  • dctrytsman
  • dctrytsman
25 Apr 2025 07:25
Replied by dctrytsman on topic Spindle Gear changing
My spindle has an encoder on and at the moment, regardless of what gear I am in, it will always run at the selected RPM. I tested this, I selected the low gear ratio manually and ran S1000 M3 and it ran 1000RPM. I then did a M5, set the gear to high ratio manually, set S1000 M3 and the spindle ran at 1000RPM.
Unfortunately there is no clutch on the gearbox so I wont be able to change gears while running.
I basically just need a way to change gears automatically when a spindle speed command is given. When a S command is given, the spindle should first stop if it is running, then change to the appropriate gear based on the S command given, then start and run at the commanded speed. If possible, I would like the spindle to stop, then run at a very low rpm , then change gears if needed, then run at the given rpm.
Is there any way to implement this ?
  • Aciera
  • Aciera's Avatar
25 Apr 2025 06:59
Replied by Aciera on topic XHC-HB04 Pendant, Solving Jerky Movement
Category: Basic Configuration
Best way to get code changes for specific hardware into master would be to create a pull request with the description of the issue and the proposed (and tested) changes.
github.com/LinuxCNC/linuxcnc
  • Aciera
  • Aciera's Avatar
25 Apr 2025 06:48
Replied by Aciera on topic Creating Subroutines for ngcgui
Category: O Codes (subroutines) and NGCGUI
@max68
No double posting please.
  • aDm1N
  • aDm1N's Avatar
25 Apr 2025 06:04
Replied by aDm1N on topic ChatGPT LinuxCNC Assistent
Category: Configuration Tools
That's the current status. A few startup errors have gone away, but I think I need to change the entire pin assignment now. Are there any other serious errors you see besides the pin assignments?
File Name: custom_2025-04-25.hal
File Size:3 KB
File Name: my-lathe_2...4-25.ini
File Size:2 KB
  • fery15sty
  • fery15sty
25 Apr 2025 03:46
Replied by fery15sty on topic spindle speed mode to c-axis mode (cnc-lathe)
exactly right. all my logic changed to base-thread.. and the spindle rotation works as expected. spindle speed mode or c-axis mode.
thank you PCW
best regards
  • PCW
  • PCW's Avatar
25 Apr 2025 02:46
I would think Logic should be possible with stepgen signals if
you addf the logic components to the base thread instead of the servo thread.
  • fery15sty
  • fery15sty
25 Apr 2025 02:01
I tried using two modes on the lathe spindle.
I want to be able to change the spindle speed mode to c-axis mode which can be changed by entering Mcode
Here is an example of my code:
net caxis-cc-step <= stepgen.2.up
net caxis-ccw-step <= stepgen.2.down
net mode-caxis => and2.10.in0 => and2.11.in0
net caxis-cc-step => and2.10.in1
net caxis-ccw-step => and2.11.in1
net caxis-cc-out and2.10.out => or2.6.in0
net caxis-ccw-out and2.11.out => or2.7.in0
net spindle-cw-step <= stepgen.4.up
net spindle-ccw-step <= stepgen.4.down
net mode-spindle => and2.12.in0 => and2.13.in0
net spindle-cw-step => and2.12.in1
net spindle-ccw-step => and2.13.in1
net sp-cc-out and2.12.out => or2.6.in1
net sp-ccw-out and2.13.out => or2.7.in1
net servo-cc or2.6.out => parport.0.pin-08-out
net servo-ccw or2.7.out => parport.0.pin-09-out
M198 code:
#!/bin/bash
halcmd sets mode-caxis True
halcmd sets mode-spindle False
exit 0
M199 code:
#!/bin/bash
halcmd sets mode-caxis False
halcmd sets mode-spindle True
exit 0
I have tried all the codes above. M-code works well, it can change the spindle mode to c-axis or c-axis to spindle mode. but the resulting signal is not perfect.
I assume that the stepgen signal cannot use and2 or or2 logic, so that the stepping signal is damaged?
  • Chef_2
  • Chef_2
25 Apr 2025 01:29
Replied by Chef_2 on topic Umstieg auf LinuxCNC mit RaspberryPi4
Category: Deutsch
Uhi, das ist ja süß... all in one.
Ja viel können muss das nicht... Es handelt sich um eine Drehmaschine...
Ich habe aktuell dieses Interface:
www.sorotec.de/shop/Interface-Advanced-PRO.html
Mir geht es für das erste erst mal darum, mich mit diesem LinuxCNC zu befassen...
Ich hoffe es gibt hier sehr Hilfsbereite und schlaue Menschen in diesem Forum... ich selber kontruiere und baue Maschinen inkl. Elektrik aber bei Software ist es bei mir dann vorbei.
  • PCW
  • PCW's Avatar
24 Apr 2025 22:56
Replied by PCW on topic LinuxCNC S-Curve Accelerations
Tried this out but got following errors with large acceleration violations
Running the LinuxCNC logo:
  • PCW
  • PCW's Avatar
24 Apr 2025 22:10
Replied by PCW on topic spindle with encoder
How many degrees of backlash at the spindle?
 With this and the thread pitch, you could determine
the Z axis error caused by the backlash to see how serious it is.
I guess you could even make a hal backlash component for the
encoder position if need be. (create a deadzone on reversals)
  • billru
  • billru
24 Apr 2025 21:57
Replied by billru on topic Stepper motors for a EtherCat system
Thank you for the feedback
  • rodw
  • rodw's Avatar
24 Apr 2025 21:21
WEMAS MT 32 CNC Lathe -> LinuxCNC - Mesa or EtherCAT?
Category: Turning
If you wanted to use handwheels, consider Mesa over Ethercat.encoder/counter. Required Ethercat modules are expensive.
  • rodw
  • rodw's Avatar
24 Apr 2025 21:12
Replied by rodw on topic Stepper motors for a EtherCat system
I have found it is better to use a matched pair motor/drive combo
I have had good luck with Rtelligent ECT drives matched to their closed loop steppers.
I could not get their ECT86 (NEMA34) drives working with NEMA23/24 motors.
  • rodw
  • rodw's Avatar
24 Apr 2025 21:06
Replied by rodw on topic LinuxCNC S-Curve Accelerations
hi
in my last test there was no following error on gcode running, the problem was the very low acceleration.
following errors appears on homing procedure
cia402 defines pins to set velocity and acceleration while homing. 0x6099 and 0x609a
  • rodw
  • rodw's Avatar
24 Apr 2025 21:02
Can we test the cia-402 and shortcut linuxcnc pos-cmd to pos-feedback so
there is no ferror in linuxcnc that can trigger a motion stop?
Or test it by hooking the cia-402 to a stepgen or pid without closed loop feedback.
The only time this is necessary is during internal homing (if used). During homing, motion is happening that Linuxcnc does not know about so it generates a following error if this is not done.
In the drive, motion is measured in encoder pulses and in Linuxcnc uses device units
One of the other  things the cia402 component does is scale the encoder pulses to Linuxcnc device units (mm or inch)
It depends on the drive but many of them will have a SDO that tells the drive to use open loop or closed loop. There are some reasonably cost effective open loop Ethercat cia402 drives from Rtelligent and Leadshine. Both offer drives that can control two open loop stepper motors. The Rtelligent ECR60X2A is USD $60 each ex works (for 2 steppers).
Displaying 6241 - 6255 out of 24064 results.
Time to create page: 0.517 seconds
