  • cmorley
  • cmorley
17 Aug 2025 20:01
Replied by cmorley on topic qt_auto_probe_tool with large tool offset
Category: Mill Library
What version of linuxcnc?
What is the actual error message?
Can you pin this down to what line ?
Can you post your INI file.
  • PaulQUE
  • PaulQUE
17 Aug 2025 19:33
extra axis on 7i96 with bob was created by PaulQUE
Category: Driver Boards
hello, I have a working config on my cnc machine using a 7i96 (no s) thats using 4 stepgens and pmw output for the spindle and it's been working greaat for a few years now.
I need the four stepgens to square up the gantry (XYYZ kinematics) and I am looking at options to add a 5th stepgen to drive a rotary axis using a chinese Bob connected to the P1 expension port.
Am i correct it seems the simplest is to move the spindle pwm control to the BOB to use the 5 stepgens directly on the card?
what firmware would i need to flash on the card, and is there a exemple config that displays how to drive the spindle pwm output from the BOB?
thanks for the help
  • Hakan
  • Hakan
17 Aug 2025 19:32
Replied by Hakan on topic AX58100
AX58100
Category: EtherCAT
Pushed changes to EaserCAT 3000.
The problem was a little bigger than expected.
There is, somewhere and I don't know exactly where, a limit on how much data can be sent every ethercat cycle.
After diagnosing that, the PDOs had to be reshuffled, and MaxAcceleration and StepperScale (StepsperMM) had to be static data in SDOs.
Still settable, but in the ethercat-config.xml file.
I also added a linuxcnc configuration so the E3000 card can easily be tested. It includes a mini stepper motor milling machine.
Files, including an ethercat-conf.xml, is in linuxcnc/configs/sim.axis.
  • roboDan
  • roboDan
17 Aug 2025 19:27
Replied by roboDan on topic Erratic Z axis
Erratic Z axis
Category: Basic Configuration
Well, I apologise - it appears that one of the coil wires was loose! Typical!
After completely removing it and screwing it back into its terminal (while the driver was off), I was able to get a smooth movement out of the Z axis.
Thanks for your time - apologies for not noticing...I've been troubleshooting this thing for days and I may have lost my mind :) I'm very much looking forward to using LinuxCNC!
  • Aciera
  • Aciera's Avatar
17 Aug 2025 19:25
Replied by Aciera on topic Hal Error
Hal Error
Gui related pins need to be connected in the POSTgui hal file as the gui itself is not yet loaded when the regular hal files are run.
  • roboDan
  • roboDan
17 Aug 2025 19:20
Erratic Z axis was created by roboDan
Erratic Z axis
Hello all,
I've recently followed a guide to put together a 3-axis CNC milling machine, as guided by  this video . In short, the X and Y axes move the gantry using pulleys on a HTD3M timing belt, and the Z axis uses a 5mm pitch lead screw.
I am using 4 TB6600 stepper motor drivers to drive 4 NEMA 23 motors. Going through stepconf, the X and Y axes run fine and smoothly, but the Z axis refuses to work in the same way. It stutters and erratically changes direction.
I've checked all of the connections for the parallel BOB I am using, the driver and motor itself, and I was able to move the Z axis without issue when I started out with the Arduino GRBL kit that was recommended in the video.
Please let me know what I should be looking for. I'm attaching the ini and hal files to this post, and in the meantime I'll re-check all of the wiring.
Thanks in advance for your help!
  • Silverback
  • Silverback
17 Aug 2025 19:18 - 17 Aug 2025 19:26
qt_auto_probe_tool with large tool offset was created by Silverback
I am trying to adapt `qt_auto_probe_tool.ngc` to offset large tools and measure at the edge. I get "Internal error: unable to assign #<offset_amount>". I have added the variables to the .ini file under [VERSA_TOOLSETTER].
I am not sure what's going on. Is it a scope issue and I am not setting it in the proper location? Are the variables from the ini file not being parsed?
Also, is there any way to debug this step by step instead of trying it and getting the error out of the gui?
Many thanks.
o<qt_auto_probe_tool> sub
; IMPORTANT: this remap enables using a gcode/ngc program on machines without
;    automatic tool changers, and without repeatable tool holders, but which
;    do have a tool setter (and ideally, an xyz probe).
;    With this remap, a program or user can issue TxM6 commands at any
;      point and the machine will automatically do the following:
;      1. Move to a tool change position defined in .ini parameters, Z first, then XY
;      2. Perform the normal M6 tool change (IE stop spindle, prompt for tool)
;      3. Move to the location of the toolsetter, Z first, then XY, probe the new tool's offset
;      4. Change the offset of the current coordinate system to match the new tool
;      5. Return the tip of the new tool to the same spot as the tip of the old tool
;            based on newly measured z-offset
;      6. Return control back to whatever state it was in prior, continuing the program
;           if one had been running.
