  • npostma
  • npostma's Avatar
16 May 2025 11:50 - 16 May 2025 11:53
Replied by npostma on topic Need guidence to improve latency and speed
Category: Basic Configuration
Hi Todd,
Thanks for your response — I’ll definitely give that a try, as it feels like my last resort with this current setup.
I've already disabled everything I possibly could in the BIOS. The only things I haven't touched yet are the memory timings and voltages. If this doesn’t work either, I’m honestly not sure what else is left to tweak.
I'm also considering switching to a Mesa card, possibly the 7i76EU, but I have zero experience with Mesa hardware. I’ll need to figure out whether it will work with my three DM542A stepper drivers, and also with my VFD, which is currently controlled over USB using: `loadusr -Wn vfd hy_vfd -n vfd -d /dev/ttyUSB0 -p none -r 9600`
Things i disabled next to the obvious, like settings for fixed clock speeds (fclock 1066, bclock 1000) disabling power management and disabling hardware that is not being used (BT, Wireless, serial, audio, fancontrol (disabled fixed on 100%)):
BIOS Settings (set to Disabled):
SMT / Hyperthreading
→ Disables logical cores to reduce cache sharing and latency spikes
C1E, C6, and other C-States
→ Prevents the CPU from entering sleep states, ensuring consistent timing
Streaming Stores Control
→ Avoids aggressive memory write optimizations that can disrupt real-time behavior
DRAM Scrub Time
→ Turns off background memory error checking to avoid unexpected memory bus usage
GMI Encryption Control
→ Disables inter-chiplet encryption on Infinity Fabric to reduce overhead and latency
XGMI TXEQ Mode
→ Prevents signal equalization tuning that could introduce instability or variability
DRAM Map Intervention
→ Disables memory remapping logic that can introduce unpredictable latency
DF Sync Flood Propagation
→ Prevents error broadcasts across chiplets, reducing the chance of system-wide stalls
  • H-S-W
  • H-S-W
  • H-S-W
  • H-S-W
16 May 2025 11:06
Replied by tommylight on topic Issues installing LinuxCNC
Category: Installing LinuxCNC
home and besnik are in the wrong places again and Downloads starts with upper case D. Linux is case sensitive so D and d are not the same.
Copy and paste from here:
cd /home/besnik/Downloads
sudo chmod +x  /home/besnik/Downloads/linuxcnc-install.sh
./linuxcnc-install.sh
  • Todd Zuercher
  • Todd Zuercher's Avatar
16 May 2025 11:01
Replied by Todd Zuercher on topic Issues installing LinuxCNC
You had the directory tree order wrong. You typed "cd home/besnik/downloads/" and it needs to be "cd besnik/home/Downloads/". Also Linux is case sensitive so the capitol leter "D" is also important.
  • Todd Zuercher
16 May 2025 10:36
Replied by Todd Zuercher on topic Need guidence to improve latency and speed
Keep playing with different combinations of cores isolated using isolcpus till you find what gives you the best result. Your Ryzen has 6 of them to choose from, I'd test different combinations of 1, 2, and 3 cores isolated, like 1,3,5 or 3,4,5 or 0,1,2, or 4,5, or 0,1...
  • low-blip
  • low-blip
16 May 2025 10:30 - 27 May 2025 11:38
Actual position and Commanded position differ, using cia402 [SOLVED]
I'm very new to LinuxCNC, and using a CNC machine custom built and configured by someone else. Running into some errors that none of us could figure out, help would be very very appreciated.
We are using cia402 and ethercat to run a 9-axis system, including xyz and 6 rotation axis. We noticed that the actual and commanded positions of the xyz axes are always off by a factor of 80 , e.g. if we send the Gcode to move X axis by 10mm, it moves by 10mm, the commanded position is 10, but the 'actual position' is 0.125. We can still run .ngc files, they do exactly what we expect them to do, but at the end we get motor position error on these three axes.
