICO stepgenerator and encoder driver
Category: Driver Boards
the stepper-ninja-w5500.uf2 is the file you need if you make like this.
the pico only is not enough, you need a w5500 module also, or a W5100S-EVB-PICO
  • npostma
  • npostma's Avatar
27 May 2025 06:08
Protecting My Mesa 7i76EU: Wiring Questions for Home Sensors and Touch Probe
Category: Basic Configuration
I started getting joint following errors after I changed the following stepgen timing settings to these even values:DIRSETUP = 6000
DIRHOLD = 6000
STEPLEN = 3000
STEPSPACE = 3000This happened even though I set STEPGEN_MAXVEL and STEPGEN_MAXACCEL to be 25% higher than my MAX_VELOCITY and MAX_ACCELERATION values, as recommended.However, my power supply is a 32V 10A unit running three axes, so it might be a bit underpowered. Could this be the cause of the joint following errors?
I do have another similar power supply available, so I could use it to power one axis separately—this would help with the available current, but not increase the voltage.Any advice or experience with similar situations would be appreciated!
  • Aciera
  • Aciera's Avatar
27 May 2025 06:04 - 27 May 2025 06:12
How to refresh the Axis screen after setting offsets G10 L20
Category: AXIS
Not sure if there is a halcmd to do that but you can use an executable custom Mcode to call a bash script that executes this:
axis-remote --reload
www.linuxcnc.org/docs/html/man/man1/axis-remote.1.html
  • Farmerted
  • Farmerted
27 May 2025 02:02
Replied by Farmerted on topic How to set up parallel port in Debian
I’m having a similar issue, I’ve run the above commands and captured the output, would you be able to help? I know this thread is pretty old.  Would it help to just paste the outputs or include as a file?
  • PCW
  • PCW's Avatar
27 May 2025 01:44
Replied by PCW on topic Changing MPG step rate with a switch
Category: HAL
Typically you would use a mux component for this.
In you case (only 2 increments) you could use mux2
Something like:
loadrt mux2
addf mux2.0 servo thread
setp mux2.0.in0  0.0001
setp mux2.0.in1 0.001
net jog-increment-select mux2.0.sel  some_old_input_bit
net jog-increment mux2.0.out
 (your signal names and select pin names will be different)
  • Soccer Kid
  • Soccer Kid's Avatar
27 May 2025 01:27
Replied by Soccer Kid on topic Unnamed CATIO-A Device Configuration (help!)
Category: EtherCAT
Hello friend, please refer to the following code. I have the same module and it has been tested and is available. The corresponding pulse counting and other modules only require you to add PDO as needed.
<!-- IO -->
<slave idx="5" type="generic" vid="90588" pid="109252" configPdos="true">
<syncManager idx="2" dir="out">
<pdo idx="1600">
<pdoEntry idx="0x2300" subIdx="00" bitLen="16" halPin="out00" halType="u32"/>
</pdo>
</syncManager>
<syncManager idx="3" dir="in">
<pdo idx="1A00">
<pdoEntry idx="2020" subIdx="00" bitLen="32" halPin="encoder" halType="u32"/>
<pdoEntry idx="2000" subIdx="0" bitLen="16" halType="complex">
<complexEntry bitLen="1" halPin="in-1" halType="bit"/>
<complexEntry bitLen="1" halPin="in-2" halType="bit"/>
<complexEntry bitLen="1" halPin="in-3" halType="bit"/>
<complexEntry bitLen="1" halPin="in-4" halType="bit"/>
<complexEntry bitLen="1" halPin="in-5" halType="bit"/>
<complexEntry bitLen="1" halPin="in-6" halType="bit"/>
<complexEntry bitLen="1" halPin="in-7" halType="bit"/>
<complexEntry bitLen="1" halPin="in-8" halType="bit"/>
<complexEntry bitLen="1" halPin="in-9" halType="bit"/>
<complexEntry bitLen="1" halPin="in-10" halType="bit"/>
<complexEntry bitLen="1" halPin="in-11" halType="bit"/>
</pdoEntry>
</pdo>
</syncManager>
</slave>
  • Soccer Kid
27 May 2025 01:02
Replied by Soccer Kid on topic Modbus via Ethercat (Beckhoff)
Category: EtherCAT
This module, I have previous usage experience on other platforms. In principle, it can be used without any problem, but it depends on how you call the corresponding registers. This module is very easy to use. All you need to do is to send data according to the standard MODBUS template.
