  • wrhammer
  • wrhammer
20 Apr 2025 03:24
Replied by wrhammer on topic Remap M6 in python
Remap M6 in python
That was it, adding the self.task == 0 at the beginning solved the read ahead issue and removing the yeilds in the middle of the g-c-code operation took care of it! Behaves like expected, M-codes execute and the tool change executes with the offset. Got quite a few commits trying to troubleshoot this one. Thanks for the help!
  • notJamesLee
  • notJamesLee
20 Apr 2025 00:44
Replied by notJamesLee on topic Determining Angular Scale - Help w/ Microsteps
Category: Configuration Tools
update,
I changed the number to in the driver gui to 1800 and upped the 'stepsPerRev' variable in the Arduino code to 600 and its working great so far. This is with the dip switches set at default.
If i switch the dip switches to 1600, the value in the gui updates to 1600. So this leads me to believe the dip switches set the steps per revolution. in retrospect i guess its obvious.
I am going to leave it as is because its clean and now going to switch the control to closed and see about tuning in the PID before i reinstall it on the CNC. unless thats not a good idea.
19 Apr 2025 23:56 - 20 Apr 2025 00:04
Replied by tommylight on topic Should I switch from AXIS to QtDragon?
Category: Qtvcp
I have no quality mice available.
I have plenty, you are welcomed to use them, but i can not guarantee the quality! They do chew on everything in the shop though, seem pretty healthy by the looks and the speed they move through the shop. :)
Edit:
The evidence of the above:
forum.linuxcnc.org/show-your-stuff/32784...ofit?start=30#239606
  • IB_CnC
  • IB_CnC
19 Apr 2025 23:44 - 19 Apr 2025 23:55
Probe Basic and Carousel ATC with Geneva and Stepper
Category: QtPyVCP
In order to control the ATC stepper motor like a "dumb DC motor" with just the DI-Outputs mapped to my MESA outputs and free up the stepgen on the MESA for other future purposes, I simply purchased a step generator from amazon (10 bucks) and two relays.
I will just use the relays to trigger the board start/ stop and direction tactile buttons (solder to button pins).
Should work fine in combination with the geneva drive.. :-)
I still have to find good sensor flag positions for Home and Index, but that should be solvable.
  • langdons
  • langdons
19 Apr 2025 23:36
Replied by langdons on topic Should I switch from AXIS to QtDragon?
Category: Qtvcp
AXIS has better keyboard shortcutrs in theory, though many of them simply do not work for no reason at all in reality.
My mouse on the PC is poor (I dropped it on the hard concrete floor a couple times).
The keyboard is PS/2, I have lots of keyboards, but I am low on mice.
  • langdons
  • langdons
19 Apr 2025 23:32
Category: Qtvcp
My CNC PC has a nice 1920x1080p 60Hz LCD over DisplayPort via the iGPU.
It has no dedicated GPU.
  • notJamesLee
  • notJamesLee
19 Apr 2025 21:29
Okay so i confirmed that 1600 is the number, but this just makes me question what the micro steps are doing. Its clear i don't know what the step/rev actually translate to.
I guess i am just looking for what the optimal dip switch stetting is for my setup and what this number should be.
This software seems to have a decent scope as well. Is there any reason i shouldn't use this to tune the PID and get it close before moving to LCNC? It just easier when its all on the test bench. I know alot of wiring noise factors in it final resting place will make a difference but could i get it close here? or would the new environment completely change the PID settings?
19 Apr 2025 21:28
Replied by tommylight on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
If the power supply can do over 2A of current, yes you can use the same supply.
And no, that 2A is not related at all to the 2A written on the drive.
  • notJamesLee
  • notJamesLee
19 Apr 2025 21:12
Hi Friends,
catching up on replies now, i was out traveling for work the last few days. Here are the links to the motor and driver i am using.
Motor
Driver
Ill try to reply to everyone in this one reply to avoid any confusion, and ill to to work backwards as much as possible.
@Langdons
 - Does speed make a difference?
