  • mark-v-d
  • mark-v-d
24 Oct 2025 22:28
POSITION_FILE and index was created by mark-v-d
I would like to use the POSITION_FILE in combination with the index pulse
of the encoder to home my lathe. The idea is that you know approximately
where you are when starting up, and once you pass the first index pulse
you know the exact position. Has anyone done this... and if so can you
explain how?
  • SPH
  • SPH's Avatar
24 Oct 2025 22:22 - 24 Oct 2025 22:34
Help with Delta E3 Ethercat drives - hal and ethercat-conf.xml
Category: EtherCAT
That sorted it. Just #'d out the two PYVCP lines. Looking back over the build thread it was using probe basic so that's probably the issue.
I now have axis running with one encoder that's reading! Fantastic. Don't have any motor control though. I can move the motor shaft and get count and motion on the simulator display but with the machine enabled I can't jog. The sim shows movement but no shaft rotation.
I'm also getting a Linuxcnc notification "LCEC: Invalid appTimePeriod of 0 for master 0 (should be 1000000)."
A quick search on the forum suggests that relates to:
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
HOMEMOD=always_homed
in the ini file but it's set to 1000000 already.
  • Cooped-Up
  • Cooped-Up
24 Oct 2025 21:57
Replied by Cooped-Up on topic Maho MH800e Retrofit Project
Category: Milling Machines
watching the "DRO" the z axis zeros then moves, hits the index, zeros, and then hits the estop. I have the offset set to 0 so it should just stop correct?
  • Cooped-Up
  • Cooped-Up
24 Oct 2025 21:51
in testing the "Z" axis right now I have it passing the index point, it turns off the enable signal, seems to hesitate for a split second before continuing to the estop hard limit
  • PCW
  • PCW's Avatar
24 Oct 2025 21:47
Replied by PCW on topic Maho MH800e Retrofit Project
Is index-enable connected to both motion and the driver?
If the encoder index  (something like hm2_cardname.0.encoder.00.index-enable)
has been set but is not ever cleared when the index location has been passed,
that suggests a hardware issue with the index signal itself.
  • Unlogic
  • Unlogic
24 Oct 2025 21:14
Replied by Unlogic on topic Probe Basic backplot error when loading file
Category: QtPyVCP
After an impressively quick iterative process Lcvette and TurBoss managed to fix all the errors I encountered in this thread.
I'm sure they'll announce an updated development version shortly including these fixes.
  • Cooped-Up
  • Cooped-Up
24 Oct 2025 21:10
It does set the index enable currently it just sails right by it when homing
  • Will_cnc
  • Will_cnc
24 Oct 2025 21:07
Replied by Will_cnc on topic Stepperonline A6-1000EC driver
Category: EtherCAT
Hi
I am planning on using the same motor and driver for my mill until I upgrade to a larger motor.  would you be able to share your . ini  .hal  and . xml file of your configuration any what mode you set on the driver if you got it running?
Thanks will
  • PCW
  • PCW's Avatar
24 Oct 2025 20:57
Mesa smart serial or PktUART or serial over RS232 or udp for robot joints
Could official firmware for example for 6i25 or 7i92 currently accept 224bits via smart serial from slave?
Yes if the sserialb firmware is installed
  • andypugh
  • andypugh's Avatar
24 Oct 2025 20:47
Replied by andypugh on topic XHC-WHB04B-4 error during compile
Are you compiling from source because 2.9.6 doesn't work properly with the XHCWHB component?
If so then see this thread:
forum.linuxcnc.org/21-axis/57364-axis-co...-9-6?start=10#336658
if not, then you can get a list of the missing build dependencies
cd linuxcnc-dev
./debian configure no-docs
dpkg-checkbuilddeps
  • andypugh
  • andypugh's Avatar
24 Oct 2025 20:31 - 24 Oct 2025 20:32
Replied by andypugh on topic Lathe project needs a turret
Category: Turning
The manual turret looks like a prime candidate for motorisation...
Or get an industrial robot arm to operate the manual tool changer for you. :-)
  • andypugh
  • andypugh's Avatar
24 Oct 2025 20:19
Replied by andypugh on topic Maho MH800e Retrofit Project
You might need to force home-sw-in high, so that it always thinks it's on the switch, and then it will set the index-enable.
ie, in the HAL file:
sets joint.0.home-sw-in 1
  • sconisbee
  • sconisbee
24 Oct 2025 20:00
Replied by sconisbee on topic Feed per rev G95 way too fast
Category: Basic Configuration
Hi Andy, I've been running a 25,000ns relatively successfully. Which is why I've been scratching my head so much. However, actually thinking out loud on here had me thinking it had to be electrical. So I dug out the oscilloscope and probed the signal. The cheap Chinese sensors had a 20k pull up resistor which was far too strong and was causing the pulse width to be way too long. So at 1900 the signal went from a pulse train to just "on".
I've swapped out the resistor and now getting good clean pulses read by the Pi with a stable speed reading up to 4000rpm.
Thank you for your suggestions as they have pointed me in the right direction. I'm in the process of modelling up a mount so i can mount two sensors to create a encoder that will do direction as you suggested.
Displaying 12136 - 12150 out of 12865 results.
Time to create page: 2.627 seconds
