  • abs32
  • abs32
05 Nov 2025 18:59
Probe tripped during non-probe move deadlock
Colleague, please publish the entire part of the hal file for controlling the probe shutdown? Including the commands addf + loadrt + something like this net probepin parport.0.pin-13-in-not => and2.3.in0
  • abs32
  • abs32
05 Nov 2025 18:56
Replied by abs32 on topic Issue with G38.5
Issue with G38.5
vers 2.84.
  • Hakan
  • Hakan
05 Nov 2025 18:41
Replied by Hakan on topic SANGE elec IO
SANGE elec IO
Category: EtherCAT
Not so good news, but good with feedback. Will help the next guy to make a decision.
I guess the I/O module isn't EtherCAT certified if it performs so poorly?
  • Hakan
  • Hakan
05 Nov 2025 18:29
Replied by Hakan on topic Trouble with Cia402 drive configuration
Category: EtherCAT
Looks like the slaves are out of order, I mean disorder, not right numbered.
Check with "ethercat slaves" that the cia402 drive really is slave 3.
Looks to me like the Beckhoffs didn't start up properly.
05 Nov 2025 17:54
Replied by tommylight on topic booten dauert lange 1min 30 sek , alles ok
OK, that needs editing the /etc/fstab file and omitting or deleting the line containing the uuid of the missing drive.
In a terminal:
sudo nano /etc/fstab
edit and save with
CTRL+o and exit with CTRL+x
Do mind that deleting or omitting the wrong uuid will fail to boot completely.
  • SvenRSA
  • SvenRSA
05 Nov 2025 17:33
Replied by SvenRSA on topic proudly presenting a Maho MH700 retrofit ..
Category: CNC Machines
Thanks. I’m having a hard time reading the ini and HAL file I can seem to find the Scale value for the B axis in his files. And the touchy/ axis version don’t want to launch on my newer version. Was just taking a shot in dark.
  • bentiggin
  • bentiggin
05 Nov 2025 17:25
High frequency ohmic struggles was created by bentiggin
Category: Plasmac
I am trying to get ohmic sensing to work using a mesa 7i97t, thcad-2(jumpers on low range and 1/32), and a 24v power supply(meanwell hdr-15-24).
I have tried rodw's ohmic comp and ohmic comp3, as well as try many variation in the hal file mentioned in the original ohmic post/thread on this forum.
While I have no doubt there are issues with my hal file, I can't seem to get any response from the encoder in halshow, so I'm starting to wonder if I'm even getting a signal.
I tried using a multimeter to test the thcad outputs, but I don't know what I should be looking for. Is there a good way to test this?
I have it wired up similar to the diagram in the manual. I am using a 370k(or maybe 390k, can't remember) resistor between 24v+ and the thcad.
Since all the controls are on the gantry(this is a retrofit), I connected the 0v on the power supply to the buss bar on the gantry which in turn is wired to the star ground on the frame. I also connected the thcad shield terminal to the same buss bar.
The plasma is a ht hsd130 which uses a high frequency start. I previously damaged a 7i97t(which has been replaced) starting the plasma. I wonder if I could have damaged the thcad, as well.
How can I protect the mesa boards from the high frequency start? Would a relay between the torch tip and thcad be enough? I assume it would need to be a special relay.
Attached is a hal file I have been using.
  • deltafox24
  • deltafox24
05 Nov 2025 16:56 - 05 Nov 2025 16:59
Replied by deltafox24 on topic Rotary axis in Qtdragon_hd
Category: Qtvcp
 Hello, everyone! I'm writing here so as not to clutter up the forum with unnecessary topics.
I can't seem to properly configure the display of the rotation axis on QtDragon.
I tried setting GEOMETRY=AXYZ  and GEOMETRY=!AXYZ, and I changed both TRAJ and  KINS, but the rotation axis is still not displayed. For example, in this code there are 4 rotations of the A axis, but it draws like this
  • peterpan
  • peterpan
05 Nov 2025 16:37
Replied by peterpan on topic Trouble with Cia402 drive configuration
Category: EtherCAT
Hate to open this back up, but after a 2-week hiatus I came back and linuxcnc doesn't seem to start with the Clearpath drive connected. I don't recall editing anything since it was working, but I doubt that's actually possible. It might be something simple, but here's the error:
dmesg
[  +0.000006] EtherCAT 0: Slave states on main device: INIT, OP.
[  +0.000002] EtherCAT 0: Re-scanning now.
[  +0.002280] EtherCAT 0: Scanning bus.
[  +1.647025] EtherCAT 0: Bus scanning completed in 1648 ms.
[  +0.000006] EtherCAT 0: Using slave 0 as DC reference clock.
[  +0.014687] EtherCAT 0: Slave states on main device: PREOP, OP.
[  +3.742316] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:07!
[  +0.000006] EtherCAT ERROR 0-0: SDO abort message 0x06090011: "Subindex does not exist".
[  +0.003995] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:08!
[  +0.000002] EtherCAT ERROR 0-0: SDO abort message 0x06090011: "Subindex does not exist".
[  +0.005998] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:0A!
[  +0.002995] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:0B!
[  +0.000001] EtherCAT ERROR 0-0: SDO abort message 0x06090011: "Subindex does not exist".
[  +0.005999] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:0D!
