Thank you very much for your help. I first installed
www.debian.org/devel/debian-installer/ as described without any errors. Then I run:
cd ~
cd Downloads
sudo dpkg -i linuxcnc-uspace_2.9.3_amd64.deb
and I get these messages. Why these dependency problems? Or are these messages normal?
dg@LinuxCNC:~/Downloads$ sudo dpkg -i linuxcnc-uspace_2.9.3_amd64.deb
[sudo] Password for dg:
(Reading database... 119436 files and directories are currently installed.)
Preparing to unpack linuxcnc-uspace_2.9.3_amd64.deb...
Unpacking linuxcnc-uspace (1:2.9.3) via (1:2.9.3)...
dpkg: Dependency problems prevent configuration of linuxcnc-uspace:
linuxcnc-uspace depends on python3 (<< 3.12); but:
Version of Python3 on the system is 3.13.3-1.
linuxcnc-uspace depends on libboost-python1.74.0 (>= 1.74.0+ds1); but:
Package libboost-python1.74.0 is not installed.
linuxcnc-uspace depends on libboost-python1.74.0-py311; but:
Package libboost-python1.74.0-py311 is not installed.
linuxcnc-uspace depends on libgpiod2 (>= 1.5.1); but:
Package libgpiod2 is not installed.
linuxcnc-uspace depends on libmodbus5 (>= 3.1.4); but:
Package libmodbus5 is not installed.
linuxcnc-uspace depends on libpython3.11 (>= 3.11.0); but:
Package libpython3.11 is not installed.
linuxcnc-uspace depends on libtk8.6 (>= 8.6.0); but:
Package libtk8.6 is not installed.
linuxcnc-uspace depends on libudev-dev; but:
Package libudev-dev is not installed.
linuxcnc-uspace depends on iptables; but:
Package iptables is not installed.
linuxcnc-uspace depends on blt; but:
Package blt is not installed.
linuxcnc-uspace depends on mesa-utils; but:
Package mesa-utils is not installed.
linuxcnc-uspace depends on python3-tk; but:
Package python3-tk is not installed.
linuxcnc-uspace depends on python3-numpy; but:
Package python3-numpy is not installed.
linuxcnc-uspace depends on python3-opengl; but:
Package python3-opengl is not installed.
linuxcnc-uspace depends on python3-configobj; but:
Package python3-configobj is not installed.
linuxcnc-uspace depends on python3-xlib; but:
Package python3-xlib is not installed.
linuxcnc-uspace depends on libgtksourceview-3.0-dev; but:
Package libgtksourceview-3.0-dev is not installed.
linuxcnc-uspace depends on tcl8.6; but:
Package tcl8.6 is not installed.
linuxcnc-uspace depends on tk8.6; but:
Package tk8.6 is not installed.
linuxcnc-uspace depends on bwidget (>= 1.7); but:
Package bwidget is not installed.
linuxcnc-uspace depends on tclreadline; but:
Package tclreadline is not installed.
linuxcnc-uspace depends on tclx; but:
Package tclx is not installed.
linuxcnc-uspace depends on python3-pyqt5; but:
Package python3-pyqt5 is not installed.
linuxcnc-uspace depends on python3-pyqt5.qsci; but:
Package python3-pyqt5.qsci is not installed.
linuxcnc-uspace depends on python3-pyqt5.qtsvg; but:
Package python3-pyqt5.qtsvg is not installed.
linuxcnc-uspace depends on python3-pyqt5.qtopengl; but:
Package python3-pyqt5.qtopengl is not installed.
linuxcnc-uspace depends on python3-opencv; but:
Package python3-opencv is not installed.
linuxcnc-uspace depends on python3-espeak; but:
Package python3-espeak is not installed.
linuxcnc-uspace depends on python3-dbus.mainloop.pyqt5; but:
Package python3-dbus.mainloop.pyqt5 is not installed.
linuxcnc-uspace depends on python3-pyqt5.qtwebengine | python3-pyqt5.qtwebkit; but:
Package python3-pyqt5.qtwebengine is not installed.
Package python3-pyqt5.qtwebkit is not installed.
linuxcnc-uspace depends on espeak-ng; but:
Package espeak-ng is not installed.
linuxcnc-uspace depends on pyqt5-dev-tools; but:
Package pyqt5-dev-tools is not installed.
linuxcnc-uspace depends on gstreamer1.0-tools; but:
Package gstreamer1.0-tools is not installed.
linuxcnc-uspace depends on espeak; but:
Package espeak is not installed.
linuxcnc-uspace depends on python3-poppler-qt5; however:
Package python3-poppler-qt5 is not installed.
linuxcnc-uspace depends on psmisc; however:
Package psmisc is not installed.
dpkg: Error processing package linuxcnc-uspace (--install):
Dependency problems - leaving unconfigured
Processing triggers for libc-bin (2.41-7)...
Processing triggers for mailcap (3.74)...
Processing triggers for desktop-file-utils (0.28-1)...
Processing triggers for hicolor-icon-theme (0.18-2)...
Processing triggers for man-db (2.13.1-1)...
Processing triggers for shared-mime-info (2.4-5+b2)...
Errors occurred processing:
linuxcnc-uspace
dg@LinuxCNC:~/Downloads$ sudo apt install git
Try "apt --fix-broken install" to correct this.
Unmet Dependencies:
git: Depends on: liberror-perl but should not be installed
Depends on: git-man (> 1:2.47.2) but should not be installed
Depends on: git-man (< 1:2.47.2-.) but should not be installed
Recommends: Patch but should not be installed
linuxcnc-uspace: Depends on: py
