  • my1987toyota
  • my1987toyota's Avatar
01 May 2025 16:27 - 01 May 2025 16:39
Replied by my1987toyota on topic fresh install issue with 2.9.4
Category: Installing LinuxCNC
found the problem
I see it is talking about missing raspi-firmware.
to remove enter the terminal
then enter
sudo dpkg -P raspi-firmware
now the error is gone.
  • PCW
  • PCW's Avatar
01 May 2025 16:25
Replied by PCW on topic 7i84
7i84
Category: Driver Boards
The 7I84 needs VFIELDA VFIELDB and VIN
Suggested wiring is to power VFIELDA and VFIELDB and leave W1 in the default
left hand position, so VIN get powered via VFIELDB.
  • GDTH
  • GDTH's Avatar
01 May 2025 16:18
7i84 was created by GDTH
7i84
He,
I have a 7i84 connected to a 7i77. Lcnc can see the device but the red is always on and I am not able to control the outputs. Could it because I only have 24v connected to vin. Does the field a and b niet power?
  • my1987toyota
01 May 2025 16:05 - 01 May 2025 16:24
fresh install issue with 2.9.4 was created by my1987toyota
File Name: errorreport.txt
File Size:1 KB
So I decided to do a fresh install on the computers for my Mill and Lathe. The computers areDell Optiplex 9020 micros. I am installing Linuxcnc V2.9.4 ISO. After installing and then updatingI get an error message ofE: Subprocess /usr/bin/dpkg returned an error code (1)it also says there is an issue with initramfs-tools.all that said I am attaching a pic of the error message to help. I am sure I am missing something stupidI usually do. LOL
File Size:1 KB
  • PCW
  • PCW's Avatar
01 May 2025 14:32
[SOLVED]linuxcnc Latency test ambiguous results
Did you try pinning the Ethernet IRQ to the last processor?
This usually make a large difference in Network latency
  • Attis92
  • Attis92
01 May 2025 14:24
Yes, correct!
But I’m still having some issues with the config upload, which I’m currently investigating on the EC500 board.
If you're unable to change the config, you may need to erase the entire chip first:
sudo pyocd erase -c --target mimxrt1050_quadspi
Then flash the firmware again and upload the new config.
sudo pyocd flash remora-rt1052-3.1.3.bin --target mimxrt1050_quadspi
This worked for me, but it's definitely not an ideal solution...
  • Lcvette
  • Lcvette's Avatar
01 May 2025 13:22
Porbe basic lathe: Questions about the keyboard
Category: QtPyVCP
not sure i follow about the speeds thing? maybe your configuration settings for default jog speed? not sure about the keys things, been completely covered up with work and haven't had any time to dig into probe basic recently. maybe ask the linuxcnc devs if they could add a keyboard assignment to the configuration? for lathe? if its such an issue im sure more folks would want a global resolution that translates into any gui running the lathe option in the ini.
  • acourtjester
  • acourtjester
01 May 2025 13:18
Replied by acourtjester on topic Plasma center punching operation
Happy to help, just a small payback for all the help I have received in the past from this site and members.
  • Lcvette
  • Lcvette's Avatar
01 May 2025 13:17
Replied by Lcvette on topic config tool setter
config tool setter
Category: QtPyVCP
did you get this resolved?
  • PCW
  • PCW's Avatar
01 May 2025 13:08
Replied by PCW on topic LinuxCNC S-Curve Accelerations
I did set the acceleration in the TRAJ section, it does affect the acceleration
but the scaling seems not to be correct. The Acceleration/Velocity bounds are important
since they are per joint physical limitations.
(sorry if I am getting out the sandpaper when construction is at the chainsaw stage)
It is great so see  a jerk limited profile working with LinuxCNC as it fixes the inevitable
following error at the start/end of motion due to the impossibility of having instant force
application in any real drive system.
  • Lcvette
  • Lcvette's Avatar
01 May 2025 13:05
Probe Basic and Carousel ATC with Geneva and Stepper
Category: QtPyVCP
yeah that delay is a bugger.. the drive should be enable constantly and just be looking for a direction voltage and step pulse stream. i would have the drive enabled anytime the the machine is on and not estopped. and have it sitting idle waiting for pulse command.
  • jjdege
  • jjdege's Avatar
01 May 2025 12:57 - 01 May 2025 20:22
cakeslob post=326968 userid=25269
Are all the drivers the same, or did you do your check all axis with the same drive
 jjdege post=326970 userid=32556
hi
the same driver for all axes.
I tried to unsolder the chip, without success
the board does not respond, for now I do not think I will buy another
thanks for the support
Hi guys
I couldn't resist and bought a new board, this time I opted for a 3-axis EC500,
it has LEDs that indicate the I/O status, I think it's more complete.
I tested it with Mach3 to make sure it was working well, given the previous ones,
and it worked on all three axes.
When loading the firmware, it got to 29% and timed out and everything froze,
the DAP wasn't receiving signals.
I reread page 115 of the thread that talks about how to unlock and after having
bridged BOOT_MO and 3V3 I managed to delete and write the new firmware!!
Now all 6 axes work.
Thanks again to Scott and to whoever made all this possible.
  • Lcvette
  • Lcvette's Avatar
01 May 2025 12:56
Replied by Lcvette on topic QtPyVCP designer plugin fails
Category: QtPyVCP
great!
  • langdons
  • langdons
01 May 2025 12:37 - 01 May 2025 12:40
Replied by langdons on topic Segmentation fault
Segmentation fault
Do not ever run an OS from a USB key long-term.
The flash memory will wear out and the bandwidth will be limited b/c USB only has 1 unidirectional dataline.
It cannot read and write simultaneously.
USB 3.0 and greater fixes the bandwidth issue, but the weardown of the flash memory is still very problematic.
I recommend you install Ventoy to a USB, download an ISO of LinuxCNC from the downloads page, and install to an HDD from that.
Chrome downloads files slowly for some reason, use Firefox, curl, wget, or JDownloader to avoid waiting all day.
You can reduce latency by setting the CPU governor to performance.
echo performance | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governor > /dev/null
I prefer Ubuntu's GRUB to Debian's.
(the Debian version is ugly)
  • DarkPhoinix
  • DarkPhoinix
01 May 2025 12:36
Replied by DarkPhoinix on topic [SOLVED]linuxcnc Latency test ambiguous results
 28:          0          0          0         18  IR-PCI-MSI 360448-edge      mei_me
 cat /etc/modprobe.d/mei*
blacklist mei
blacklist mei_hdcp
blacklist mei_me
Very nice next blacklisted intel backdoor! six windows of youtube no junction error!! But nest use rustdesk error coming
Displaying 5686 - 5700 out of 24142 results.
Time to create page: 0.403 seconds
