  • endian
  • endian's Avatar
11 Nov 2025 20:18
Replied by endian on topic Ethercat HAL driver
Ethercat HAL driver
Category: EtherCAT
Translate it as complex . Import it as s32 or u32.. Then create simple component to cut it a pieces... Simple and effective
  • Masiwood123
  • Masiwood123's Avatar
11 Nov 2025 20:14 - 11 Nov 2025 20:24
  • Masiwood123
11 Nov 2025 20:12
Replied by Masiwood123 on topic beta bulleri for retrofit?
Category: CNC Machines
watch both videos, I think the following is motor tuning, connecting the home switch, and again I have a problem with the keyboard, the velocity changes when jogging, I need to find Tommylight's post on how to solve it. thanks:)
  • DemonClaW
  • DemonClaW
11 Nov 2025 19:16 - 15 Nov 2025 07:50
Beckhoff Problem with Communication (TwinCAT, LinuxCNC)
Category: EtherCAT
Hey Guys,some of you know so much about this Topic so I hope I can find someone in the mood to help me.Im trying to make a CNC 3-Axis on Raspberry PI5 and Beckhoff, the problem is that im completly new in this topic and try to learn as much as possible but i got already stuck in the beginning. EtherCAT works fine and i got the "Koppler" and Cards but if im trying to get them into LinuxCNC like some videos teach the Programm wont start anymore
If i start i get the message: Failed to register PDO entry: No such file or directory
LCEC: master 0 PDO enty registration failed
A friend and myself checked the code 10x, and it seems that the problem starts before. I cant get the EK1100 connected to TwinCat or CodeSYS, too. Whats kind of weird to me because as i said if I try it with the "ethercat slaves" command, it knows The Ek1100 and all Cards
Thanks for everybody who can help me with this and invests some of his time for me
  • zz912
  • zz912's Avatar
11 Nov 2025 18:58
Replied by zz912 on topic Compile files in /linuxcnc/lib/
You probably don't need to compile the gtk_little_probe.py file.
Python is an interpreted language, so often you just need to make the edits and run the code.
It is true, but not in LCNC.
If I modify this file:
/home/zdenek/linuxcnc/linuxcnc-zz912/src/emc/usr_intf/gmoccapy/gmoccapy.py
It returns:
zdenek@cnc:~/linuxcnc/linuxcnc-zz912/src$ make
Reading 203/203 dependency files
Done reading dependencies
Reading 274/274 realtime dependency files
Done reading realtime dependencies
make: Vstupuje se do adresáře „/home/zdenek/linuxcnc/linuxcnc-zz912/src“
Syntax checking python script gmoccapy
Copying python script gmoccapy
You now need to run 'sudo make setuid' in order to run in place with access to hardware.
make: Opouští se adresář „/home/zdenek/linuxcnc/linuxcnc-zz912/src“
The most important sentence is:
Id dont know why and where, but it works.
gmoccapy.py is in /src/ folder and it works.
I placed the wrong file here, I meant:
/linuxcnc/lib/python/gladevcp/builtin-panels/gtk_verser_probe/gtk_verser_probe.py
You can try modify it, but noting happens.
MAKE doesnt see it.
  • Hakan
  • Hakan
11 Nov 2025 18:30
Replied by Hakan on topic Ethercat HAL driver
Ethercat HAL driver
Category: EtherCAT
The array data types are not implemented in linuxcnc-ethercat.
Not 100% sure about IgH Ethercat master.
  • Masiwood123
11 Nov 2025 18:15
i will make short video what is all about that problem later.
  • Hakan
  • Hakan
11 Nov 2025 18:14 - 11 Nov 2025 18:16
Replied by Hakan on topic Trouble with Cia402 drive configuration
Category: EtherCAT
The following error can be large due to physical reasons, such as the axle sticking, tool breakage, etc.
With a good FERROR setting, the machine stops with a warning instead of destroying all sorts of things.
That's what you want. When the servos are working well, you should tighten the FERROR values ​​to get that protection.
Normally, values ​​are specified in the INI file.