We've tried increasing the FERROR and MIN_FERROR in the .ini file
[AXIS_X]
MIN_LIMIT         = -5
MAX_LIMIT         = 395
MAX_VELOCITY         = 500
MAX_ACCELERATION     = 250
[JOINT_0]
TYPE             = LINEAR
MAX_VELOCITY         = 500
FERROR             = 200
MIN_FERROR         = 50
MIN_LIMIT         = -1
MAX_LIMIT         = 1200
HOME            = 0
HOME_OFFSET        = 0
HOME_SEQUENCE        = 1
HOME_IGNORE_LIMITS    = YES
# nach github.com/dbraun1981/hal-cia402/blob/main/README.md
HOME_SEARCH_VEL     = 5.0
HOME_LATCH_VEL         = -2
HOME_FINAL_VEL        = 1
HOME_USE_INDEX    = FALSE
 .hal:
loadrt [KINS]KINEMATICS
loadusr -W lcec_conf ECOMODUL_ethercat_conf.xml
loadrt lcec
loadrt cia402 count=9
# Functions servo-thread
addf lcec.read-all servo-thread
addf cia402.0.read-all servo-thread
addf cia402.1.read-all servo-thread
addf cia402.2.read-all servo-thread
addf motion-controller servo-thread #########################################
#nets
net emc-enable => iocontrol.0.emc-enable-in
sets emc-enable 1 #config
#testing Werte für pos-scale fehlen
#x
setp cia402.0.csp-mode 1
setp cia402.0.pos-scale 8000
#y
setp cia402.1.csp-mode 1
setp cia402.1.pos-scale 8000
#z
setp cia402.2.csp-mode 1
setp cia402.2.pos-scale 8000 ...
#from servo(ethercat) to cia402 net x-statusword      lcec.0.8Axis.xcia-statusword => cia402.0.statusword
net x-opmode-display  lcec.0.8Axis.xopmode-display => cia402.0.opmode-display
net x-drv-act-pos     lcec.0.8Axis.xactual-position => cia402.0.drv-actual-position net y-statusword      lcec.0.8Axis.ycia-statusword => cia402.1.statusword
net y-opmode-display  lcec.0.8Axis.yopmode-display => cia402.1.opmode-display
net y-drv-act-pos     lcec.0.8Axis.yactual-position => cia402.1.drv-actual-position  net z-statusword      lcec.0.8Axis.zcia-statusword => cia402.2.statusword
net z-opmode-display  lcec.0.8Axis.zopmode-display => cia402.2.opmode-display
net z-drv-act-pos     lcec.0.8Axis.zactual-position => cia402.2.drv-actual-position
#from cia402 to servo(ethercat) net x-controlword         cia402.0.controlword     => lcec.0.8Axis.xcia-controlword
net x-modes-of-operation  cia402.0.opmode     => lcec.0.8Axis.xopmode
net x-drv-target-pos      cia402.0.drv-target-position   => lcec.0.8Axis.xtarget-position net y-controlword         cia402.1.controlword     => lcec.0.8Axis.ycia-controlword
net y-modes-of-operation  cia402.1.opmode     => lcec.0.8Axis.yopmode
net y-drv-target-pos      cia402.1.drv-target-position   => lcec.0.8Axis.ytarget-position net z-controlword         cia402.2.controlword     => lcec.0.8Axis.zcia-controlword
net z-modes-of-operation  cia402.2.opmode     => lcec.0.8Axis.zopmode
net z-drv-target-pos      cia402.2.drv-target-position   => lcec.0.8Axis.ztarget-position
#from motion to cia
net x-enable    <= joint.0.amp-enable-out => cia402.0.enable
net x-amp-fault => joint.0.amp-fault-in   <= cia402.0.drv-fault
net x-pos-cmd   <= joint.0.motor-pos-cmd  => cia402.0.pos-cmd
net x-pos-fb    => joint.0.motor-pos-fb   <= cia402.0.pos-fb net y-enable    <= joint.1.amp-enable-out => cia402.1.enable
net y-amp-fault => joint.1.amp-fault-in   <= cia402.1.drv-fault
net y-pos-cmd   <= joint.1.motor-pos-cmd  => cia402.1.pos-cmd
net y-pos-fb    => joint.1.motor-pos-fb   <= cia402.1.pos-fb net z-enable    <= joint.2.amp-enable-out => cia402.2.enable
net z-amp-fault => joint.2.amp-fault-in   <= cia402.2.drv-fault
net z-pos-cmd   <= joint.2.motor-pos-cmd  => cia402.2.pos-cmd
net z-pos-fb    => joint.2.motor-pos-fb   <= cia402.2.pos-fb
  • besi99
  • besi99
16 May 2025 10:01
Replied by besi99 on topic Issues installing LinuxCNC
Okay thats a good tip that thoose commands are wrong. I found thoose commands on the forum.I tried the commands with the order you told. But I still get the same error. I took some pics maybe they help.