No it doesn't seem like it. The Arduino code i am running does  a slow loop and a fast loop changing the delay int between steps and its been consistent every time. Although i haven't cranked the speed up and don't plan on it.
@andypugh
- you are correct, i am trying to understand the most optimal way to get this into Lcnc and based on previous posts I can maybe modify the drivers software to make that a whole number. Still investigating this though.
@timo
- I have and it works as expected and repeatably. The issues comes up when i put it into the pulley system, with the reduction i can't hone in a precise step/rev, from which i can derive the steps/deg for a rotary axis in LCNC.
- in regard to the pulleys, I am certain the motor pulley isn't (the ole sharpie method) the idler doesn't count, and no am im not 100% certain that the drive shaft is fixed in place, however with everything powered down i can turn the drive shaft and it turns the motor pulley. that on top of the low speeds and it being uploaded gives me a decent amount of confidence in my answer.
- I also haven't even begun to tackle any of the encoder/ pid error stuff because when i tried initially i discovered this the issue we're dealing with now, that comes next once i have this setup pretty good.
@spumco
- This is my plan. I have the cable and am able to get it to talk to my PC, the issue is once i get it its all french to me. How would i verify the 4:1 encoder resolution? Should the drive be connected to the motor when i do this? I am going to spend the next few hours messing with it on the software side and ill report back what i learn or how i mess up.
Thank you all again,
  • DarkPhoinix
  • DarkPhoinix
19 Apr 2025 21:09
Replied by DarkPhoinix on topic Remora - ethernet NVEM / EC300 / EC500 cnc board
Driver:TB6560 JP-1635A
Steper:  57hdd0401
In your opinion is it safe to connect this driver and stepper?
Can I use the same 24V power supply that I use to power NVEM or is it better to use a separate one?
I only need it to test the jjdege conf (if I'm not mistaken it's the same conf as mine then it will tell me nvem-rt1052.txt)
to check the outputs.
I will never use this driver-stepper as a final solution.
  • meister
  • meister
19 Apr 2025 21:03
rio can now can :)
odrive(modded) via can-bus in an icebreaker board with rio:
  • rodw
  • rodw's Avatar
19 Apr 2025 20:38
Replied by rodw on topic Custom interface board questions
You won't need to develop a driver, you just need to write an xml file.
the wiring is substantially reduced using Ethercat drives over mesa.
Do you really need an encoder? The only purpose I can see is rigid tapping but thread milling is more efficient and it does not require it.
Everything about Ethercat is more expensive but it is the emerging standard. It does add a bit of complexity to the config. The bit that is not really worked out is the internal drive homing but using Linuxcnc homing is just as simple as mesa. I've had good luck finding reasonably priced Beckhof modules on ebay (including encoders) but some are outrageously priced, more expensive than new modules.
Ethercat with rs485 controlled VFD is the simplest way to run your spindle but there is now a linuxcnc driver for Omron mx2 VFD's .
  • RobotMatic
  • RobotMatic's Avatar
19 Apr 2025 20:30
Replied by RobotMatic on topic MPG " la conexion mas simple !! "
Category: Español
File Name: jog_ui_29.hal
File Size:2 KB
Para la version actual de linuxcnc2.9x ,el archivo  jog_ui.hal que mensiono en el inicio de este hilo necesita una actualizacion.
Adjunto aqui arriba el archivo jog_ui_29.hal donde esta implementado el mismo funcionamiento con axisui.
  • rodw
  • rodw's Avatar
19 Apr 2025 20:07
Replied by rodw on topic Should I switch from AXIS to QtDragon?
Category: Qtvcp
its just all round better if you have a 1080p rouch screen, plus it adds probing and too handling if you have repeatable tooling.
it is very well documented
  • Cynas
  • Cynas
19 Apr 2025 18:25
Replied by Cynas on topic NativeCam on LinuxCNC 2.9.3
Category: NativeCAM
Thank you all for your time for NativeCam,
Does the configuration for the lathe work?
Milling machine and plasma work without any problems, unfortunately configuration but lathe does not start
Thank you for your help
Displaying 6511 - 6525 out of 24030 results.
Time to create page: 1.097 seconds