; The following settings should be enabled in the QtDragon interface:
;    A -  Under Probe Tool screens: insure that "Tool Measure" is enabled
;    B -  Under Settings: insure that "Use Tool Sensor" is enabled
;  The following workflow assumes using both a XYZ probe and a Z Toolsetter:
;    1 - Initial Setup: Before beginning the program, setup the Probe Tool as
;        having a zero z-offset in the tool table. (Non-zero tool lengths
;        for the probe tool can be made to work, but have multiple extra
;        steps required, and it is easy to have the tool offset interfere with
;        the remap coding and cause incorrect adjustments to your offsets.
;        This procedure assumes a zero length.)
;    2 - Initial Tool: Load the probe tool with M61 Qx, where x is the Probe tool's number
;        in the tool table. (Do not use TxM6)
;    3 - Toolsetter measure: Use button under the Probe Screens for "Probe Tool Setter
;        Z Height:" this will set and display on the Probe Settings screen the
;        "Probe HT" = #<_hal[qtversaprobe.probeheight> value in ABS coordinates.
;    4 - Workpiece Measure: Use the button under the Probe Screens for "Probe Z height
;        of material:" this will set and display on the Probe Settings screen the
;        "Block Ht" = #<_hal[qtversaprobe.blockheight]> value in ABS coordinates.
;    5 - Set Coord System (G54): Use the Probe Tool and whichever probe screen is
;        appropriate to set the coordiate system XYZ offsets needed for your job.
;        NOTE: Return_Option 3 uses the current local coordinate system, not just ABS coord.
;    6 - Prepare to Run: You may then issue a manual TnM6 command to change the tool
;        before starting the job, or if the job begins with a TnM6 command before
;        spinning the spindle, you may leave the Probe Tool installed.
; !! Take care not to leave the XYZ tool probe in the spindle when a program may start
;    the spindle. !!
(debug, in change tool_in_spindle=#<tool_in_spindle> current_pocket=#<current_pocket>;)
(debug, selected_tool=#<selected_tool> selected_pocket=#<selected_pocket>;)
; --- Begin Initial data gathering ----
#<tool> = #<selected_tool>
#<pocket> = #<selected_pocket>
#<local_start_x> = #<_x>
#<local_start_y> = #<_y>
#<local_start_z> = #<_z>
#<toolsetter_diameter> = #<_ini[VERSA_TOOLSETTER]TOOLSETTER_DIAMETER>
#<offset_direction> = #<_ini[VERSA_TOOLSETTER]OFFSET_DIRECTION>
#<offset_amount> = 0 ; initialize offset amount to zero.
; --- End Initial Data Gathering ----
; --- Begin Initial Safety Checks ----
; we must execute this only in the milltask interpreter
; or preview will break, so test for '#<_task>' which is 1 for
; the milltask interpreter and 0 in the UI's
o100 if [#<_task> EQ 0]
        (debug, Task is Null)
o100     return [999]
o100 endif
; check we are in right mode
o110 if [#<_metric_machine>]
    o115 if [#<_imperial>]
       (MSG, Auto Tool probe error: not in G21 mode )
    o115 return [-3] ; indicate probe contact failure to epilog
    o115 endif
o110 else
    o115 if [#<_imperial> EQ 0]
       (MSG, Auto Tool probe error: not in G20 mode )
    o115 endif
o110 endif
;check we have a usable search velocity configured, otherwise error
o150 if [#<_hal[qtversaprobe.searchvel]> LE 0]
    (MSG, No usable search velocity in hal.qtversaprobe.searchvel)
    o150 return [-1] ; indicate searchvel <= 0
o150 endif
;check we do not have an invalid Return Option
o175 if [EXISTS[#<_ini[VERSA_TOOLSETTER]RETURN_OPTION>]]
    #<return_opt> = #<_ini[VERSA_TOOLSETTER]RETURN_OPTION>
    o176 if [[#<return_opt> EQ 1] OR [#<return_opt> EQ 2] OR [#<return_opt> EQ 3]]
        ;Continue: Return_Option is both defined and valid
    o176 else
        (MSG, Invalid RETURN_OPTION in .ini file under VERSA_TOOLSETTER)
        o176 return [-1] ; signal error to post processing
    o176 endif
o175 else
    ;Continue: it is valid to not define Return_Option, defaults to 1
o175 endif
; --- End Initial Safety Checks ----
; --- Begin Physical Tool Change ----
;first go up
F #<_hal[qtversaprobe.searchvel]>
G53 G0 Z[#<_ini[CHANGE_POSITION]Z>]
o200 if [#<_current_tool>  NE #<tool>]
    ; then move to change position
    G53 G0 X[#<_ini[CHANGE_POSITION]X>] Y[#<_ini[CHANGE_POSITION]Y>]
o200 endif
;cancel tool offset mode
G49
; using the code being remapped here means 'use builtin behaviour'
;  ie, this is not a recursive call to this program, but calls the
;    un-remapped M6 processing
;  That processing includes actually sending the window to the user
;    to press OK when they have completed the tool change.
