  • unknown
  • unknown
17 Oct 2025 21:26
Replied by unknown on topic Update LinuxCNC 2.9.5 on debian 13
Category: Installing LinuxCNC
That's ok mate.
What I found with the RPi Dbeian kernel is that it didn't allow for overlays, so things like SPI were an issue. There's quite a few customisations for the RPi compared to a "vanilla kernel".
The official image, which gives an easy way to start for most users, uses a kernel built from the RPi github sources and configured for real time. It took a bit of time to find the "right kernel" from their sources, but eventually it was found and the image was an easy task from there on in.
There's quite a large thread with the first post explaining what it's all about. And as ssh is enabled out of the box you technically don't have to connect a keyboard and Display.
  • DavidR8
  • DavidR8
17 Oct 2025 21:22
New Probe Basic install - error during install.
Category: QtPyVCP
Yeah, no love. I'm going to go with QTDragon instead.
  • f355
  • f355's Avatar
17 Oct 2025 20:48
Replied by f355 on topic Update LinuxCNC 2.9.5 on debian 13
I'm sorry if that came out sounding arrogant, that was not the intent. I totally understand why Tommy suggested apt update, I just wanted to quite literally save his and my time.
I can certainly build it myself, or use 2.9.4 that works just fine for my purposes, or whatever. I don't have a problem, LinuxCNC has a problem, and being unable to fix it for everybody, I'm reporting it here in hopes that someone blessed with permissions does that.
Raspberry Pi OS Lite doesn't come with a desktop environment or a window server pre-installed, so I'm free to choose what to use (XFCE obviously lol). PREEMPT_RT kernel is available as an official package from Raspberry Pi debian repos these days and works fine. I'm not sure what the "official" linuxcnc raspberry pi image would give me at this point, and it is much harder to use for me personally - it requires me to connect a display/keyboard, for example. As to libgpiod or axis, I don't use either so I can't say anything about them.
  • unknown
  • unknown
17 Oct 2025 20:23
With your 20 years experience if you really want 2.9.5 on arm you can always build it yourself. ;)
As for the version differences that will depend on the system the packages were built on.
Was there any reason, apart from the official arm image being based on Bookworm, that you went with Raspberry Pi OS Lite ?
Does that give you the choice of Wayland or X11.
Look we get a lot of users with varying degrees of Linux Experience, as we can't tell your experience usually we start advice with the basics. So no it's not a waste of time starting with said basics.
From memory when I attempted to build an RPi image based on Devuan, based on Trixie or maybe unstable, there was an issue with the libgpiod library. At the time the libgpiod driver would not compile against version 2.0 so I abandoned that idea due to that. As far as I know I'm unaware of that situation has changed. Bear in mind that there are some issues that affect Axis in 2.9.5 and 2.9.6 that have been well reported on the forum. It would appear they have been resolved but looks like we need to wait for a 2.9.7 version.
  • DavidR8
  • DavidR8
17 Oct 2025 20:13 - 17 Oct 2025 20:14
Category: QtPyVCP
Thanks, I'll give that a try.
17 Oct 2025 20:12
Replied by tommylight on topic No underspeed with temporary material
Category: Plasmac
Seems a bit over the hedge, i mentioned multiple times that for under 100$ it is very OK, but 279$ i can not justify nor advise any longer.
17 Oct 2025 20:09
Replied by tommylight on topic New Probe Basic install - error during install.
Category: QtPyVCP
Try
sudo apt update
then
sudo apt install python3-distro
Run install again.
  • f355
  • f355's Avatar
17 Oct 2025 19:53 - 17 Oct 2025 19:55
I've done that, quite obviously. I think it is better to save time and skip obvious advices, I have 20 years of in-depth professional experience with Linux behind my back.
The real issue is that the package depends on the version of python3 that trixie doesn't provide, as can be seen here :
Depends: python3 (<< 3.12), python3 (>= 3.11~),
amd64 package depends on 3.13 :
Depends: python3 (<< 3.14), python3 (>= 3.13~),
It looks like a simple oversight more than anything else, those things happen. If it is, I hope it gets corrected soon!
  • DavidR8
  • DavidR8
17 Oct 2025 19:40 - 17 Oct 2025 19:41
Category: QtPyVCP
What Linux OS being used including kernel type?