[  +0.003001] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:0E!
[  +0.002997] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:0F!
[  +0.002998] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:10!
[  +0.000003] EtherCAT ERROR 0-0: SDO abort message 0x06090011: "Subindex does not exist".
[  +0.002999] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:11!
[  +0.002999] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:12!
[  +0.002993] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:13!
[  +0.003003] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:14!
[  +0.002994] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:15!
[  +0.003000] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:16!
[  +0.002999] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:17!
[  +0.002997] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:18!
[  +0.003001] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:19!
[  +0.002995] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:1A!
[  +0.003001] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:1B!
[  +0.003001] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:1C!
[  +0.000005] EtherCAT ERROR 0-0: SDO abort message 0x06090011: "Subindex does not exist".
[  +0.003988] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:1D!
[  +0.003001] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:1E!
[  +0.002999] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C32:1F!
[  +0.030001] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:07!
[  +0.003993] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:08!
[  +0.006996] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:0A!
[  +0.004001] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:0B!
[  +0.005999] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:0D!
[  +0.002992] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:0E!
[  +0.000004] EtherCAT ERROR 0-0: SDO abort message 0x06090011: "Subindex does not exist".
[  +0.003998] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:0F!
[  +0.003001] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:10!
[  +0.002998] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:11!
[  +0.002999] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:12!
[  +0.002996] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:13!
[  +0.002999] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:14!
[  +0.002998] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:15!
[  +0.002999] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:16!
[  +0.002997] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:17!
[  +0.003002] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:18!
[  +0.002991] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:19!
[  +0.003001] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:1A!
[  +0.002998] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:1B!
[  +0.002999] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:1C!
[  +0.003001] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:1D!
[  +0.002994] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:1E!
[  +0.003002] EtherCAT WARNING 0-0: SDO information error response while fetching SDO entry 0x1C33:1F!
And in the terminal running linuxcnc:
LINUXCNC - 2.9.6
Machine configuration directory is '/home/cnc/linuxcnc/configs/sim.axis'
Machine configuration file is 'axis.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./ethercat.hal
Failed to execute SDO upload: Invalid argument
LCEC: slave 0.3: Failed to execute SDO upload (0x6502:0x00, error -22, abort_code 00000000)
LCEC: slave 0.3: Failed to execute SDO upload (0x6060:0x00, error -22, abort_code 00000000)
LCEC: slave 0.3: Failed to execute SDO upload (0x607a:0x00, error -22, abort_code 00000000)
Failed to get reference clock time: Input/output error
Failed to get reference clock time: No such device or address
It says no such device or address about a bagillion times.
As always, thanks in advance!
  • karlhe
  • karlhe
05 Nov 2025 16:31
Replied by karlhe on topic booten dauert lange 1min 30 sek , alles ok
    Hallo, ich musste erst die Fotogrösse verkleinen.
jetzt das bildsckirmfoto
  • deltafox24
  • deltafox24
05 Nov 2025 16:12
Replied by deltafox24 on topic SANGE elec IO
SANGE elec IO
Category: EtherCAT
The SANGE I/O module has an unreliable EtherCAT implementation — it often loses connection and is not detected reliably in the network. The ESI file is either missing or contains errors, which requires manual editing.The polling cycle is no better than 10 ms, which is too slow for real-time control.Hardware quality is poor: weak isolation and possible false input triggers.There is practically no support from the manufacturer.
Overall, not worth buying.
05 Nov 2025 16:11
  • Aciera
  • Aciera's Avatar
05 Nov 2025 15:34
Try to activate Gladevcp with setp gladevcp -> Linuxcnc
Category: GladeVCP
Looking at your .ui file it seems that you have a 'HAL_Table' inside a 'HAL_HideTable' object:
Which would explain why this would make your panel disappear (because it is actually controlling the 'HAL_HideTable' object):
setp gladevcp.table1 1
And also why commenting it out,
#setp gladevcp.table1 1
Shows an inactive panel because 'HAL_Table' (with id=schalter)) is not set True by any signal.
  • DerKlotz
  • DerKlotz
05 Nov 2025 15:11
Category: GladeVCP
2. start your config from a terminal ($ linuxcnc) and check output for clues
[GladeVCP][INFO]  Logging to: /home/cnc/gladevcp.log (logger.py:106)
[GladeVCP.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No DEFAULT_SPINDLE_0_SPEED Entry in DISPLAY, Using: 200 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No MIN_SPINDLE_0_SPEED Entry in DISPLAY, Using: 100 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No MAX_SPINDLE_0_SPEED Entry in DISPLAY, Using: 2500 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No MAX_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 1 (qt_istat.py:532)
[GladeVCP.QTVCP.QT_ISTAT][WARNING]  INI Parsing Error, No MIN_SPINDLE_0_OVERRIDE Entry in DISPLAY, Using: 0.5 (qt_istat.py:532)
79691779
3. I would recommend using a simple texteditor to edit the files not a word processor like the one in your screen shot.
Ok
  • karlhe
  • karlhe
05 Nov 2025 14:20 - 05 Nov 2025 16:33
    Hallo,
das booten dauert lange, kann man das ändern?
karlhe
Displaying 11461 - 11475 out of 12824 results.
Time to create page: 2.855 seconds
