  • cmorley
  • cmorley
  • langdons
  • langdons
30 Apr 2025 14:26 - 30 Apr 2025 14:54
Is there a bug in the carousel component or am I doing it wrong ATC Denford
For some reason, when I wrote G4 P1000, the program paused for far longer than 1000ms or 1 second.
No clue why.
What GUI are you using?
In theory, it should not matter, but it might make a difference.
I think QtDragon has toolchanger functionality.
  • langdons
  • langdons
30 Apr 2025 14:22
What languages are you good at?
I have encountered issues with the G4 command before.
HAL ≠ G-CODE
30 Apr 2025 14:16
Probe Basic and Carousel ATC with Geneva and Stepper
Category: QtPyVCP
Any idea why such a long delay between pressing a button and the actual move?
30 Apr 2025 14:14
Replied by tommylight on topic [SOLVED]linuxcnc Latency test ambiguous results
Yes i have, but not a default config, it is for NV something or another.
Do you get the dropped connection?
Do you get joint errors?
30 Apr 2025 14:11
AC Servo tuning - Joint 0 following error at high velocities
Category: Basic Configuration
In your ini file, you have limited max_output to 8, should usually be 10.
Here is a detailed tuning guide:
Do read it fully first so you know what parts to pay more attention, no skipping steps.
And do let me know if something there can be explained better.
  • Adam Maszynotwór
  • Adam Maszynotwór's Avatar
30 Apr 2025 14:10 - 30 Apr 2025 14:15
Hello, I'm starting to restore a lathe from scrap.
My problem is ATC (we'll get to the original ATC when I start the model)
Test model:
Step PIN8 dir PIN9 LPT stepper motor
Microstep 1600
4 pockets
1 gome sensor (pocket 1)
Head lock by left rotation (example video from the web)
Component linuxcnc.org/docs/html/man/man9/carousel.9.html
Basic lathe configuration
Symptoms:
T1M6 after starting linuxcnc looks for HOME and rewinds (strangely but it does rewind)
Each successive tool, e.g. T3M6, no longer rewinds
When I start from T2 M6 it passes HOME (activating it) but no longer rewinds while in position
My observations:
Dir changes but there is no movement. which means that there are no pulses flowing to PIN 8.
M66 waits for READY signal even though nothing is happening. Only after time has elapsed does the DIR state change and then it is READY
all files below
As you know I am not strong in HAL and in English please write as if to a child
O<changetool> sub
(debug, Tool change to T#<_selected_tool>)
M68 E0 Q#<_selected_tool>  ; Wybierz kieszeń
M64 P0                     ; Włącz karuzelę
G4 P2
; Czekaj max 15s na ready (z timeoutem)
M66 P0 L3 Q15
; Jeśli timeout, zatrzymaj karuzelę i zgłoś błąd
O100 if [#5399 EQ 0] (if timeout)
  M65 P0
  (msg, Toolchange FAILED - Timeout)
  M99
O100 endif
M65 P0                     ; Wyłącz karuzelę
(debug, Tool change OK)
O<changetool> endsub
M2
[code][code]loadrt stepgen step_type=0,0,0
loadrt carousel pockets=4 encoding=counts dir=1 num_sense=1
addf carousel.0 servo-thread
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 35000
setp stepgen.2.dirsetup 35000
setp stepgen.2.maxvel 100
setp stepgen.2.maxaccel 150
setp stepgen.2.position-scale 1
net astep stepgen.2.step => parport.0.pin-08-out
setp parport.0.pin-08-out-reset 1
#net adir stepgen.2.dir => parport.0.pin-09-out
net adir carousel.0.motor-rev => parport.0.pin-09-out
#Konfiguracja carousel
setp carousel.0.scale 400
setp carousel.0.width 10
setp carousel.0.fwd-dc 10
setp carousel.0.rev-dc 100
setp carousel.0.rev-pulse 10
#Połączenie carousel z stepgen
net carousel-pos-cmd carousel.0.counts-target => stepgen.2.position-cmd
net carousel-counts carousel.0.counts <= stepgen.2.counts
net carousel-ready carousel.0.ready => iocontrol.0.tool-changed motion.digital-in-00
#net carousel-dir stepgen.2.dir <= carousel.0.motor-rev
net carousel-enable carousel.0.enable <= motion.digital-out-00
net carousel-enable stepgen.2.enable <= motion.digital-out-00
net carousel-pocket carousel.0.pocket-number <= iocontrol.0.tool-prep-number
net home-signal carousel.0.sense-0 <= parport.0.pin-10-in
#Toolchange
all files below
[/code][/code]
  • langdons
  • langdons
30 Apr 2025 13:41
Replied by langdons on topic EtherCAT + 7i96s + Internet Success
Category: EtherCAT
This is why defining variable types is such a good idea.
It avoids issues like this.
  • langdons
  • langdons
30 Apr 2025 13:40
How to change jog speed using joystick buttons (QtDragon + HAL)?
Category: HAL
A speed dial or throttle stick would be cooler.
  • Spyderbreath
  • Spyderbreath's Avatar
30 Apr 2025 13:22
Replied by Spyderbreath on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
I seem to of been wrong about converting the ST-link to DAP. I just went back and watched the video again and there were originally 2 steps in doing the conversion, but there is the post below that video - forum.linuxcnc.org/18-computer/44828-rem...rd?start=2050#321860 - that says to just use that one file?
I am now very confused and the computer says the converted ST link is an unrecognized device and it does not show up. I can not communicate with the link plugged into the USB
At this point I truly do not know what to do.
  • alexandrap
  • alexandrap
30 Apr 2025 13:16
Replied by alexandrap on topic Updating pncconf for 7i95t
Category: PnCConf Wizard
Yes, excellent tool , but I can't create a spindle configuration with a servo motor drive (step-dir chinese servo T3D) using CT2 - I was hoping that pnconfig knew that.
I'm afraid I don't have enough knowledge to manually insert component lines into an already created configuration file (CT2).
  • IB_CnC
  • IB_CnC
30 Apr 2025 12:32 - 30 Apr 2025 12:35
Category: QtPyVCP
Basic homing and CW/CW rotation indexing working fine now!
Altough it responds with a small delay (due to the stepgen PCB)
Some vids:
Next step is mapping and wiring the other sensors!
  • DarkPhoinix
  • DarkPhoinix
30 Apr 2025 11:31
Replied by DarkPhoinix on topic [SOLVED]linuxcnc Latency test ambiguous results
No, not yet.
Now is that point where you upload your configuration files here so we can have a look, joint errors are usually miss configuration on stepper systems.
What board are you using?
Hi tommylight, have you seen my configuration? is a default conf.
  • csurimilan
  • csurimilan
30 Apr 2025 11:06
Category: HAL
Hi everyone,I'm using QtDragon and a joystick (via
hal_input
) to jog my machine. Jogging works fine with a costant speed, but I’d like to adjust the jog speed using two buttons — one to increase and one to decrease the speed. (like the slider in the Qtdragon gui)
  • JT
  • JT's Avatar
30 Apr 2025 10:19
Replied by JT on topic Updating pncconf for 7i95t
Sorry so slow but massive interruptions and a few train wrecks to clean up...
I have the 7i95t working completly now and would like to share what I've learned about getting this board to work with linuxcnc 2.10pre. MesaCT tool 2.1.7 doesn't currently support the 7i95t
I just ran MesaCT 2.1.7 and pressed two buttons and created a working configuration for a 7i95T.
JT
Displaying 5806 - 5820 out of 24148 results.
Time to create page: 0.277 seconds