  • Soccer Kid
27 May 2025 00:52 - 27 May 2025 00:53
resolved-- Regarding the data reading offset issue of the ether cat IO module
Category: EtherCAT
RODW, as you said, is correct. In the EL2809 module, I used it like this, and at the same time, testing the "general" driver and adding hal manually was also without any problems. However, problems arise when using this "Sdot" module. I received the data related to this module. Each piece of data corresponding to the PDO will be shifted by 16 bit.
  • bondglen
  • bondglen
27 May 2025 00:20
Category: AXIS
Hi all,
I have a home-made pendant that can jog and set the offsets using HALUI commands.
When I set the G54 offsets (using HAL commands) I would like to refresh the Axis display so that it will show the part in the offset position.
I would like to use a HALCMD to refresh the Axis display if possible, but will use whatever is required.
Is this even possible?
Thanks in advance.
  • slowpoke
  • slowpoke
26 May 2025 23:43
Changing MPG step rate with a switch was created by slowpoke
Category: HAL
I have a MPG encoder that has 100 detents and scaled on my lathe X axis for 0.001" increments. All working great.
Once in a while I need to turn to a dimension tighter than 0.001" When I need to do this I tweak my ini file to make the MPG increments 0.0001"
I would prefer to have a toggle switch to toggle between regular(0.001") and sensitive (0.0001") mode, and be able to toggle it as required and not have to restart LinuxCNC.
Is this possible and if so how would I go about it?
Thanks,
  • jackj120
  • jackj120
26 May 2025 21:43
Mecanumeric MF2040 LI retrofit (Pantograph)
Category: Milling Machines
Hi everyone,I'm planning a retrofit for my Mécanumeric MF2040 (large-format pantograph) i'll dismantle all the eletronic and leave the structure. After some research, I’m considering the following setup and would appreciate advice or feedback:Controller & Interface:
  • LinuxCNC running on an old (but reliable) PC
  • Mesa 7i76e Ethernet motion controller
Motors:
  • 3x Delta B2 Servo Motors (220V, 750W, 2.39Nm, 3000rpm, ECMA-C20807RS)
    • Alternative: 3x Leadshine ELM0750DH80E-SS
  • Z-axis motor: Still evaluating options
Usage:
  • The machine is mainly used for cutting and engraving (pantograph work, large panels).
Questions:
  1. Does this setup sound suitable for a machine of this size and type?
  2. Any experience with these servo motors (Delta B2 vs Leadshine)? Reliability, tuning, integration?
  3. Suggestions for the Z-axis motor?
  4. Any compatibility issues or tips when using LinuxCNC with the Mesa 7i76e and these servo drives?
Thank you in advance for your advice and suggestions!
  • SwitchWitch
  • SwitchWitch
26 May 2025 21:23
Replied by SwitchWitch on topic Modbus via Ethercat (Beckhoff)
Category: EtherCAT
So it`s not going over ethercat? Didn`t think about this possibility yet. Thx a lot for the hint!
  • PCW
  • PCW's Avatar
26 May 2025 20:39 - 26 May 2025 20:40
Replied by PCW on topic Threading Index Varies With Speed
Yes, the X movement (joint 0 in the plot) is done before index is detected
but the interpolated position (spindle-revs) removes any quantization
issues:
  • COFHAL
  • COFHAL
26 May 2025 19:33
What is the bianari file for the normal RP pico?
stepper-ninja-W5500 or stepper-ninja-W5500S
Displaying 2986 - 3000 out of 24902 results.
Time to create page: 0.285 seconds
