  • Aciera
  • Aciera's Avatar
26 Oct 2025 17:42 - 26 Oct 2025 17:44
Replied by Aciera on topic VTK based version of Vismach
Category: Show Your Stuff
It's pretty much the same. It's actually fairly straight forward once you get the hang of it but I guess that's true for everything and I must have made a couple dozen sim models by now.
ProbeBasic has machine simulation that can be setup using a yaml file (similar to what some CAM systems have) but it is quite limited compared to vismach.
  • andypugh
  • andypugh's Avatar
26 Oct 2025 17:40
Replied by andypugh on topic Festo CMMT-ST
Festo CMMT-ST
Category: EtherCAT
Your kinematics setup seems to be wrong:
[KINS]
JOINTS = 3
KINEMATICS = trivkins coordinates=XYZ
Should be 5 joints and probably XYYZZ
  • andypugh
  • andypugh's Avatar
26 Oct 2025 17:33
Proposal RPi Linuxcnc Image Based on Raspi OS All welcome/encoraged to comment
Category: Installing LinuxCNC
Just a reminder (it's way down the list of repos now) but we did previously use pi-gen to make LinuxCNC images.
github.com/LinuxCNC/pi-gen
Bitrot has probably set in, though.
  • andypugh
  • andypugh's Avatar
26 Oct 2025 17:22
how to get rid of the probed dumping non-probe mode error?
There is a motive. My 2.8.4 has a jitter in the range of 2000. It also uses the compiled module "curve geometry" (compensation of the position of the X coordinate depending on the position of the Y coordinate). There is no such module for 2.9.
I don't think that "curve geometery" was ever a built-in LinuxCNC component. Did you install it from a comp file?
If you have the .comp file then it will also work with 2.9.x once installed, but if you don't have the source file then you may be a bit stuck.
If you have 2000ns jitter then you may be using the RTAI kernel? It is possible to run LinuxCNC 2.9.x with RTAI, but it's been a while since I created an installer package. (they have to be built by hand, as the buildbot currently has no RTAI builders, and it needs modifications to the Makefile)
Having said that, I have a PC that gives 3-digit latency with both RTAI and Preempt-RT. it appears to be entirely random.
  • abs32
  • abs32
26 Oct 2025 17:13
  • abs32
  • abs32
26 Oct 2025 17:11
These are different questions and topics. In those topics where the authors forgot to say the main thing, I inserted the necessary pieces to make it easier for new users to search.
  • andypugh
  • andypugh's Avatar
26 Oct 2025 16:55
Replied by andypugh on topic VTK based version of Vismach
That's very pretty.
Is it any easier to comprehend than Vismach? I find using Vismach rather confusing (and I wrote the docs!)
  • andypugh
  • andypugh's Avatar
26 Oct 2025 16:54
Replied by andypugh on topic POSITION_FILE and index
I did something a bit like this using resolvers (with the difference being that resolvers are single-turn absolute)
wiki.linuxcnc.org/cgi-bin/wiki.pl?Psuedo-Absolute_Encoders
You probably need a realtime HAL component (or set of standard components) that zeros the absolute portion of your adder when the index is seen. This is because of the way that the joint position feedback is used in the home offset calcuations.
  • PCW
  • PCW's Avatar
26 Oct 2025 16:43
Replied by PCW on topic MESA 7I92 programming
Category: Driver Boards
This works for me:
  • andypugh
  • andypugh's Avatar
26 Oct 2025 16:41
Replied by andypugh on topic Manual tool change + tool lengh touch off
Which user interface are you using? And which version of LinuxCNC?
#### generally means that the parameter doesn't exist, but that doesn't make any sense for #5181.
You are typing (debug, #5081) not (for example) (debug, #<5081>) ?
  • Hakan
  • Hakan
26 Oct 2025 16:26
Stepper online A6 Servo motor as Spindle motor
Here is now a modified cia402 component together with a complete example on how to use PV (Profile Velcotiy) for an EtherCAT spindle drive.
github.com/MetalMusings/cia402pv
  • karlhe
  • karlhe
26 Oct 2025 16:21 - 26 Oct 2025 16:22
Replied by karlhe on topic linuxcnc bootet nicht mehr
Category: Deutsch
Hallo,
ich habe mit einem usb linuxcnc live den rechner gestartet.
dann linuxcnc damit neu installiert. mbr wurde auf der entsprechenden festplatte
neu installiert. nach fertigstellung, neu gestartet. mein Linuxcnc und die maschine laufen wieder.
  • Aciera
  • Aciera's Avatar
26 Oct 2025 16:09 - 26 Oct 2025 16:10
Replied by Aciera on topic MESA 7I92 programming
It opens a blank site but should download a .zip file (or open a popup about downloading a zip file with all the source files).
This is what I get when I click on the link in your last post:
  • TJ
  • TJ's Avatar
26 Oct 2025 15:58 - 26 Oct 2025 16:02
Replied by TJ on topic MESA 7I92 programming
A Mesa webáruházban, ha a támogatásra kattintok, csak egy üres ablakot hoz fel.
(www.mesanet.com/software/parallel/7i92.zip) vagy bármilyen más.
Csak a letölthető PDF.
Or is it just me that the download from the MESA site doesn't work?
Ezért kérdezem, hogy hol érhető el még a teljes kód.
Displaying 12061 - 12075 out of 12830 results.
Time to create page: 0.839 seconds