M6
; ------ End Physical Tool Change ----
; ------ Begin Safety Checks for Tool Offset Measurement ----
o300 if [#<_hal[qtversaprobe.enable]> EQ 0]
   (MSG, Auto Tool probe disabled )
    G43 ;turn back on tool offset mode before returning
o300 return [3] ; indicate no tool measurement
o300 endif
;check we have a usable probe velocity configured, otherwise error
o400 if [#<_hal[qtversaprobe.probevel]> LE 0]
o400 return [-2] ; indicate probevel <= 0
o400 endif
; ------ End Safety Checks for Tool Offset Measurement ----
; ------ Begin Tool Offset Measurement ----
;rapid-move to safe height
G53 G0 Z[#<_ini[VERSA_TOOLSETTER]Z_MAX_CLEAR>]
;Then rapid-move to probe XY location
G53 G0 X[#<_ini[VERSA_TOOLSETTER]X>] Y[#<_ini[VERSA_TOOLSETTER]Y>]
; --- Start of new code for diameter compensation ---
M1 ; Option stop for debugging
0440 if [is_number[#<toolsetter_diameter>]]
    o450 if [#5410 GT #<toolsetter_diameter>]
        #<offset_amount> = [[#5410 - #<toolsetter_diameter>] / 2]
        (debug, tool diameter=#5410)
        (debug, toolsetter diameter=#<toolsetter_diameter>;)
        (debug, offset amount=#<offset_amount>;)
        o451 if [#<offset_direction> EQ 1]
            G53 G0 X[#<_ini[VERSA_TOOLSETTER]X> + #<offset_amount>]
        o451 elseif [#<offset_direction> EQ 2]
            G53 G0 X[#<_ini[VERSA_TOOLSETTER]X> - #<offset_amount>]
        o451 elseif [#<offset_direction> EQ 3]
            G53 G0 Y[#<_ini[VERSA_TOOLSETTER]Y> + #<offset_amount>]
        o451 elseif [#<offset_direction> EQ 4]
            G53 G0 Y[#<_ini[VERSA_TOOLSETTER]Y> - #<offset_amount>]
        o451 endif
    o450 endif
o440 else
    (debug, tool_diameter=#<tool_diameter> toolsetter_diameter=#<toolsetter_diameter>;)
    (MSG, tool_diameter or toolsetter_diameter is not a number)
o440 endif
; --- End of new code for diameter compensation ---
;then feed down to the probe start location
G53 G1 Z[#<_ini[VERSA_TOOLSETTER]Z>]
;switch to relative distance mode for probe moves
G91
;begin initial probe move
G38.2 Z- #<_ini[VERSA_TOOLSETTER]MAXPROBE>
G0 Z #<_hal[qtversaprobe.backoffdist]>
o510 if [#5070 EQ 0]
G90
o510 return [-3] ; indicate probe contact failure to epilog
o510 endif
;reprobe at probe speed: G38.2 means probe toward workpiece, stop on contact
;  when G38.n axis completes, it puts the Z value detected (in the coordinates system
;  in which this program started) into parameter #5063 (because we're probing Z)
F #<_hal[qtversaprobe.probevel]>
G38.2 Z- [#<_hal[qtversaprobe.backoffdist]> *1.2]
o511 if [#5070 EQ 0]
G90
o511 return [-3] ; indicate probe contact failure to epilog
o511 endif
;switch back to absolute distance mode once probing is done
G90
;set the current offset
#<touch_result> = #5063
; G10 L1 is the Set Tool Table Offset: it changes the tool table offset,
;   it DOES NOT change the offsets in the current coordinate system. (that would be G10 L2)
#<calculated_offset> = [#<touch_result> - #<_hal[qtversaprobe.probeheight]> + #<_hal[qtversaprobe.blockheight]>]
G10 L1 P#<tool> Z[#<calculated_offset>]
;G43 enables tool length offset: this affects all subsequent moves by applying
;  the offset just calculated to the coordinate system currently in
;  effect. ie. it has subtracted Calculated Offset from the Z offset
G43
(DEBUG, %fProbe Height: #<_hal[qtversaprobe.probeheight]>;)
(DEBUG, %fBlock Height: #<_hal[qtversaprobe.blockheight]>;)
(DEBUG, %fProbe Result: #<touch_result>;)
(DEBUG, %fCalculated Offset: #<calculated_offset>;)
; ------ End Tool Offset Measurement ----
; ------ Begin Return Movement ----
; return to original tool-tip position, but using new z-offset
(DEBUG, Return to original tool-tip position using new z-offset: #<local_start_x> , #<local_start_y> , #<local_start_z>;)
; now use original (modal)coord system to go over to xy
G0 X[#<local_start_x>] Y[#<local_start_y>]
;M1 ; Option stop for debugging
