  • alpri0265
  • alpri0265
17 Aug 2025 16:10
Request for firmware bitfile for Mesa 7i90HD + 7i85S (3 axes, encoders, PWM)
Category: Driver Boards
Thanks for the firmware file! When I try to flash it with mesaflash, I get the error Invalid bitfile header. It looks like this is a raw Xilinx ISE/Vivado .bit file. Could you please provide the firmware in the proper format for mesaflash (with the MESA header, or as a .bin file for the 7i90)?
  • alpri0265
  • alpri0265
17 Aug 2025 16:03
Replied by alpri0265 on topic Mesa card 7i90 error following
  • SebastianM
  • SebastianM
17 Aug 2025 15:56 - 17 Aug 2025 16:21
Issues with MESA 7976eu analog-in was created by SebastianM
Hey guys,
I want to measure the internal temp of my jianken ATC spindle. I have a NTC with a classic voltage divider setup, and at room temperature the V_out of this divider carries 12V. (Measured against GND with a multimeter).
However, as soon as I put this cable into analog_in1 of my Mesa 7i76eu, the voltage drops to 8v, and thous the calculated temperature is garbage...
Any ideas why this is happening?
Sebastian
  • PCW
  • PCW's Avatar
17 Aug 2025 15:15
Note that the pins listed in the source file comments are DB25 pins
so
7I90  P4.1  --> DB25.1
7I90  P4.3  --> DB25.14
7I90  P4.5  --> DB25.2
etc
  • alpri0265
  • alpri0265
17 Aug 2025 15:02
  • Surmetall
  • Surmetall's Avatar
17 Aug 2025 14:47 - 17 Aug 2025 14:50
Replied by Surmetall on topic NativeCam on LinuxCNC 2.9.3
Category: NativeCAM
Hi thanks for your answer. Yes i saw your Macros and i think they look really good. You did and do a great jobs there for all, thank you for that! But as far as i understand them, you can only use one at a time right? and there is also no macro for a free contur ? or do i miss something?
edit: oh sorry my bad, they are from andypugh of course! so thanks andy :)
  • PCW
  • PCW's Avatar
17 Aug 2025 14:31 - 17 Aug 2025 14:32
Note that this is not a standard configuration as the 7I90 is a 50 pin connector FPGA card
and the 7I85S is s 25 pin FPGA card daughtercard. I pinned this out so a flat cable adapter
should be relatively simple (look at the included VHD source file for the pinout)
File Name: 7i90_7I85S31p_p4.zip
File Size:9 KB
This has 3 stepgens and 1 PWMgen, 4 encoders and a sserial port
(on the 7I85S)
  • PCW
  • PCW's Avatar
17 Aug 2025 14:07
MESA 7i97 - connection of DC Tach-Motors (2)
Very briefly:
In the hal file (use the sample: basic7i97 or use MesaCT to generate the basic configurations)
The PID output pin connects to the PWM value pin. You would change this connection to
add the abs component so you have:
PID output --> abs in --> abs out --> PWM value
That is, for example, in the basic7i97 hal file you have:
net x-output     => [HMOT](CARD0).pwmgen.00.value
This would need to change to:
net x-output     => abs.0.in
net abs-x-output    <= abs.0.out
net abs-x-output     => [HMOT](CARD0).pwmgen.00.value
  • machinedude
  • machinedude's Avatar
17 Aug 2025 14:03
Replied by machinedude on topic QTPYVCP+VISMACH+LINUXCNC ROLLED INTO ONE?
Category: QtPyVCP
i'm not even close to being done but got the viewer hooked into a custom .ui file. i think i am on the downhill side of things now but this seems to be the hard way to do it :) but since i have so much time in teaching myself this i will finish what i started. but basically, it's done in OpenGL.
  • alpri0265
  • alpri0265
17 Aug 2025 12:33
I understand, thank you! The duplication was unintentional. My apologies
17 Aug 2025 12:17
  • Asymmetrisch
  • Asymmetrisch
17 Aug 2025 12:16
Replied by Asymmetrisch on topic Problem bei installation Ethercat
Category: Deutsch
Hallo Franz,
hast du die Kombination ServoStar - EL6751 in der Zwischenzeit noch zum Laufen gebracht?
Schöne Grüße,
Gerhard
17 Aug 2025 12:14
You posted the same question twice, and that is not good as it makes it impossible for us to follow what has been answered, and for users to find the correct info when they need to.
Duplicate post was deleted.
Thank you.
  • Hartwig
  • Hartwig
17 Aug 2025 12:14
Replied by Hartwig on topic MESA 7i97 - connection of DC Tach-Motors (2)
Thanks a lot for the answer.
Good message: it is doable and I can use the RS Pro amplifier. Unfortunately the Mattke not. In any case, I have to forget the Tach function of the motors.
Sorry for my further questions - I`m an absolute beginner and not an experienced programmer. This are my first steps in learning to run.
Below I have formulated my questions in red font. I need to understand, whether the I/Os on my MESA are sufficient by number and by functionality.
Thanks a lot and best regards
Hartwig
  • alpri0265
  • alpri0265
17 Aug 2025 11:49
Sorry, I didn’t quite understand what you mean by "without double posting". Could you please explain?
Displaying 13606 - 13620 out of 14148 results.
Time to create page: 0.585 seconds