With Ethercat it isn't so stream-lined yet, some values are set directly in the hal file like the pos-scale.
You can do it yourself, but it often introduces one more level of complexity when one just wants the machine to work.
In the ini file create a [ETHERCAT] section like below
[ETHERCAT]
CIA402_POS_SCALE_X = 200.0
and more
and use it in the hal file
setp cia402.0.pos-scale [ETHERCAT]CIA402_POS_SCALE_X
Optional.
I am not the right person to elaborate on ethercat homing.
I use linuxcnc's homing variant with switches in the traditional way.
Many people have used ethercat homing, search the forum, or maybe someone chimes in.
There are 3-4 lines mentioning homing in the cia402 documentation github.com/dbraun1981/hal-cia402
  • Masiwood123
11 Nov 2025 18:08
 thank you very much for the answer, it will certainly help me later, now i have come to the conclusion that I could destroy the drivers by bringing 24v for enabling, it did not occur to me that the old controller gives 10v on that output, otherwise they are all 24vdc. and now here in the picture you can see these white wires, they are connected to enable on pin 7, however, the pin 6 from the driver just gives 10v and then I managed to short-circuit to pin 7 and the drivers are enabled, however, I still need to understand the estop chain so that the switch that supplies power to the drivers would stick, when I turn it on manually, the axes slide slightly to one side, maybe mm/min, I assume that the offset on the trimmer is not well adjusted, But, when all that I did it via the Mesa 7i77 card, i installed enable and brought the wires for the analog signal of the axis, when i start linuxcnc machine F2  axis move a little and stop(joint following error) (I will have to try to tune the motors first or maybe I should try to turn the analog wires ref and ref-?
  • ruediger123
  • ruediger123
11 Nov 2025 18:01
Replied by ruediger123 on topic Ethercat HAL driver
Ethercat HAL driver
Category: EtherCAT
Hello,
I try to integrate the security plc from Sick Flexi Soft via ethercat but I get the message that bitLen only allows 32 bits.
Are the restrictions limited to Linuxcnc-ethercat or do they also apply to the IGH ethercat-master.
  • PCW
  • PCW's Avatar
11 Nov 2025 17:26
Mesa 7i96s Torch on and arc ok problems?
Category: Plasma & Laser
It look basically OK but I do not have information on the plasma source pinout
  • andypugh
  • andypugh's Avatar
11 Nov 2025 17:06
Replied by andypugh on topic Compile files in /linuxcnc/lib/
So, the reason that "make" is not doing anything is that the file in question is not mentioned in the makefile, as it is simply interpreted as and when needed.
(There is a complication that Python code is compiled to bytecode (.pyc) and sometimes that might be run instead.)
To be sure that your edited file is running, maybe put a "print("this is version 2.2.2") near the top of the file?
  • Lcvette
  • Lcvette's Avatar
11 Nov 2025 16:45
Replied by Lcvette on topic Probebasic tool length calculation
Category: QtPyVCP
G49, did you modify your tool setter macro? If not I would check that your var file and pb version are all correctly aligned and the parameters are storing in the var file.
11 Nov 2025 16:38
Replied by tommylight on topic beta bulleri for retrofit?
Pots do not work with digital inputs, but encoders do, so given enough space the pots can be switched for encoders.
For rough analog, Mesa 7i77 has 4 analog inputs (in0-in3) when set in mode 2, you can try that and see if it is usable for you.
For outputs, 2.10 (or Master) has a nice feature where you can toggle inputs and outputs from the "show hal configuration" menu, so add the Mesa outputs by assigning some random names to pins, then use the above to toggle on and off outputs by clicking on SET or clear, as shown bellow:
  • peterpan
  • peterpan
11 Nov 2025 16:03
Replied by peterpan on topic Trouble with Cia402 drive configuration
Category: EtherCAT
I figured out how to setup homing mode in the ClearView software, and setup a home sensor, but I have no clue how to make it start homing when home is pressed in linuxcnc. I assume I need to do something with the joint.0.index-enable pin?
Displaying 11191 - 11205 out of 12825 results.
Time to create page: 2.296 seconds