Debian 12
-  What version of Linuxcnc is installed?
2.9.4
-  What version of QtPyVCP and Probe Basic is installed?
Version from here: kcjengr.github.io/probe_basic/quick_star...l#installation-steps
-  How did you install Probe Basic? Quickstart guide? Dev Guide?
I followed the quickstart guide.
I get an error when I run the third command 'sudo dpkg -i python3-qtpyvcp_5.0.2-19.dev_amd64.deb'
The download folder shows the file.
17 Oct 2025 19:38
Replied by tommylight on topic Update LinuxCNC 2.9.5 on debian 13
Must do:
sudo apt update
first, then try installing.
  • snowgoer540
  • snowgoer540's Avatar
17 Oct 2025 19:24
Replied by snowgoer540 on topic No underspeed with temporary material
Category: Plasmac
Found my invoice it was $110 in 2020. Quite the jump.
  • f355
  • f355's Avatar
17 Oct 2025 18:25
Thank you for fixing this, Andy, the new key works just fine!
However, the debian package itself seems to have a broken python3 dependency. I'm on the latest Raspberry Pi OS Lite (which is basically trixie with a custom kernel and a few Pi-specific tools installed). Any particular reason for the arm64 package to want python3 < 3.12? amd64 one depends on 3.13, and so does linuxcnc-uspace 2.9.4 that comes with trixie.
$ sudo apt-get install linuxcnc-uspace
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Solving dependencies... Error!
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
 linuxcnc-uspace : Depends: python3 (< 3.12) but 3.13.5-1 is to be installed
                   Depends: libboost-python1.74.0 (>= 1.74.0+ds1) but it is not installable
                   Depends: libboost-python1.74.0-py311 but it is not installable
                   Depends: libgpiod2 (>= 1.5.1) but it is not installable
                   Depends: libpython3.11 (>= 3.11.0) but it is not installable
                   Recommends: linuxcnc-doc-en but it is not going to be installed or
                               linuxcnc-doc
                   Recommends: librsvg2-dev but it is not going to be installed
                   Recommends: hostmot2-firmware-all but it is not installable
                   Recommends: python3-pil but it is not going to be installed
                   Recommends: python3-pil.imagetk but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
E: The following information from --solver 3.0 may provide additional context:
   Unable to satisfy dependencies. Reached two conflicting decisions:
   1. linuxcnc-uspace:arm64=1:2.9.6 is selected for install
   2. linuxcnc-uspace:arm64=1:2.9.6 Depends python3 (< 3.12)
      but none of the choices are installable:
      [no choices]
  • PanikEspoir
  • PanikEspoir
17 Oct 2025 18:05
Replied by PanikEspoir on topic Terminated with an error, I'm begging for help
There were some electric issues due to an electric storm.
Thanks for the reply.
  • unknown
  • unknown
17 Oct 2025 17:42
Step By Step Help Needed . EL8 Leadshine to PI 5
Category: EtherCAT
Waveshare do an add ethernet adaptor that connects via the pcie bus, they also do one that has a Nvme drive and an ethernet adaptor.
The Odroids have Realtek adapters, so there's that to think about, but I didn't have any issues although I did install the dkms drivers. Then again the Odroid has Nvme and sata ports built in, so no extra $$$ in that respect.
The N100 with Intel hardware sounds like worthy advice. Decisions decisions.
  • unknown
  • unknown
17 Oct 2025 17:30 - 17 Oct 2025 17:32
Is there a new Linuxcnc release in the wings ?
Everything has been pretty well documented within the package lists and in the commit messages.
I thought a backport would be a package that is in eg Trixie that was been repackaged for Bookworm.
TBH the extra packages may be pulling in too much extra stuff, the ISO weighs in at about 4.1G, which I think is due to suggested packages being installed as well. And TBH I've only included them to make transferring files around a little easier whilst testing. Like I said it's experimentation ATM, whether it's any use upstream I don't know.
Not even going to bother to upload to Google drive and ask for any help testing as it was a waste of time. I guess people are busy.
Displaying 12571 - 12585 out of 12890 results.
Time to create page: 0.536 seconds
