  • IB_CnC
  • IB_CnC
03 May 2025 22:20 - 03 May 2025 22:21
Probe Basic and Carousel ATC with Geneva and Stepper
Category: QtPyVCP
Updated vid
I was also planning to mount the toolsetter on the ATC, so it becomes available when the carousel is out of the way.
But I'm a little worried it will trigger due to the movement of the cylinder, as the end cushioning is not that good, need to solve that first.
  • spincycle
  • spincycle
03 May 2025 22:14
Replied by spincycle on topic Bridgeport VMC760 retrofit
Category: Milling Machines
Some pictures of the old beast.
  • Spyderbreath
  • Spyderbreath's Avatar
03 May 2025 22:06
Replied by Spyderbreath on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
If you are going to be copying this post here - www.forum.linuxcnc.org/18-computer/44828...rd?start=2140#327240 - watch the caps and dashes. On my Rpi5 / bookworm install its not LinuxCNC but linuxcnc and them there should be a double dash (--) before install in both instances in step 2. no show stopper but it was not a direct copy/paste into the console.
A full blown NVEM config would be sweet. Or just little snippets like the one you provided for the end-stops. That bit of info now allows me to configure ALL my inputs.
  • Hakan
  • Hakan
03 May 2025 22:00
Replied by Hakan on topic free CADCAM
free CADCAM
Category: CAD CAM
See if you qualify for one of the free license alternatives for Fusion 360. If you do I think it is hard to beat.
One can argue that it isn't free, at least it doesn't cost any money.
  • spincycle
  • spincycle
03 May 2025 22:00
The induction motor is a very, very old invention.
By Nikola Tesla.
Hahaha, so true
  • spincycle
  • spincycle
03 May 2025 21:59
Thanks for the input Langdons.
Good to know that a beefed up PC is a better choice than the Pi.
The thought did cross my mind to keep the motors and replace drivers. I would assume I'd need to get drivers that work with the Siemens encoders or replace the encoders with ones that match the drives.
Does anyone have any experience with this?
Thanks,
J
03 May 2025 21:37
None of the axis are moving - using mesa 7i92t with 7i76u
Category: Basic Configuration
Enable signal:
This signal is used for enabling/disabling the drive.
High level +5V (NPN control signal) for enabling the drive, and low level for disabling the drive.
PNP and Differential control signals are on the contrary, namely Low level for enabling.
By default it is left UNCONNECTED (ENABLED).
Contradicting info.
Not unusual on China stuff, at all.
  • dbtayl
  • dbtayl
03 May 2025 21:35 - 03 May 2025 21:37
Replied by dbtayl on topic free CADCAM
free CADCAM
Category: CAD CAM
I use FreeCAD- the "Path" workbench got renamed to (more appropriately) "CAM" a while back- when searching for information on it, you may see references to both. It's adequate, getting better all the time (use the weekly builds!). Lots of little things that are obnoxious, but I haven't found anything better for any reasonable-to-this-hobbyist cost if you're doing more mechanical designs than organic/artsy. Being parametric on the CAD side and having adaptive toolpaths on the CAM side are huge for me. Definitely a learning curve, sometimes you have to go about things in unintuitive ways for various reasons to get what you want.
Depends heavily on what you're doing as well. Blender + BlenderCAM might be a good choice if you can manage the learning curve and are doing more organic/less "dimensioned" stuff. FreeCAD doesn't handle that so well IME.
If you're doing 2D/engraving type stuff, Inkscape or others might be better.
You might also end up using multiple for different things.
03 May 2025 21:35
Replied by tommylight on topic Bridgeport VMC760 retrofit
By Nikola Tesla.
  • cmorley
  • cmorley
03 May 2025 21:32
How to change jog speed using joystick buttons (QtDragon + HAL)?
Category: HAL
You could use a mux component to set halui.jog-speed.
Mux2 for 2 speeds from one button or
Mux4 for up to 4 speed from two buttons
  • cakeslob
  • cakeslob
03 May 2025 21:26
the documents will be updated to reflect the struggles of you and the other users this last week.
to the 2 other users who posted the quick guides for flashing and setup, i would like to use those in the remora docs, i hope this is ok
  • Spyderbreath
03 May 2025 21:23
OK, progress! I put the #end-stops into my .hal file and BANG, I get a limit switch error reported in axis on pins 3, 5, and 7.
THANK YOU to all that have gotten me this far!! I now know that the remora flash took on the nvem and the hardware part is working.
Just the nightmare of figuring out the rest of the .hal file to get everything else working. But as for now, forward is a good direction to be heading. :)
  • cakeslob
  • cakeslob
03 May 2025 21:23 - 03 May 2025 21:24
the first part is what you add to the bottom of your hal file
the second part is a sample of the NVEM config.txt. the config.txt is what configures the remora hardware to the remora software. the hal file is what connects the remora software to the linuxcnc software. i included it to emphasize the relationship between which IO on the board does what in linuxcnc
The ini file is what configures your linuxcnc machine, so speeds of each axis, the travel, where the home switch is, how many axis/joints, the gui, etc
  • Hakan
  • Hakan
03 May 2025 21:08
Replied by Hakan on topic Using POSIX realtime
Category: EtherCAT
Just type the command "ethercat debug 1"
  • langdons
  • langdons
03 May 2025 21:06
Category: HAL
I can't even get QtDragon to work at all.
Good luck.
Displaying 5416 - 5430 out of 24213 results.
Time to create page: 0.801 seconds
