  • tcbmetalworks
  • tcbmetalworks
16 Oct 2025 18:58
Replied by tcbmetalworks on topic 10.5 x 25 cnc plasma table retrofit
here is the red box turned into a blue box, will be a nice enclosure plenty of room and lots of protection against forklifts swinging sheets of metal and the holes in the roof
  • Fabse
  • Fabse
16 Oct 2025 18:51
Axis configuration not fully working on 2.9.6
Category: AXIS
Hey,
@ChrisB_II thanks for the explanation and the link you posted. I looked at the documentation and a youtube video about building linuxcnc and even though it seems doable, I don't think I am comfy going down that route. :D
@andypugh How do I go about installing the .deb file? Update to 2.9.6 and then just run the command you posted?
  • tcbmetalworks
  • tcbmetalworks
16 Oct 2025 18:50
Replied by tcbmetalworks on topic Automatic band saw marvel v10a
Category: CNC Machines
Heres where im at with the project, I got the most of the machine wired up, and had it "functioning" the hydraulic that actuates the back and forth of the shuttle is leaking threw and slowly pushes forward when idle aswell as makes a big mess of my floor. When the machine trys to shuttle forward it like jumps back and forth intill it hits the spot it needs to be on the linear encoder then slowly seeps forward. I had a feeling this would be a problem. Am I crazy to try to pair a encoder to a hydraulic and expect it to acurately position? Or would this problem be solved by fixing the leaking hydraulic and maybe a new solenoid valve. Is there any examples of somebody doing similar, controling a hydraulic accurately with a linear encoder. or do i scrap the hydraulic system, only keep it for clamping and to push the blade forward. Replacing the hydraulic with a heavy duty servo motor and ball screw.
  • jmp97
  • jmp97
16 Oct 2025 18:37
Replied by jmp97 on topic LinuxCNC installation + 7I96S
Category: Installing LinuxCNC
My PC uses a Realtek RTL8111/8168/8411 network card, integrated into the Gigabyte motherboard.
Does this network card model cause problems with Mesa?
  • snowgoer540
  • snowgoer540's Avatar
16 Oct 2025 18:30
THC qtplasmac 2.9 is moving UP when it should be moving DOWN
To add to what Tommy said ...
From: linuxcnc.org/docs/devel/html/plasma/qtpl...ml#plasma:z-settings
[AXIS_Z] MIN_LIMIT should be just below top of the slats with allowances for float_switch_travel and over travel tolerance. For example, if the user’s float switch takes 4 mm (0.157") to activate then set the Z minimum to 5 mm (0.2") plus an allowance for overrun (either calculated using the equation below or allow 5 mm (0.2") below the lowest slat).
[AXIS_Z] MAX_LIMIT should be the highest the user wants the Z axis to travel (it must not be lower than Z HOME_OFFSET).
[AXIS_Z] HOME should be set to be approximately 5 mm-10 mm (0.2"-0.4") below the maximum limit.
There's a nice diagram there too.
  • Hakan
  • Hakan
16 Oct 2025 17:08
Is there a new Linuxcnc release in the wings ?
But Andy does have a good point, doesn't he? It would be much better if this was fixed in the official linuxcnc distribution.
Perhaps you can open an issue at linuxcnc github and see it you can get your fixes incorporated?
  • jmp97
  • jmp97
16 Oct 2025 16:15
I get this:
halcmd show all *.tmax?
Loaded HAL Components:
ID Type Name PID State
Component Pins:
Owner Type Dir Value Name
Pin Aliases:
Alias Original Name
Signals:
Type Value Name (linked to)
Parameters:
Parameter Aliases:
Alias Original Name
Exported Functions:
Owner CodeAddr Arg FP Users Name
Realtime Threads:
Period FP Name ( Time, Max-Time )
The LEDs on the board that light up:
CR6 --> Red
CR8 --> Yellow
CR11, CR12, and CR14 --> Green
16 Oct 2025 14:34
Replied by tommylight on topic 3D printed stuff, showcase it here
Category: Additive Manufacturing
You mean propellers?
Pretty damn well, none have disintegrated so far and mostly the smaller ones stay intact when bumping into something while spinning, it takes a bit of effort to break them, and that is mostly due to printing direction.
Also i do not use PLA, ABS, HIPS, PETG, and lately PA6 Nylon.
The main issue are sanding them properly will improve efficiency a lot, and balancing them is a must sometimes.
Give it a try, you will be surprised how good they can be, just keep layer line longitudinally.
  • andypugh
  • andypugh's Avatar
16 Oct 2025 14:27
Replied by andypugh on topic Injection molding
Injection molding
It could be done. It's probably how I would do it if I had to control an injection moulding machine, but only because I already know how to use LinuxCNC.
(when your only tool is a hammer....)
Getting temperature into LinuxCNC HAL is not the easiest thing. One option is:
linuxcnc.org/docs/stable/html/man/man9/max31855.9.html
16 Oct 2025 14:25
Replied by tommylight on topic Injection molding
Injection molding
First such machine i fixed was back in 1990 !!!
They are complicated machines, but all are made from simple parts, so look at it as separate parts, makes it much easier.
The main hurdle with retrofitting such machines is the logic and interlocks, writing down whatever you already know will help a lot during programing.
  • andypugh
  • andypugh's Avatar
16 Oct 2025 14:22
Replied by andypugh on topic what means TC abbreviation in TC_STRUCT?
Category: LinuxCNC Documents
TP - Trajectory Planner ( see src/emc/tp/tp.c)
TC - Trajectory Controller. (see src/emc/tp/tc.c))
  • Aciera
  • Aciera's Avatar
16 Oct 2025 14:19
Replied by Aciera on topic Tutorials
Tutorials
but if there's no new tutorials out there to guide newbs, then i might as well not waste my time and just install windows.
Makes me wonder why we bother maintaining about 1500 pages of written documentation:
linuxcnc.org/docs/html/
  • laurentl38
  • laurentl38
16 Oct 2025 13:51
Replied by laurentl38 on topic increment 4 MPG jog wheels with Basic Probe
Category: QtPyVCP
Yes, that's a solution. I'll think about it, if I start modifying the code (I'm not very good at programming) or if I find a solution to add additional control switches (from my window, this solution seems the easiest to me)
  • andypugh
  • andypugh's Avatar
16 Oct 2025 13:27
Replied by andypugh on topic increment 4 MPG jog wheels with Basic Probe
Category: QtPyVCP
Probe Basic is written in Python, you could modify it.
  • andypugh
  • andypugh's Avatar
16 Oct 2025 13:21
Replied by andypugh on topic Enlarge Hal_Meter
Enlarge Hal_Meter
Category: GladeVCP
Try a different layout with a 2-element V-box with a 2-element H-box in the top box.
I think that your meter is being constrained to be same width as "Licht" as it is in the same column.
Displaying 12631 - 12645 out of 12890 results.
Time to create page: 0.894 seconds