Thanks for trying to help me :)
- Shume flm per ndhime
  • alangibson
  • alangibson
16 May 2025 09:03
Ohmic probe aborts immediately was created by alangibson
Category: Plasmac
Hello all. I've got an odd problem with ohmic probing that recently cropped up.
When I tap the Ohmic Probe button in QtPlasmaC, probing immediately aborts without moving the Z axis. Normally I would assume that the ohmic sensing circuit is always closed for some reason, but it's definitely not that.
halscope shows that the ohmic sense feedback pin is never activated. The ohmic enable pin is however correctly activated.
I've verified that the relay on my breakout board closes when ohmic probing is activated. If I connect the ohmic sense wire directly to the table, probing again immediately aborts and the ohmic sense pin is correctly activated. I've also verified that the relay that closes when the sense circuit is closed is not activated.
Z axis is homed. It correctly probes when using only the float switch.
So my question is: what can cause a situation where ohmic probing aborts no matter if the sense pin is active or not?
  • npostma
  • npostma's Avatar
16 May 2025 08:29 - 16 May 2025 09:17
Hi, thanks for your response!
Do you happen to have a link to that specific thread? I might have missed it.
I've read a lot of posts and tried many things in both the BIOS and on the CNC machine over the past month, but nothing seems to help so far. I haven’t tried any bootloader or CLI-based options yet, so that might be worth exploring next.
That's why i have the feeling i am missing something obvious because this is my first AMD CPU machine. In the past i had 2 intel systems before and never had this extreme latency. Also i always used my AMD Firepro graphics card. So the GPU did not change over time.
::EDIT:: Alright isolating cores seems to be a step in the correct direction. I changed my GRUB conf to:
GRUB_CMDLINE_LINUX_DEFAULT="quiet isolcpus=2,3 nohz_full=2,3 rcu_nocbs=2,3 idle=poll processor.max_cstate=0 amd_pstate=disable"
to free up my core 2 and 3. If i do a latency tests i now have a servo thread < 25 000 and a base thread < 120 000. So that is better. I think i it still not ideal to have such a high basethread... still the:
- joint 0 following error
- unexpected real-time delay
errors even if i start linuxcnc on the isolated cores via #!/bin/bash
taskset -c 2,3 linuxcnc /home/npostma/linuxcnc/configs/CNC/CNC.ini
Validated with `ps -eLo pid,psr,comm | grep -i linuxcnc` that it did run on the isolated cores. I also see in HTOP that the cores are isolated. No processes go to them.
Thanks again!
  • unknown
  • unknown
16 May 2025 08:20
Replied by unknown on topic Need guidence to improve latency and speed
There's quite a few threads regarding latency, there's a quite a long one from just this week.
Your max speed will be a function of step per rev and your base thread.
You could try isolating the last 2 cores via the kernel command line.
  • Aciera
  • Aciera's Avatar
16 May 2025 08:15 - 16 May 2025 08:29
Planning to Retrofit a Mazak Integrex200Y Mill-Turn Machine
That is because the PP uses G18 to rotate the coordinate system for milling.
