  • Muzzer
  • Muzzer
22 Nov 2025 16:01
Updating from LINUXCNC - 2.8.4-23, Mint 20.3 - gmoccapy lathe structure
Category: Gmoccapy
Yes, I used the official LinuxCNC ISO. I see what you mean about XFCE, in contrast to the previous Mint GUI.....
Had a few problems installing it, which may have been due to using a 256GB UFD. Changed to a 16GB and it went well, whether that was the problem or not.
Now I have a functioning OS, I will have a go at reinstituting gmoccapy.
  • mooser
  • mooser
22 Nov 2025 15:58
latency (netowork?) 7010 with 7i96s+7i84u
I'm setting up a new system and I'm sometimes getting a unexpected realtime delay on task 0 with period 1000000 error (mostly on startup) and there was a few error finishing read ones as well. After much reading and tinkering I've got it to this point and I'm not sure if it's OK or not.
7010, all the extra anything in the bios has been turned off, only using the 1 core
built in intel network controller, onboard graphics
Ping 192.168.1.121 was up around 350ms, made the changes to the networks file and it is about 150ms now, mainly sits just under 100ms so I think the network to card connection is ok.
Histogram looks pretty "fat" though ???
Also had a tri-peak at one point... might have been a glitch though
Is it safe to just bump the period up some or is there something I can actually do to make this better
M
  • unknown
  • unknown
22 Nov 2025 15:55
  • bszoke
  • bszoke
22 Nov 2025 15:41
Replied by bszoke on topic StepperOnline A6 Servo
Category: EtherCAT
I was responding to  MWalz  13 Jan 2025 21:26  #318886  on this thread.
  • TripleM
  • TripleM
22 Nov 2025 15:26 - 22 Nov 2025 15:28
Gewindeschneiden G33.1 k-word missing.
Category: Deutsch
beim Gewindeschneiden mit 33.1 wird eine Fehlermeldung ;missing k-word" ausgegeben, obwohl es vorhanden ist.
Wenn man die Meldung ignoriert, wird er ausgeführt, allerdings bleibt der Programmlauf daraufhin stehen.
Im MDI funktioniert der Befehl allerdings problemlos.
Funktioniert der Befehl bei euch?
Gruß
  • BoMadsen
  • BoMadsen
22 Nov 2025 14:27
Replied by BoMadsen on topic 7i76eu steppers don't move
Category: Driver Boards
PCW you are impressive! I checked the original wiring of the Mach3 board the mill came with, and it used single ended wiring using only the negative wires for STEP and DIR, so I tried to change that.
No change when using the UI, it still shows following error. But then I tried the servo tuning test in pncconf, and the steppers are now moving :)
Now I just need to figure out the following error, but at least now I know that the hardware is working.
Thank you very much, your help is much appreciated!
  • Sekai
  • Sekai
22 Nov 2025 13:08
Replied by Sekai on topic Chinese Mesa 7I92 from aliexpress NEW
I think the max value is to high.
Maybe the cpu needs to tweak?
  • abs32
  • abs32
22 Nov 2025 12:37 - 22 Nov 2025 12:42
Probe tripped during non-probe move deadlock
I installed version 2.9.4 and 2.9.7 and they work worse, replacing this error with another one - Queue is not empty after probing.
In this regard, I ask you to publish a complete road map on what is quoted here forum.linuxcnc.org/38-general-linuxcnc-q...obing?start=0#333528"
a solution to this topic.
It says about "Great HAL": www.forum.linuxcnc.org/38-general-linuxc...dlock?start=0#332412
Now I have such entries in hal -
net probe-in <= parport.0.pin-13-in-not
net probe-in => motion.probe-input
By analogy with "Great HAL" I assume this -
loadrt flipflop count=0
loadrt flipflop count=1
addf flipflop.0                 servo-thread
addf flipflop.1                    servo-thread
setp   flipflop.0.set FALSE
setp   flipflop.0.data  TRUE
net probep-in        parport.0.pin-13-in-not  => flipflop.0.clk #при этом отключить базовый вариант
net probere-set      motion.digital-out-00    => flipflop.0.reset
net probefiltered   flipflop.0.out           => motion.probe-input  parport.0.pin-01-out
However, how can this be related to the M64 P0 + M65 P0 call?
It is not clear why the Greet HAL example contains addf flipflop.1 (in addition to addf flipflop.0) if flipflop.1 is not used in any way according to the example?
  • 1911ut
  • 1911ut
22 Nov 2025 12:37
Replied by 1911ut on topic Is something up with 2.9.7 (joint errors)
Thanks for you help.
I found the problem, I guess I am getting too old. (72)
It was a new install and I copied the wrong hal configuration.
I do regular backups and name folders by date (2025-11-11)
I must have read the folder wrong.
Culprit was
setp pid.x.maxerror 0.0005
Every thing is back to normal
  • PCW
  • PCW's Avatar
22 Nov 2025 12:35 - 22 Nov 2025 12:49
Replied by PCW on topic 7i76eu steppers don't move
If you get a following error, no further movement will be possible so a configuration
issue the causes a following error is s show-stopper.
Other possible reasons for no motion are wrong scaling, too short step lengths
high drive requirement (try single  ended wiring rather than differential)
Single ended wiring:
DRIVE STEP+  --> 7I76EU STEP+
DRIVE STEP-  --> 7I76EU GND
etc
  • Lcvette
  • Lcvette's Avatar
22 Nov 2025 12:31
probe_basic_postgui.hal conflicts with my gamepad*.hal
Category: QtPyVCP
yeah, think that is all machines, but could be wrong
  • BoMadsen
  • BoMadsen
22 Nov 2025 12:25
I think you are spot on with the "enable" output comment, the motors where not locked. I disconnected "EN+ -> TB2 pin 6 +5VP" and bingo, the motors where locked. So far so good, thank you :) I have measured Dir+/- and the voltage here change when I jog the axis.
But alas, the motors will still not move. How ever, now I get the "Joint 0 following error" immediately when I try to move the X axis, so I suspect this is why nothing is moving. I have tried to read up on the error, and it seems to point at a misconfiguration in the PID/Acelleration/etc part of the config. But I can't really see it being SO wrong, that the motor won't start at all?
  • juergen-home
  • juergen-home
22 Nov 2025 12:19
Category: QtPyVCP
Found it out myself: it was: Is it a known problem that in "linuxcnc probe basic sim" jogging is not working after a program was run.
Workaround: clicking the “Manual” button after stop.
  • Lcvette
  • Lcvette's Avatar
22 Nov 2025 12:05
Category: QtPyVCP
great glad you got it sorted out! what thread for the other issue, i do not see it in the qtpyvcp section?
  • PCW
  • PCW's Avatar
22 Nov 2025 11:47
Replied by PCW on topic Chinese Mesa 7I92 from aliexpress NEW
The watchdog error is a sign of network latency issues.
I would try:
sudo chrt 99 ping -i .001 -q-c 60000 10.10.10.10
which should run for 1 minute and then print timing statistics
to see if this is the issue.
Displaying 11041 - 11055 out of 11230 results.
Time to create page: 0.276 seconds