; and finally down to the (already offset) z coord
;G0 Z[#<local_start_z>]
; ------ End Return Movement ----
; signal success be returning a value > 0:
o<qt_auto_probe_tool> endsub [1]
m2
  • AdelRTP
  • AdelRTP
17 Aug 2025 19:10
Hal Error was created by AdelRTP
Hal Error
 When I use the net command in my HAL file in LinuxCNC to connect a QtDragon pin (for example, net jogspeed_u qtdragon.slider-jogspeed-linear classic ladder.0.floatin-05) to a HAL signal, I get an error saying that the pin qtdragon.slider-jogspeed-linear does not exist. However, when I run the same command via the halcmd interface, no error occurs. What could be the reason for this issue?
  • Jonathan_H
  • Jonathan_H
17 Aug 2025 19:07
System hangs repeatedly with certain combinations of operations
using spindle-enable the output of lut5.0 seemds to remain resolutely False, despite the values of the input signals being correct
  • Mars
  • Mars
17 Aug 2025 18:53
Remora - Can't get it out of estop....
First, thanks for all the help.  This is my time LinuxCNC so, please bear with me.  My setup:  Rpi5 with SPI to a BigTreeTech SKR 1.4 (has the LPC processor) running Remora pulled from Github a couple weeks ago.  I got everything compiled and I think in the right place (I got a bunch of warnings on the SPI Remora compile but was told to ignore).  I figured the remora-xyz sample code looked like a good place to start.  The LinuxCNC Config Selector allows me to select remora-xyz and a window starts with axis.ngc.  *The problem is that the Emergency Stop button comes up pressed and it can't click it off*.  I have tried using the halmeter tool and found a variable called iocontrol.0.user-request-enable that I think may be relevant based on looking at the .hal file.  This PIN reads FALSE but very briefly flashes to TRUE, then back to FALSE when I click on the Estop button.  I as wondering if the remora-xyz example is actually trying to read a HW input somewhere on the SKR 1.4 board that I should be terminating correctly?   Any suggestions much appreciated.  TIA.
  • Clemens
  • Clemens
17 Aug 2025 18:38
I somehow have troubles with my Linuxcnc setup. I use linuxcnc together with a NVEM Board with a RT1052 on it and the Remora-RT1052-cpp. When I do normal milling I usually don't see any problems. But with complex 3D surfaces all of the axis somehow drift away. It's not much but after 15 minutes of milling it's about 0.1mm. I'm quite sure that the problem are not the motors or the drivers. I also have the correct setup (setup and hold times) for my motordrivers, I even checked them with an oscilloscope and they are fine. With the oscilloscope I could also see, that the problem is not an EMI Problem, the signals (STEP/DIR) are not noisy at all.
Is it possible, that there is a problem with the Stepgenerator? I use the (almost) latest firmware 3.13 but from what I've seen the changes after 3.13 where not related to the Stepgenerator.
If not what else could cause this problem?
Thanks Clemens
  • alpri0265
  • alpri0265
17 Aug 2025 17:18
Request for firmware bitfile for Mesa 7i90HD + 7i85S (3 axes, encoders, PWM)
Thank you very much for the firmware! It loaded to the board without problems. I will try it out.
  • SebastianM
  • SebastianM
17 Aug 2025 17:03
Replied by SebastianM on topic Issues with MESA 7976eu analog-in
Thx Peter.
How would you “handle” this? Could I just subtract a constant value from the calculated temp?
  • PCW
  • PCW's Avatar
17 Aug 2025 16:31
Replied by PCW on topic Issues with MESA 7976eu analog-in
The 7I76EU inputs have and ~11K input impedance which needs to be accounted for
when driven by a high impedance source (it looks like your source impedance is around 5K Ohms)
  • PCW
  • PCW's Avatar
17 Aug 2025 16:27
Displaying 13591 - 13605 out of 14148 results.
Time to create page: 0.555 seconds