Have you tried setting the rotational axis to Z as suggested here:
forum.linuxcnc.org/10-advanced-configura...hine?start=50#327942
The underlying problem is that linuxcnc applies the x-,y-z- tool-offsets internally, so the tool-length is automatically subtracted from the Z position shown in the DRO. That is why the kinematic model for milling has the tool spindle pointing in the negative machine Z direction and the model for turning has it pointing in the negative X direction.
While it might be possible to remove the tool-offset as linuxcnc applies them and add them to different axes in the kinematic I'm rather skeptical that it is worth the effort.
You need to remember that the planner currently has no information about the custom kinematic used, neither does the preview. The nice thing about TWP is that you can load any G17 XYZ milling toolpath and it will be displayed correctly in the screen.
Generally speaking limit violation checking and tool path preview will only be of limited use for more complex kinematics.
Note though that limit values can be changed when changing kinematic modes. For an example see:
github.com/LinuxCNC/linuxcnc/tree/master...xis/vismach/millturn
The actual values are changed using executable Mcodes:
github.com/LinuxCNC/linuxcnc/tree/master...mach/millturn/mcodes
  • SanzuiWorks
  • SanzuiWorks's Avatar
16 May 2025 07:00 - 16 May 2025 07:02
Replied by SanzuiWorks on topic Manual Toolchange + Abs Z Probe (QtDragon)
Category: Qtvcp
Thanks for your interest! I made several modifications to qt_auto_probe_tool.ngc to improve tool length offset management and work coordinate independence.
Changes Made:
Separated tool length offset (G43) from work coordinate systems (G54/G55), making the tool table more intuitive.
The probe height was defined in machine coordinates and probed at the tip of the spindle.
Ensured tool length offset remains consistent regardless of WCS changes.
Thanks!
  • npostma
  • npostma's Avatar
16 May 2025 06:43 - 16 May 2025 07:03
Hi all,
It’s been (far) too long since I last had time for CNC projects. Fortunately, things have settled down a bit lately, and I’ve been able to pick up the hobby again. However, getting my machine up and running has proven to be more of a challenge than expected.
My old Intel setup (with a 4790K) had both a faulty motherboard and RAM, so I replaced it with an ASUS AM4 board and a Ryzen 5600 CPU. Since then, I've been struggling with what seems to be very high latency.
To make matters worse, I used to run LinuxCNC 2.4, but I’ve now reinstalled everything using the latest stock ISO (2.9 with the PREEMPT-RT kernel). Unfortunately, this means my old configuration is no longer compatible.
I’ve uploaded my current settings, including the BIOS changes I’ve made in an attempt to reduce latency. At this point, my first goal is simply to get the axes moving at a reasonable rate. Right now, I can’t get it to move faster than about 1 mm/sec (rough estimate) before I run into either a joint 0 following error or an error about the base thread timing.
If anyone has tips or suggestions based on my setup or config files, I’d really appreciate the help. The machine used to run at a speed much faster than the tool could handle, so I know it's capable — I just need to get the configuration right again.
I’m aware that my .hal and .ini files likely need significant changes. I've done my best to port over the old configuration, but clearly, it’s not quite there yet.
Thanks in advance for any insights or advice!
The images are from 1 to 12, replace the number in the URL. I cant post that many links
www.doingcode.nl/images/linuxcnc/1.jpg
  • jochen91
  • jochen91
16 May 2025 06:39
Hello Aciera,
i spend more time with it and found one more challenge.
While working with TWP i saw a problem, that it does twist the workplane perfectly but it also changes the axis definition.
Z Integrex is becoming X (Conventional)
X Integrex is becoming Z (Conventional)
Y stays Y
While this behavior can be surely handled in the PP, its a bit of a mess in LCNC. Soft limits are fairly difficult to define and in AXIS GUI it also looks a bit messy. The Doosan PP also does not change Z/X definition, when G368 is posted. And of course the key binding is also off in TWP mode.
The question is now: Can G68 keep the original Integrex Axis definitions ?
Displaying 3811 - 3825 out of 24558 results.
Time to create page: 0.567 seconds
