  • Aciera
  • Aciera's Avatar
15 May 2025 18:02
Replied by Aciera on topic Preview plot with touchscreen gestures
Category: Gmoccapy
Nice, thanks for sharing.
  • Wischi
  • Wischi
15 May 2025 17:11 - 15 May 2025 17:13
Category: Gmoccapy
Hello everyone,
i was facing the same problem preview plot bug in LinuxCNC 2.9.4 with Gmoccapy 3.4.9 as described in this thread:  Question: Gmoccapy 3.4.2 and touchscreen
Preview only moves a couple of mm then stops.
So i decided to change the gremlin.py to use the Gtk3 Gestures. With the modified version you can rotate the preview with one finger again, but also zoom in and out with pinch gestures as well as pan with two fingers. In X, Y, Z view the rotation is locked, only zoom + pan. As of right now it will disable the mouse, but my machine only has the touchscreen so for me its no problem.
~$xinput list show my touchscreen as:
eGalaxTouch Virtual Device for Single
eGalaxTouch Virtial Device for Touch
No further driver installed. Tested with fresh 2.9.4 live iso.
Just replace gremlin.py in /usr/lib/python3/dist-packages/
I just wanted to drop this file in here in case someone has the same problem. It does not work in Axis though! There the preview jumps to a random place, but it is the same behaviour with the original gremlin.
Also made a small video:
  • PCW
  • PCW's Avatar
  • youngyaper
  • youngyaper
15 May 2025 16:28
  • fc60
  • fc60
15 May 2025 16:24
linux cnc keeps bending shortcutting to the next line.
Greetings,
I think I had a similar situation.
I needed to activate G64 to tell the controller not to move until the previous event had finished it's travel.
Cheers,
Dave
  • youngyaper
  • youngyaper
15 May 2025 16:17
I have an issue that im sure some of you know the solution. It seems linuxCNC/ AXIS processor  instead of completing a move to a coordinate begins moving to the next coordinate creating a curve/ bend toolpath between the two points, almost like a shortcut. It does this only from an X or Y cordinate to a Z and vise versa, but not from an X to Y coordinate. Please help !! thanks.
  • PasstScho
  • PasstScho
15 May 2025 16:02
Replied by PasstScho on topic mesa 7i73 4x8 keypad problems on KEY8 input
Category: Driver Boards
Great news!
I also tried more modern versions of the MPLAB X IDE, are not able to properly read the original hex format.
Well actually those editors are reading it correctly. Data after the End-Of-File should not exist. A good Editor should just say sth. like "can't open file - wrong entry" or "do you want to ignore the error?"....
The Editor/Programmer PCW is reading does not read it correctly as it ignores the EOF Entry without saying so.
Wikipedia says:
 :00000001FF   End Of File: Must occur exactly once per file in the last record of the file.
But well - the initial problem is solved and I don't think I will put effort in fixing Microchip's tools or Toolchains.
@PCW: Please keep the EOF bug in mind whenever you send hex files made by the same toolchain.
Thank you for the fixed firmware!
  • Milkof
  • Milkof
15 May 2025 16:00
Mesa 7I96 + Stepper online CL86T Wiring connections
 Hello everyone,
I wanted to ask a favour of some more experienced users than myself.
I am making the electronics with the 7I96 and the CL86T drives, the connections for the motor management I managed to connect.
Now I am missing the limit switches e-stop and Z-Finder, could you kindly check on the attached diagram if the connections are correct?
Milko
15 May 2025 15:43
Why does it seem like everyone here is Australian?
I am not in Australia.
I do like Australia, with all the creatures that can kill people easily, mostly because of people.
  • langdons
  • langdons
15 May 2025 15:27
It seems all permanent, long-standing members, contributors, moderators, etc. are Australian.
Why is this?
Why would a place with a hot climate have lots of people who work with heat-producing machinery in a room that likely has no A/C?
Machines likely need cooling water (fresh, not salty), a rarish thing in Australia.
I suppose close proximity to Asia is nice, but is kinda counterracted by the fact that it's far away from the USA (though Trump is successfully making proximity to the US less desirable).
  • langdons
  • langdons
15 May 2025 15:17
[SOLVED]linuxcnc Latency test ambiguous results
Didn't TommyLight literally say that?
  • DarkPhoinix
  • DarkPhoinix
15 May 2025 14:46
Replied by DarkPhoinix on topic [SOLVED]linuxcnc Latency test ambiguous results
Today i try a new MB with HDMI exit! The youtube video test is DUMP!
Try stress test + glxgear for your system dont lose time!
  • kubes
  • kubes
15 May 2025 14:19
Replied by kubes on topic Show your screens
Show your screens
Category: QtPyVCP
@ anfänger
Nice work on the update to probe_basic.  The status tab is perfect!  I see this is an older post, but maybe you can share the update or some notes on how you made it.  I want to create something very similar.  Newbie here and not sure where to start.
  • SteepLearningCurve
15 May 2025 14:16
Replied by SteepLearningCurve on topic None of the axis are moving - using mesa 7i92t with 7i76u
Category: Basic Configuration
Hi All
Yes, the W4 jumper on the 7i92t was down, and it is now up.
The linuxcnc config loads,  the inputs also work , and there is also movement on the motors :)
A very very big thank you, to the knowledgeable folks on this forum, for sharing your valuable time, wisdom, and knowledge with me, it is greatly appreciated.
As a person new to Linuxcnc , there are so many things that we don't know.
Be braver than me, post a question sooner than I did.
(For folks reading this post in the future, the wiring currently is differential, and seems to be working fine).
  • DarkPhoinix
  • DarkPhoinix
15 May 2025 14:01 - 15 May 2025 14:04
Replied by DarkPhoinix on topic Remora - Does Analog input syntax exist?
Warning: Spoiler!
Thanks for reply,
I have set 12800 and testing some gcode only with Y working.
I don't want to cause problems when all the stepper and spindle are physically working.
Displaying 3841 - 3855 out of 24557 results.
Time to create page: 0.441 seconds
